Low Wire Voltage
Old 06-20-2007, 05:11 PM   #1
mehranalmasi's Avatar
Trade: future home improver
Low Wire Voltage
Hi,
I am upgrading a swimming pool and have noticed a problem with current to one of the pumps.
Basically there are two pumps for the pool. One for filtering and one for the sweeper. The pump connected to the filtering wiring does not run but if I connect the same pump to the sweeper wiring, it works. I could see that both wires going to the filtering pump have power but when I looked closer and compared to the reading on the sweeper wiring, the filtering lines register a bit less current.
They both used to work. So the question is: could a slightly less reading on the voltmeter be the cause? if so how can I find the source of this problem? I have used a sand paper to clean all the contacts between the pump and the switch.
thanks.
Mehran
mehranalmasi is offline
High Voltage vs Low Voltage Lights robertc65 Outdoor Lighting 16 04-04-2011 06:26 AM
Wire balustrades karma_carpentry Decks & Fencing 11 09-17-2007 06:10 PM
Conduit for underground low voltage wire robertc65 Outdoor Lighting 4 01-22-2007 02:52 PM
safe hot wire driver Electrical 13 05-12-2006 11:18 PM
Low voltage wire for sale. casscounty Outdoor Lighting 2 04-30-2006 03:07 PM
