Mortar Mix?
Old 01-06-2009, 10:31 PM   #1
rotarex's Avatar
Mortar Mix?
whats a good brand for floors another for shower floors and shower walls
this is my 1st job using mortar in the shower area
something weird happen tho i used HD Flex bond (i forgot which one) and it so happen i laid down the wrong tile so 3 days later i had to tear them off, and to my surprise they came off with ease out of 44 tiles only 4 broke, and i did a wet mix, just so it sticks and was set on Ply wood, not Chip wood, how is this possible
Custom Decks
Custom aquarium all salt water
Renovation
next on my list............planting trees for all those material i used
rotarex is offline
Old 01-06-2009, 11:51 PM   #2
wellbuilthome's Avatar
Trade: building for 30 years. new homes , additions
Re: Mortar Mix?
Tile is a funny thing . Was the tile clean of mud when it popped up .Did the mud come off the floor ? Some times if you don't use the flex bond on porcelain tile it will come off clean . Was it warm in side ? Ive had a problem with HD flex bond , i used some old bags to do part of a job and some areas where louse and had to be redone it was a 25 bag job. ( Large custom bathroom) Its funny i had 3 old bags of mud and had to take up 3 small areas 4' 6"x 4' 6" it was funny three spot and 3 missing bags of old HD mortar. My guys did the job . The tile was a porcelain base with a marble veneer over it like a checker board . I never had any luck with tile on ply wood I always lay 30# felt and wire with a 3/4" mud job or 3/8 scratch coat if the floor is level . If the mud sat to long on the floor and started to dry the tile can pop off . If it was cold it could take longed to cure . I like the tec stuff John
wellbuilthome is offline
Colored Mortar ophnurse Masonry 8 02-14-2009 09:50 PM
Mortar Removal On Aluminum sxdirt Masonry 10 10-10-2008 08:03 AM
1st Row of Bricks on Lentil Dry, In Mortar, or Either? TomBrooklyn Masonry 16 08-30-2008 04:01 PM
Mortar Bedding for Stone on Concrete Question. lukachuki Masonry 10 05-26-2007 10:09 PM
Changing mortar color? kcrossley Masonry 1 12-17-2006 01:44 AM
