Trade: Jack of most
Mold Removal
I was doing some small demo in a room in my basement as I wanted to do something different on the wall. Guess what I found...mold.
It's a lower basement room on the concrete wall side of a walkout. The wall is insulated with a thin foil type batt insulation then it is covered with drywall. The drywall is fine other than the bottom edge which is a little water/mold damaged. But when I pull the insulation back, the material that was in contact with the concrete wall has turned black and is flaking off. Guess I need to find out why it was leaking, but I'd like to know if anyone has removed molding parts themselves? I have the time, just wondering if I'm ok doing it myself. Safety first, but I have heard that a lot of the mold issues have been overblown in this country in terms of deaths. Scare tactics?
MarQ Remodeling (no website) |
Plays Well With Numbers
Trade: Bookkeeper for GC, Residential Const, HVAC & Plumber
Re: Mold Removal
Carl - I am no expert by all means, but I do know that black mold can be toxic. There is also black mold that isn't. One of the guys I bookkeep for (he runs a football league) also works for our state. For the last 1 1/2 years he has been in and out of the hospital, breathing problems, heart racing, sinus problems, tired all the time, bad acid reflux. He was told numerous times he was having a panic attack (which is funny, because he is a felony warrant arrest officer). He was finally referred to a specialist and they found black mold in his bloodstream - which causes a large number of health problems. He is on special meds, etc. (the mold is in the state building his office is in). So my point is - be cautious. It could be the toxic mold and the spores can get all over the place when you disturb the area.
Professional Painter
Trade: Owner/Operator
Re: Mold Removal
I officially nominate Deb as the "mom" of Contractor talk! What a gal
*always has good answers and backs them up....
Rich |
#4 | |
Home Improvement Guy
Trade: Renovations contractor
Re: Mold RemovalQuote:
Don't worry, the baseboard will hide it! |
#5 | |
Trade: contractor
you can try ... but it comes back.... usually best to also find the CAUSE and fix that as well |
Re: Mold Removal
Okay - So I am flattered...
Thank you.But this doesn't have anything to do with me turning 40 in two days... does it??? Like RUBBING SALT IN THE WOUND? Nah - I know you guys wouldn't do that to me. I am having SUCH a good day today! |
Re: Mold Removal
you mean "39" and next year..."39.....39"......"39
Rich |
Re: Mold Removal
40 is the new 22
Trade: Mold Remediator, Decorative Concrete, Bamboo Fencing,
Re: Mold Removal
When you are moving the insulation you are releasing spores into the air which can cause problems. Go on my website so you can get some more information about what you are up against. www.iaqm.com Go to the education page. That will help you out alot. I will tell you that I had a guy get sick for two weeks and we wear all PPE. If you are going to do this yourself be prepared and wear all PPE. You can even bring it into your house after you have been working on the job. Be Careful.
IAQM
www.iaqm.com Elite Concrete Finishing www.eliteconcretefinishing.com Elite Bamboo Products www.elitebambooproducts.com |
Trade: Builder/Remodeler- Master Electrician
Re: Mold Removal
As a certified mold remediation specialist ( I have the card that says so) You will need to pull off the job and tell the customer they have a major problem which will likely cost tens of thousands or at least several?
Or now that the insurance money is gone and the overblown hype has dissipated you can remove it It was big here in Houston and died a quick death when the money dried up. I believe it is much like peanut butter, some can get sick and even die from exposure. I am still surprised they sell peanut butter
www.copusconstruction.com www.etexasrentals.com www.thelakevoice.com AkA Richard Cranium |
#11 | |
Trade: Jack of most
I've also read it the other way around. But mold is in the air we breathe every day. The mold in this room doesn't smell and I think I've been living with it for 4 years now. I just don't want to be the next sucker that pays 3 grand to have a single room demoed.
#12 | |
Trade: Jack of most
Re: Mold Removal |
Re: Mold Removal
When I took the course there were many things that bothered me.
When a remediation was nearing completion and the inspector was due, they told us to keep the door sealed until he is on the porch. Open the door and close it behind him because those mold spores could come in from rotting vegetation/leaves and are outside in the air The second item that bothered me was going throught the procedure they taled about removing sheetrock, treating areas with micrban, hepa vacuuming several time (every square inch). I asked what happened to the mold trapped between the vapor barrier and studs?? He went a little sheepish and responded "well you can't get it all?" It cost us all a lot of money and seemed to me to be primarily bunk. I am sure high concentrations can affect some but find it fascinating how it dominated newspapers and t.v. and as soon as the laws changed (money)...it went away. Maybe the out of work asbestos removal co.s have moved up North to start their new businesses??
Re: Mold Removal
I should add. I was also told (over and over) "It is not the contractors resposibility to diagnose what type of mold is present. Have them call an environmental engineer (like us) when any type of mold is detected!"
Hmmmm. They also explained about the "other" potentially deadly molds It all boiled down to law suits. We had our a/c guy we used for years. Nicknamed him Captain Mold. Every tim we sent him out to service an a/c system he would shut it down and yell mold. Had a lot of pissed off homowners
Trade: Jack of most
Re: Mold Removal
I had a guy in to look at the mold. He was pulling up the carpet to see if there was mold underneath it. There were spots of black mold under the carpet on the edges. He looked in a few places.
What I don't get is why would he do this if he was worried about mold flying all over the place? Nothing was contained and it was dry in there. There must have been a lot of dust created by doing that. He didn't seem too worried. I just get the feeling that this whole setup and negative pressure thing is a scare tactic to rob people of their hard earned money. uhg.
#17 | |
Class A Contractor "BLD"
Trade: Remodeling and home improvements
Looks like some pros were here. |
| Plaster Removal | Mulecreek | Drywall | 8 | 01-16-2007 10:13 AM |
| New Construction Showing Mold... | thepawnshop | Construction | 13 | 10-20-2006 07:43 PM |
| When you find mold?? | theworx | General Discussion | 2 | 03-05-2006 03:15 PM |
| Painting over the mold | Glasshousebltr | Painting & Finish Work | 9 | 11-24-2005 03:11 AM |
