Nasty Smell In Bosch Dishwashers
I have installed quite a few Bosch dishwashers over the years in kitchen remodels ( by far the most popular premium brand in our customer base), and have heard only two comments over the last 6 or 7 years about them retaining a foul smell when the door is opened. Lately I have been seeing quite a few complaints in various appliance related posts about this problem. Has anyone had any customer feedback about this? Thanks.
Old and Tired
Trade: Remodeling and home services
Re: Nasty Smell In Bosch Dishwashers
I have had several odor complaints on dishwashers, bosch isīnt the only brand having this occur. One of my parts suppliers caries a product called Dishwasher Magic. Works like a charm. Kills odors and cleans the dishwasher at the same time. Just take off the cap put it in the dishwasher upside down and run a cycle. You might be able to find it at one of your local Diy stores. Or they might have a web site. All I know it has worked for me
Those who cannot remember the past are condemned to repeat it. |
Adding an air gap or raising the dishwasher drain hose up high in the dishwasher cavity often solves these foul smelling dishwasher issues (sink drain can drizzle a little bit backwards into the dishwasher without that air gap). I don't like the BOSCH dishwashers for the simple fact that they have so little room under them to wire them up.
#4 | |
Re: Nasty Smell In Bosch DishwashersQuote:
I agree with the lack of room for connections, but most of the premiun units that are totally sound enclosed have the same problem, not just the Bosch. And it is not just dishwashers. The factories have all taken a "screw the installer" attitude with their obsession to be able to advertise that their appliance (particulary built in ovens) is 1/10th of a cubic foot larger than the competitors. |
Professional Remodeler
md's right, what usually happens is the drain line is usually hooked to the disposal port, and goes down to the dishwasher, allowing waste water from inside the disposal to drain back into the dishwasher. After a while. it starts to "ferment" in the unit creating the odor. I get several calls a year from this.
The repair is simple, use a rubber-coated hose clamp or PVC conduit strap to get the loop of the drain line inside the sink base as high as possible above the disposal connection, preferably right up under the countertop. Sometimes I have add to the length of the drain line to accomplish this. Once done, I run a short cycle on the dishwasher to flush out the bad water, then let it fill up again, then pour a jar of powdered Tang breakfast drink into the dishwasher and let it run the full cycle. The dishwasher comes out clean and the smell is gone. I then advise the homeowners to run the Tang through it once or twice a year to keep the unit clean.
-Mike- Falcon Contracting Residential - Commercial
#6 | |
The Deck Guy
What a pain in the A. |
Old and Tired
Never even thought about the drain line bring routed low. Around here mos of the drain lines do come into the sink cab at the bottom but the excess line is usually puled into the cab and fastened up high to get it out of the way. It results in it being within an inch so of level with the top of the dishwasher tub. Which is what most of the manufacturers recommend.
The plumbers I know are probably doing it to get out of the way so they don get complaints. I have never seen any of them check the install manual yet
Trade: Appliance Install and Repair
I do a lot of Bosch installs and they made several improvements for the installers a couple years ago.
They now have a junction box that disconnects from the D/W so you can add the wire and strain relief easily. This is all covered in the install manual. Even though I do quite a few installs I try review the install manuals every few months to find if there has been any changes that will help me. |
| bosch scms wobble | Mrmac204 | Tools & Equipment | 3 | 07-26-2007 11:29 PM |
| DeWalt, Bosch, Ridgid | Hurley | Tools & Equipment | 24 | 02-02-2007 09:54 PM |
| The smell of ?? | K2 | Off Topic (Non Trade) | 9 | 12-19-2006 07:17 PM |
| Bosch Router Table | dayspring | Tools & Equipment | 4 | 06-14-2006 10:31 PM |
| Removing Musty Smell | 25BRIAN | General Discussion | 4 | 10-26-2005 12:56 PM |
