Max Trailer Size For Dodge Dakota 4 Cylinder?
Old 09-09-2009, 11:10 PM   #1
ChadTheAnimal's Avatar
Right now the only truck I have is a 2001 4 Cylinder Dodge Dakota. I am purchasing an enclosed trailer and was hoping you would have some suggestions as to the size my truck can handle. I will probably purchase a larger truck in a year or so. My work is mostly remodeling and the trailer would be used mostly for tools. Whenever I have to haul a heavy load, I can borrow a truck or have it delivered. I would guess all my tools and supplies would weigh somewhere between 1,000-1,500 pounds but again that is a guess.
From reading other "trailer size" threads, I believe I would be happiest with a 7x14 but didn't know if I had a little engine that could or couldn't. Also the majority of my driving will be about 10 miles round trip and no major hills.
Any advice is appreciated.
Thanks
ChadTheAnimal is offline
Old 09-09-2009, 11:12 PM   #2
Handle It!
MALCO.New.York's Avatar
Re: Max Trailer Size For Dodge Dakota 4 Cylinder?
A "Lil-Itty-Bitty-One" !!!!
6 Cylinder is as follows:
http://en.allexperts.com/q/Towing-Is...a-towing-1.htm
Ultimate Wisdom---------
MALCO.New.York is online now
Old 09-09-2009, 11:18 PM   #3
curapa's Avatar
Trade: Carpentry / Fencing / Decks
5' x 6' or so...
www.ParkerFenceandDeck.com
curapa is offline
Old 09-09-2009, 11:21 PM   #4
woodchuck2
woodchuck2's Avatar
I used to drive an extra cab Dakota with the 3.9 and 5spd. It was tired iron but ran great, no power at all for towing. I towed my 1600 lb 16' car trailer a couple times empty and it didnt like it. I once put a Honda Accord on the trailer and towed it home "about 1 mile". Problem was i live on a steep hill, the truck chugged over the hill at about 3mph in 1st gear with the gas pedal on the floor. The truck barely pulled the hill. Now yours only has a 4banger? I would say a 4'X8' trailer with a mower or some small tools but i think you will have problems towing any kind of enclosed trailer. The wind resistance is very hard on the tow vehicle to overcome.
woodchuck2 is offline
Old 09-09-2009, 11:25 PM   #5
woodchuck2
woodchuck2's Avatar
Also, i tow a 7'X14' enclosed trailer and beleive me there is alot of wind resistance even with the V-nose. IMO that size is way overkill for your truck, even empty. My trailer is loaded to the gills and weighs alot, this trailer puts a good strain on my diesels. I can tow it at 90mph with no issues and pull like mad in any hill but beleive me, you know its behind you.
Old 09-09-2009, 11:39 PM   #6
Yard Boi
HusqyPro's Avatar
Trade: Landscaping
I'd look for a late 80's or early 90's 3/4 or 1 ton to get you by. If you settle for 2 wheel drive from any of the Big 3 from that era you're looking at $3Kish for something clean and serviceable. Shoot for 87+ to get fuel injection.
As far as your Dakota goes check out those tiny enclosed trailers from Home Depot. They're kind of flimsy, but in your application that's ok. Flimsy is light. At roughly $1K they're essentially disposable.
Bob's Lawn & Landscape
When You Want The Best
Serving the LC Valley & Moscow-Pullman
HusqyPro is offline
Old 09-09-2009, 11:52 PM   #7
Meetre's Avatar
you need a bigger truck. I have a Nissan Xtera that I pull my 7x14 with for camping trips. With a light load the gas mileage drops from 26 mpg to around 12. I won't even hook it up with tools in it, the suspension just won't take that kind of weight. Never mind the fact you want to haul a trailer (around 1800 lbs.) plus your tools (you said around 1250 lbs.) so now you have more weight than the truck behind you, and the laws of physics are against you.
Meetre is offline
Old 09-09-2009, 11:56 PM   #8
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
I have 2 trailers to haul cabinets and everything else under the sun.
The small one is 5x10 that I got at Home Creepo for about $2500. I was driving a v6 Toyota and it did ok but not great.
The bigger one is approx 7x16 and 6" extra tall. Love that thing. Had to get a full size truck for that one. My truck has a towing capacity of #7000. Sometimes I wish it was more but all in all does ok.
The key is payload. How much crap you gonna haul including your own ass. And what is your truck rated at? Manufacturers tend to skew the numbers a bit if you ask me. The whole thing can get complicated if you let it.
A 4 cyl light truck ain't gonna get it done though. You will need a big boy truck to pull a 14' trailer with your stuff. The little truck can't be rated at more that a couple thousand pounds tow capacity. The pay load can't be much more than that. And that trailer empty is more than that. Just guessing on the numbers though. What does the manual say?
Gus Dering is offline
Old 09-10-2009, 12:09 AM   #9
Yeah I guess deep down I already knew it was really just a car posing as a truck. I knew there must have been a reason I couldn't find any pics of dakotas pulling trailers. :-)
As far as the specs go, I couldn't find the manual, but I believe the load capacity was around 3300.
I guess the good news is that is looks like I'll have to be getting that new truck about a year sooner than I thought.
Old 09-10-2009, 12:12 AM   #10
Yard Boi
HusqyPro's Avatar
Trade: Landscaping
Back in the day (way, way back) 3/4 ton trucks and 1 ton trucks had small 4 and 6 cylinder engines. Big inch V-8 didn't come around until the late 60's and diesel in the 80's.
I suppose with low gearing (4.10 or 4.56), air bags to hold the rear end up, a massive radiator, a granny 5 speed, and some other stuff that Dakota could pull a 14,000lb trailer.
Course back in the day those trucks moved at 45mph.
Thank you for taking a ride in the way back machine. Please exit to your right.
HusqyPro is offline
Old 09-10-2009, 12:21 AM   #11
dayexco's Avatar
if all you're doing is a 10 mile radius....you could pull a 8/5 x 20'er.....good electric brakes, not in a hurry...have at it...i wouldn't want to pull it daily 20 miles round trip....but if you take it to a jobsite...let it sit for a week or so, move to next job....that 4 cyl. will surprise you.
dayexco is offline
Old 09-10-2009, 12:26 AM   #12
#1 stunner
Static Design's Avatar
Trade: Design/Build
Send a message via AIM to Static Design
How far are you from KY? I can hook you up on a nice 6x10 enclosed trailer. Google your truck and see what its rated at for towing, take the weight of the trailer plus your tools, if it less then the rated listing then it will be okay.
Will do autocad/ 3d work for food.
SD on facebook... click here
Static Design is offline
Old 09-10-2009, 06:02 AM   #13
KemoSabe
loneframer's Avatar
Make sure you lock out "overdrive" if your an automatic trans, or you will surely burn it up. Dakotas were notorious for that.
loneframer is offline
Old 09-10-2009, 07:52 AM   #14
kubie's Avatar
Trade: general contractor
i had a 97 ranger v6 and pulled a 16' car hauler loaded with wood, walk planks, truss jib, 1/4" steel work platform 12' long and 30" wide that fit on a rough terrain lift truck. i dont know how much it all weighed, but had to be a lot. that truck pulled a lot of weight. all pulled from my bumper
kubie is online now
Old 09-10-2009, 08:19 AM   #15
NNY's Avatar
Trade: contractor
I agree with the buy a bigger truck group . It 's not going to pull much safely for very long . I would go with a used 3/4 plus and keep it for primarily pulling your trailer . You can scoot around doing estimates in your Dakota . Good luck !
NNY is offline
Old 09-10-2009, 08:20 AM   #16
HSConstruction's Avatar
off the bumper?!?
HSConstruction is offline
Old 09-10-2009, 08:34 AM   #17
BCConstruction's Avatar
Trade: Construction
Thanks
Yeah that trailer is prob a good 4000lbs with tools. Take a look at your max load rateings for your truck and take a look to see if your gonna be legal first. Im sure your truck will pull it but it mostly depends on terrain. If your in the flat lands then you will be fine. Def wont be winning any races though. Just make sure you change your truck ASAP as it will be pushing that little 4 banger to it's limit. As long as you aint hitting massive hills or mountains and your within your limits then give it a go.
BCConstruction is offline
Old 09-10-2009, 05:48 PM   #18
kubie's Avatar
Originally Posted by HSConstruction View Post
off the bumper?!?
yup.
crazy. lol
kubie is online now
Old 09-10-2009, 06:08 PM   #19
Trade: Construction
off the bumper?!?
Not sure what the max load of a trailer that size is but my 14 is 7klb fully loaded so i guess a 16 loaded would be about 8klb so not to much for bumper pull. a lot of 1/2 tons are rated at 11k+ pounds so a ranger should be able to do 8klb. Prob not legal but it should be able to pull it.
Old 09-10-2009, 08:09 PM   #20
Handle It!
^^^^ Way too much weight for such a Pup-Truck!!!! ^^^^
Trailer size activepainter Vehicles 27 12-26-2009 10:24 AM
"Wireless" LED Trailer Lights DirtMoverUSMC67 Landscaping 5 10-12-2009 10:19 AM
Trailer Size . gman1985 Tools & Equipment 15 07-17-2009 08:25 PM
Trailer Size Advise Bettercarpentry Vehicles 9 12-16-2008 08:31 PM
2003 Asv rc-30 skid steer with 20' trailer, auger, snow plow, 2 buckets kklick Contractor Swap 0 09-27-2008 07:33 PM
