Metal Roof Mobile Home
Old 11-17-2010, 11:08 AM   #1
Superior Firepower
skyhook's Avatar
Trade: GC HVAC/R Lic. since 1985
Rewards Points: 3,880
Question
I've been helping a friend with his Mom's mobile home.
It needs a new roof in the worst way.
It currently has a metal (pretty much flat) roof. I've seen some metal re-roofs but never done one or subbed one out.
Any tips on where to find a reliable roofer (Los Angeles) that specializes in mobile homes and what to ask for ?
skyhook is offline
Old 11-17-2010, 11:17 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Re: Metal Roof Mobile Home
Skyhook, I have had a number of metal roofs (on trailers) replaced & use a .045 Single Ply membrane. Lasts a long time & easily a one day job for a roofer. Maybe Jumbo Jack or BC Franks can help you with a roofer. You're a little too far south for me.
griz is offline
skyhook (11-17-2010)
Old 11-17-2010, 06:09 PM   #3
master hacker of wood
FRAME2FINISH's Avatar
Trade: restoration carpentry
Rewards Points: 1,730
yea what griz is saying i just watched my old mentor do one in a day, the stuff isn't cheap but its the way to go,
he put down foamboard first, and then rolled it over and screwed it off,
the rednecks around here put a polebarn around them lol
FRAME2FINISH is offline
Old 11-17-2010, 07:38 PM   #4
PA woodbutcher's Avatar
Rewards Points: 1,000
Actually the rubber is. My price is under $55 a square. The termination bars and glues are little steep though.
When you rob Peter to pay Paul, chances are pretty good you will receive Paul's vote. Apparently the object of the game is to create more Pauls than Peters....What happens when the Peters can no longer support the Pauls? .
PA woodbutcher is offline
Old 11-18-2010, 07:42 AM   #5
that isn't bad, my rubber that i use is mucho expensivo, the tape alone is 200 a roll, that bill will make ya say what
Old 11-18-2010, 12:10 PM   #6
Superior Firepower
skyhook's Avatar
The rubber or similar would be ok except the existing metal roof is rusted through and no support between the truss.
Some neighbors have framed up and sheated, then put down comp. That's looking like the best option right now. Unfortunately there are some leaks and the forecast for this weekend is rain.
My concern is anything less than solid over the old is probably going to fall through when it gets walked on.
skyhook is offline
Old 11-18-2010, 03:57 PM   #7
is the home ina park and needs to be moveable?????????????? huge question right there, if it can stay i have seen them rim joist around and use trusses and then metal right over that,
if ya plan on making money run if your helping out thats another thing
Old 11-18-2010, 04:33 PM   #8
Superior Firepower
skyhook's Avatar
Not in it to make money this time. Helping out friends and family.
Meeting a guy tomarrow who came highly recommended from a roofing supplier.
If the price is right, my friend will pay him direct.
skyhook is offline
The Following User Says Thank You to skyhook For This Useful Post:
PA woodbutcher (11-18-2010)
Old 11-18-2010, 05:32 PM   #9
knoxwindowdude's Avatar
Trade: window,siding and roofing contractor
Rewards Points: 75
Ther are rednecks up in the 'Cuse?
knoxwindowdude is offline
Old 11-18-2010, 06:14 PM   #10
beleive it ornot there are trailer parks in the cuse haha but the cuse is bigger than you think we have east north south hahaha
Old 11-18-2010, 06:45 PM   #11
Tom Struble's Avatar
Trade: siding
Rewards Points: 4
where is trailer boy anyway?
Tom Struble is offline
essrmo (11-18-2010)
Old 11-18-2010, 06:52 PM   #12
Trailer park boy
shanekw1's Avatar
Rewards Points: 369
You do not want to see what I had to do on the last one of these I did.
Done that. Use scissor trusses. I've also added double plates on top of the walls and set trusses on that.
Done many variations of that.
Lots depends on the type of trailer, how old, what walls are framed with, how codes are locally, snowy area?
Trusses and metal roofing is the way I would lean.
"Industry without art is brutality"
shanekw1 is online now
The Following User Says Thank You to shanekw1 For This Useful Post:
skyhook (11-18-2010)
Old 11-18-2010, 07:22 PM   #13
Trade: siding
Rewards Points: 4
i got plenty of those kinds of jobs too shane
Old 11-18-2010, 07:42 PM   #14
Maxi-Pier Tech
essrmo's Avatar
Trade: foundation specialist
Rewards Points: 810
same here. I see them run 1x4 @ 16"oc, paralell to the lenght (perpendicular to truss),
then rigid foam board insulation and 1 piece .024" aluminum cap fastened to the sides.
we're not in Kansas anymore Toto
essrmo is offline
Old 11-18-2010, 09:23 PM   #15
Trailer park boy
shanekw1's Avatar
Rewards Points: 369
Last one I did for some reason the inspector told the HO that it needed to be engineered.
Dig footings under the exterior walls to 42", 10' OC.
2' x 2' x 12" footing pads with 3 pcs rebar in each direction.
4 j-hook rebar in pad to tie into 4 vertical rebar, tied together every 12" vertically.
12" sono tube.
3 ply 2x12 beam on saddles.
Tom Struble (11-18-2010)
metal roof ruminatre Painting & Finish Work 5 10-15-2010 01:36 PM
sweating under a metal roof roof masters Roofing 7 03-17-2009 10:58 PM
Metal roof question tc70518 Roofing 1 03-12-2009 07:15 PM
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
Metal Roof tied to a Shingle Roof? JackOfAllTrades Roofing 2 11-15-2005 12:00 PM
