Need Advice Pinning Down Existing Drip Cap
Old 05-07-2009, 04:05 PM   #1
Brian (FL)'s Avatar
The aluminum drip cap on the front of my house needs to be pinned down. There are not enough nails and the ones that are there are not driven down tight enough. Didn't really notice until I had seamless gutters installed. Gutter goes behind the drip edge and the brackets are then screwed through the face of the drip cap.When the mounting brackets were screwed in it caused the top of the drip cap to buckle up in spots. So I need to pin the drip cap down to the roof without removing or damaging the existing shingles. Any tips or tricks from you pros?
I'm also wondering if there is another way to attach the gutter brackets (maybe a different type) to avoid the drip cap? Thanks.
Brian (FL) is offline
Old 05-07-2009, 04:16 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Re: Need Advice Pinning Down Existing Drip Cap
This site is for pro-to-pro talk. You might get better results by posting at the sister DIY forum, where many of our members often help those with questions of this nature.
Tinstaafl is offline
Old 05-07-2009, 04:18 PM   #3
Professional Instigator
rbsremodeling's Avatar
Liquid Nail, drip cap formula. Find it in home despot, isle 3 caulking section, second shelf
rbsremodeling is offline
The Following User Says Thank You to rbsremodeling For This Useful Post:
ClosetPro (05-07-2009)
Old 05-07-2009, 04:19 PM   #4
Brian (FL)'s Avatar
sorry I'll repost where you suggested
Old 05-07-2009, 04:47 PM   #5
master of none's Avatar
Trade: carpenter
why would any body run gutter hangers through the drip edge....
master of none is offline
Old 05-07-2009, 05:29 PM   #6
Patrick's Avatar
He never said they did
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 05-07-2009, 05:42 PM   #7
nlgutters's Avatar
Trade: seamless gutters
i see it alot
www.nlseamlessgutters.com
nlgutters is offline
Old 05-07-2009, 05:49 PM   #8
So none of you use Liquid nails Drip cap Formula?
Old 05-07-2009, 05:49 PM   #9
Brian (FL)'s Avatar
actually the screw for the bracket goes through the face of the drip cap. These are 6" gutters so I'm not sure how that could have been avoided with the brackets they used but would certainly like to know if it's possible.
Old 05-07-2009, 06:23 PM   #10
It's drip edge, and some one will
answer you at DIY....
http://www.diychatroom.com/
neolitic is offline
Old 05-07-2009, 06:55 PM   #11
Master Baiter
FowlOne's Avatar
Trade: Commercial/Residential Subcontractor
Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. - Ronald Reagan
FowlOne is offline
Old 05-07-2009, 07:46 PM   #12
katoman's Avatar
Trade: carpenter
I'm confused, why would they put eavestroughs across his windows and door? And if all the screws are through the drip cap, how did they get fall?
katoman is offline
Old 05-07-2009, 08:23 PM   #13
Mark
mhillc's Avatar
Trade: carpenter
Just get some PINS and PIN it down
" DO IT RIGHT THE FIRST TIME "
mhillc is offline
Old 05-07-2009, 08:31 PM   #14
Coming out of the closet
ClosetPro's Avatar
Trade: Closet Design-Install-Remodel
That's where they hide the stuff!
ClosetPro is offline
Old 05-07-2009, 09:50 PM   #15
Trade: carpenter
just lift up the first shingle and nail through the starter..... if that doesnt work use the drip cap formula or as a last resort run some lag bolts through it... every 8" should do the trick.
Good luck
Old 05-13-2009, 12:58 AM   #16
JamesKB2's Avatar
Trade: GC Residential / Light Commercial
LOL, wow, I found a new place to be! "Liquid Nails Drip Cap Formula!" I'm seriously laughing and might wake the kids......
JamesKB2 is offline
Advice wanted for starting a construction firm P.J. Construction 34 10-09-2009 02:51 PM
Tile over existing shower surface SK Builders Ceramic & Stone Tile 16 07-06-2009 01:42 AM
drip edge ? wellbuilthome Roofing 67 03-27-2009 07:13 AM
Tying into existing roof Milhaus Framing 9 11-06-2008 12:03 PM
