Trade: deks & siding
Mud Jacking
i have a customer with a hole under her patio 14 ft. long about 6" deep is mud jackig a solution? the patio is 15 x 15.
Trade: Squirrel Handler
Re: Mud Jacking
I've had it done a few times with no problems. I think the only issues are what material they pump in, one is supposed to be better than the other, I forgot which one and the other issue is cracking of the concrete.
I saw expanding foam (Great Stuff) to "mud jack" a patio on an episode of This Old House. |
Re: Mud Jacking
Of the people that I've known that have had mud jackers level patios and sidewalks, it seems to me like the results are a crap shoot. Do any of these guys have any sort of guarantee on what the outcome might be?
Re: Mud Jacking
yes but merely to fill the void, I've used an outfit to do this mud jacking aka mud raising, will fill a void or lift a slab.....
but without correcting the drainage its a waste of money & effort.. plus its a small slab
......Less with the jaw & More with the paw..... |
Re: Mud Jacking
I hope this catches concretemasonry 's eye.
if like to see a tech & practical analysis of "mud jacking"
#6 | |
Trade: underground
Re: Mud JackingQuote:
If you merely want to fill the hole, you needn't "jack" anything. If the object is to level the patio, mud jacking may or may not be an effective option;as MD noted, results will vary greatly. The type and condition of the soil as well as the slab's structure play a large part in how useful mudjacking can be. If the slab is way out of level, and the top of the patio can stand being at least 1-1/2" higher, you might consider filling the void bneath the slab and pouring a concrete overlay.
Fortunately I keep my feathers numbered for...for just such an emergency. -Foghorn Leghorn |
DRIFTWOOD
Trade: GEN CONTR.
Re: Mud Jacking
Bust up and out the old slab. 4" compacted base rock, 4" slab w 3/8"
rebar each way. doing one right now |
DRIFTWOOD
Trade: GEN CONTR.
Re: Mud Jacking
Re bar is 16 " on center
Trade: Masonry consultant
Re: Mud Jacking
You can use mudjacking if the hole is under the slab. If it is on the edge, the "mud" would run out unless contained.
A mudjacker could give you an estimate or opinion on the results. Many mudjackers carry a piece of heavy chain that they can use to sound for any other voids.
Dick Engineer, designer and consultant recently active domestically and internationally on construction and design in about 35 countries. |
| Jacking Up A Main Girder | cyberger | Remodeling | 7 | 07-13-2007 10:34 PM |
