Trade: carpenter
Need Advice
I have alot of vinyl siding to cut for the latest project. Most of the pieces will be small fillers and was wondering what is the quickest, cleanest way to cut vinyl?
I know I can use shears but i would be there forever. I've heard that you can cut vinyl with a standard framing blade but it sounds like it would shatter to me. Any advice would be greatly appreciated! Merry Christmas! |
Trade: Consultant
Re: Need Advice
Put a plywood blade in your circular saw backwards. That usually works very well, but try it on a test piece to be sure- some of the vinyls are more brittle than others and don't respond well to a sawblade.
Bob |
Re: Need Advice
I usually cut them with shears myself, - - but a slide-miter saw or a small radial-arm saw will cut them fine, as long as it's not too cold outside. I'd probably put a plywood blade in backwards. Maybe someone knows better.
Edit, - - hey, I see Bob beat me to the answer.
http://www.tr-built.com |
Trade: Home/condo renovations
Re: Need Advice
When I've done it, I use an 80 tooth blade on my miter saw, install it backwards, and make sure it's not too cold. The vinly will shatter if it's too cold.
Trade: carpenter
Re: Need Advice
Thanks for the help guys...Go Panthers!
Re: Need Advice
I've seen a saw on jobs, made by Delta, manufactured specifically for cutting vinyl siding. I can't find it on the net. It had a small circular saw (maybe 5-6") mounted on a set of rails, suspended over a table. The whole saw assembly would rotate a great deal, offering miters much greater than 45*. It would probably mitre the angle cuts for against a 4/12 soffit. I wish I could find a picture of that thing. I know it was made specially for vinyl siding, because it had stickers on it to that effect. I know that the crews I've seen using them can fly.
EDIT... I found a picture of one that's really close to the one I was thinking of, but not the same one. Last edited by mdshunk; 12-18-2005 at 01:50 PM. |
Re: Need Advice
Sheesh, md, - - beautiful saw, - - now if he can just get enough jobs cuttin' 3" pieces of siding to warrant buying this behemoth . . .
Actually, - - kinda reminds me of the old Delta 'Saw-Buck', - - I don't think they're available anymore, - - maybe I'm wrong . . .
http://www.tr-built.com Last edited by Tom R; 12-18-2005 at 02:10 PM. |
Re: Need Advice
Here's one that's a little closer to the one I have pictured in my head, but still not the one:
I'm starting to think the one that I've seen used is a 3rd party jig that you mount your own trim type circular saw into. They must sell them somewhere around me, because I've seen more than one crew using one. Last edited by mdshunk; 12-18-2005 at 02:02 PM. |
Trade: carpenter
Re: Need Advice
there is definitly a tool for every job and as a tool geek i want one.....
guess they're using a small blade to keep form shattering the vinyl??? i've got a small tile saw that looks something like that....i wonder..... thanks for the interest! |
Re: Need Advice
I want one, too, - - but don't tell md . . .
Here's a version of the one (they must've copied) that I used to use http://www.hometime.com/Howto/projec..._1.htm#cutting
http://www.tr-built.com Last edited by Tom R; 12-18-2005 at 02:36 PM. |
Trade: General Contracting
Re: Need Advice
i always use a grinder with a large abrasive cutting blade. sometimes i put an abrasive blade in the miter saw. i can get going very fast like that.
Re: Need Advice
Sounds like it would work fine, - - just might involve a little bit of clean-up, no??
Professional Remodeler
Re: Need Advice
Before I bought my Tapco Siding Saw Table I made a table out of a piece of plywood about 18" wide and 8 feet long and four 8 foot 2x4's. I screwed the 2x4's to the plywood on the long axis to make a channel just a hair wider than the siding that I would be cutting, two above the plywood, and two below to stiffen the assembly up when it is sitting on horses. You end up sandwiching the plywood between the pairs of 2x4's. I then took two pieces of 1" angle iron 3 feet long and screwed them across the top 2x4's to make guide rails for the saw, leaving enough sticking out front for the saw to sit in so the blade clears the front of the 2x4. I drilled and countersunk the mounting holes for teh angle iron for drywall screws so the saw wouldn't hit the screwheads, but I suppose you could us roofing nails too.
I also had to tape the blade guard up because it would keep getting caught when I pulled the saw back. Cut a kerf through the 2x4's and about 1/16" deep into the plywood, change blades to a plywood blade put in backwards, and your ready to cut as many pieces as needed. Took me about 45 minutesd to build it. I could also stack 4 or 5 pieces of siding on it at once and cut them all at the same time. Where you mount the angle iron rails will depend on the lengths you need, I sort of centered mine, but moving it would be as easy as moving the angle iron and cutting a new kerf. Also as Griff said, siding doesn't cut well when it's cold, tends to fracture and chip, often sending pieces of sharp shrapnel (sp?) flying |
#14 | |
Trade: Builder, Residential Construction
Re: Need AdviceQuote:
Bought my saw buck back in the late 80's. |
| Self employed guy needs some advice from the Pros to keep things straight... | Luny | Landscaping | 14 | 05-27-2007 12:38 PM |
| occupational advice | steve-o | Electrical | 4 | 08-12-2006 08:36 PM |
| Need Advice on Poly-Urethane Issue | realpurty2 | Construction | 5 | 08-09-2006 11:29 PM |
| excavation advice... | Scratch | Excavation & Site Work | 8 | 04-01-2006 10:44 AM |
| Can anyone give me advice...Georgia | truamerican | Construction | 0 | 02-22-2006 09:24 PM |
