My Head Is Spinning....
Old 12-23-2017, 02:39 PM   #1
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 90
I'm finally gonna get a cross-line laser.
50 ft should be fine.
I can't seem to figure out the difference between the Bosch GLL 50, and the GLL 3-15?
Is the 3-15 just the older version?
Delta
I have an Edifice Complex.
Old 12-23-2017, 02:48 PM   #2
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 88
Re: My Head Is Spinning....
3-15 can do a 90 degree on floor and wall. 50 is just on wall.
goneelkn is online now
The Following User Says Thank You to goneelkn For This Useful Post:
Seven-Delta-FortyOne (12-23-2017)
Old 12-23-2017, 02:59 PM   #3
Trade: Builder/GC
Rewards Points: 90
So basically the line "folds" underneath the unit to project a line at a 90 degree angle?
Delta
Old 12-23-2017, 03:00 PM   #4
Dirtywhiteboy's Avatar
Rewards Points: 8,004
Delta
Your head should be spinning Anything worth buying is more than you want to spend.. I'd recommend the Bosch GLL 3-80 or I use the PLS180 the most The GLL 3-80 will give you plumb points and the PLS180 won't. Now the pisser if you don't go green you will be cursing every time it's a bit bright. My next laser will be the PLS180 greenie If you get the Bosch GLL3-80 get the kit that has the magnetic micro adjuster with it and if you get the PLS180 get the kit with the laser catcher with it or you can't use it outside. I don't have a catcher for the GLL3-80 so it's an indoor laser only and the catcher cost about 100 bucks.
My Head Is Spinning....-work-001.jpg   My Head Is Spinning....-img_20171211_141246346.jpg   My Head Is Spinning....-img_3246.jpg   My Head Is Spinning....-img_3247.jpg
Dirtywhiteboy is offline
The Following 2 Users Say Thank You to Dirtywhiteboy For This Useful Post:
fjn (12-23-2017), Seven-Delta-FortyOne (12-23-2017)
Old 12-23-2017, 03:02 PM   #5
goneelkn's Avatar
Rewards Points: 88
there is only a dot that's plumb so you lose the first few inches, but there out it's a 90.
Just got the GLL3-15X. It's great.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 12-23-2017, 03:04 PM   #6
Further more the GLL3-80 is a 360 3 plane laser and the PLS is a 180 2 plane laser, vertical and horizontal.
Old 12-23-2017, 03:07 PM   #7
Trade: Builder/GC
Rewards Points: 90
I like PLS just on principle.
I have a rotary for outdoor use.
I'd love to get a green laser, but they are a little pricey. Maybe I'll just go for it anyway.
My typical scenario is framing a basement, where the floor might be a little out of level. Instead of running stringlines everywhere, I want to mount a laser on the wall at stud height, and measure that way.
Delta
Old 12-23-2017, 03:11 PM   #8
Tom M's Avatar
Rewards Points: 6,028
This will be my second PSL 180 laser I like them. I don't use a tripod but I use the magnetic stand to stick to a lally column or door hinge or task Pole.
Tom M is online now
Old 12-23-2017, 03:12 PM   #9
Radical Basement Dweller
Robie's Avatar
Rewards Points: 10,144
But it from Amazon and use it to see if it fits the bill.
Send it back if it doesn't.
They will send you a free return shipping label.
You have 30 days.
I've only returned a few things over the years and it's as easy as it gets...no hoops.
Democrats are doing more to undermine our country than Russians could ever hope to.
Robie is offline
The Following 2 Users Say Thank You to Robie For This Useful Post:
Old 12-23-2017, 03:16 PM   #10
The green one will be 2nd PLS180 also.. Man I hate to say it but that GLL3-15X is too limited. I just looked it on you-tube. It sucks buying a laser to find out you need one that does more things and be lit me owning 4 lasers and I should have just spent more and got one that does all of that. Check them on the you-tube to get a feel for what they do.
Old 12-23-2017, 03:17 PM   #11
You have 30 days.
THE RETURNER
Old 12-23-2017, 03:21 PM   #12
Delta
Once you have the good laser you will find a lot more things it can be a good use for. I just used the PLS180 to find the low spot in the deck and set all the column collars at the same height, the picket rails will go on the collars.
The Following 3 Users Say Thank You to Dirtywhiteboy For This Useful Post:
asevereid (12-23-2017), fjn (12-23-2017), Seven-Delta-FortyOne (12-23-2017)
Old 12-23-2017, 03:23 PM   #13
Robie's Avatar
Originally Posted by Dirtywhiteboy View Post
THE RETURNER
The blow up doll didn't work....
Robie is offline
Dirtywhiteboy (12-23-2017)
Old 12-23-2017, 03:26 PM   #14
goneelkn's Avatar
Rewards Points: 88
I only have 2
I hear ya tho. That one does what i needed it to do.
Old 12-23-2017, 03:41 PM   #15
Tom M's Avatar
I picked it up a few weeks ago to use up some end of the year cash. They were out of stock on the green one and at more than a $100 higher...... I decided I never felt at a loss for the red.
Tom M is online now
Old 12-23-2017, 03:52 PM   #16
Trade: Builder/GC
Rewards Points: 90
I own zero DeWalt products, but I see that they have a simple cross line laser that is accurate to 1/8" at 100'. That is FAR better than Bosch's 1/8" at 33'.
Is DeWalt still DIY stuff?
DW088K is the one I was looking at.
Delta
Old 12-23-2017, 03:56 PM   #17
Trade: Builder/GC
Rewards Points: 90
Randy, you could probably stock a small hardware store with all the tools you have.
I always know if I have a question about a tool, Dirty probably has one or three of them.
Ever thought about doing reviews or tutorials professionally?
Delta
The Following 2 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
fjn (12-23-2017), Robie (12-23-2017)
Old 12-23-2017, 03:59 PM   #18
Trade: Builder/GC
Rewards Points: 90
You have 30 days.
Hmm...
Didn't know you could return stuff that was open and not defective.
Good idea though. If you can't hold it and look at it before you buy, you should be able to return it.
Delta
Robie (12-23-2017)
Old 12-23-2017, 04:07 PM   #19
Robie's Avatar
Hmm...
Delta
Yeah...as long as you don't damage/abuse it.
I bought the wrong printer cartridges not long ago. I opened both packages and tried to install them and that's when I realized they were wrong. It didn't make any difference. No questions...no problems.
You go back to your order...
Click on "return"
They give you a list of a whole bunch of reasons plus a place you can fill in your own
They immediately email a link to print out the free return label
Repackage it, put the label on and drop it off.
In some cases, I have gotten the credit as soon as the item has been picked up by UPS.
Robie is offline
Old 12-23-2017, 05:13 PM   #20
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 2,962
I like the plumb dots on the PLS4. I can set the laser on a bottom plate and plumb a wall by myself.
I used to have to put a wood clamp on the brace then go over to the wall with a bubble and push or pull, then hope the clamp holds it until I nail. Then go back and recheck it after I nail the brace.
https://www.tigersupplies.com/Produc...PLS60574-.aspx
From what I’ve read green is no better outside and red is fine inside. IOW, Going Green is a waste.
Big Johnson is offline
Makita 18v, Bosch 18v, DeWalt 20v....head to head.... CrpntrFrk Tools & Equipment 469 07-12-2012 08:12 AM
We never actually know what is going through someone elses head. NYCB Off Topic (Non Trade) 11 03-06-2012 08:15 AM
Mueller Power Head WANTED TJT Corp Contractor Swap 2 01-13-2012 04:42 PM
Round head vs clipped head nails Tinstaafl Carpentry 24 12-20-2009 11:54 AM
leaky shower head Sir Plums Alot Plumbing 3 04-07-2009 08:25 PM
