Low Voltage Transformer For Zone Valves.
Old 12-06-2007, 11:03 PM   #1
kiffys's Avatar
Trade: not
I am at a loss as to where to find the low voltage transformers for the zone valves in our building... A 92 suite building built in the early 70 or late 60's. We have looked everywhere and can't find them ... Does nayone have an idea of where to begin looking. They are not in the suites or boiler room or storgae rooms...
kiffys is offline
Old 12-06-2007, 11:38 PM   #2
Fentoozler
Celtic's Avatar
Re: Low Voltage Transformer For Zone Valves.
A real shot in the dark here.....follow the pipes to the valves....follow the wires to the transformer/s.
Celtic is offline
Old 12-06-2007, 11:56 PM   #3
Thom
thom's Avatar
I put them near the valves because it's easier and less confusing later on. Try what Celtic said. They shouldn't be to far from the valves.
thom is online now
Old 12-07-2007, 07:16 AM   #4
Professional Remodeler
firemike's Avatar
They shouldn't be too hard to find, but then.... I have seen them mounted to the wall inside the apartment by a wall recp nearest the valve, mounted to the panel in each apartment, or mounted to a light fixture box in the ceiling/attic.
Might have to start at the t-stat and work your way to it. Possibly mounted to a light/junction box in the basement if it has one? If you know an electrician with a signal tracer, that might help. If you can turn the power off to the T-stat you might be able to use a tone generator like the phone company uses to trace wires.
Do you know if each apartment is seperate, or does one transformer supply several units?
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
High Voltage vs Low Voltage Lights robertc65 Outdoor Lighting 16 04-04-2011 06:26 AM
Buck-Boost transformer adindas Electrical 2 12-06-2007 11:45 AM
Relocating a dry-type transformer Magnettica Electrical Picture Post 18 09-22-2007 04:44 AM
Zone valves and transformers mdshunk HVAC 3 05-13-2007 10:49 PM
Scott-Tee transformer connection JAL Electrical 14 05-09-2006 10:34 PM
