Low Temperature Caulk
Old 11-08-2010, 05:27 PM   #1
bob_cntrctr's Avatar
Trade: property manager & renovator
Gentlemen,
I'm going to be stuck doing some windows closer to Christmas. I nkow they make special low-temperature caulk that you can apply down below freezing for just such applications, but darn if I can find an actual brand/product name online. And my local hardware store doesn't carry any.
Can someone please give me some brand/product names I can go looking for?
Thanks.
bob_cntrctr is offline
Old 11-08-2010, 05:35 PM   #2
Working
Cole82's Avatar
Rewards Points: 2,276
Re: Low Temperature Caulk
Where are you located? Not in your profile.
Are we talking 35deg or -35deg?
Most caulks can be applied down to 40deg.
Cole
The boss of awesome
Cole82 is offline
Old 11-08-2010, 05:43 PM   #3
I'm guessing 15F to 30F by then.
Old 11-08-2010, 05:47 PM   #4
Working
Cole82's Avatar
http://www.tremcosealants.com/filesh...HERproduct.pdf
The boss of awesome
Cole82 is offline
Old 11-08-2010, 05:55 PM   #5
Box Builder
Morning Wood's Avatar
Rewards Points: 8,790
Can sikaflex be used down to that temp? You'd have a hard time getting it out of the tube if it wasn't preheated.
Morning Wood is online now
Old 11-08-2010, 06:17 PM   #6
Wayfarer Doors's Avatar
Trade: windows and doors/ construction supervisor
Rewards Points: 150
I install all year. put an electric heater in your truck(or in a cooler) and keep your caulking warm, put extra tubes in your shirt while caulking . I use mulco brand, which is similar to Tremco, it cures by off-gassing, can use it "any" temp, as long as surface is dry
Wayfarer Doors is offline
Old 11-08-2010, 06:21 PM   #7
jmiller's Avatar
Trade: Roofing
Rewards Points: 1,002
Geocel 2300. Works down to zero F and sticks to moist surfaces.
http://www.geocelusa.com/core/prdb/p...heet_pdf_7.pdf
jmiller is offline
Old 11-08-2010, 06:55 PM   #8
All excellent info that I'll follow up on. Thanks, gents.
Old 11-08-2010, 08:54 PM   #9
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,695
Uh, Bob?
That was a subtle hint.
Tinstaafl is online now
Cole82 (11-08-2010)
Old 11-08-2010, 09:49 PM   #10
skipdow's Avatar
Trade: window and door installer
Rewards Points: 75
we have a heat gun pointed at a case of caulking tipped on its side and pull out a couple tubes at a time, keep them in your jacket to keep it and you warm
skipdow is offline
Old 11-08-2010, 10:53 PM   #11
PREMIER INSUL's Avatar
Trade: Insulation / Custom Carpentry
Rewards Points: 75
Dap 3.0 is good to -35 We used that all last winter without any trouble.
PREMIER INSUL is offline
Old 11-10-2010, 05:26 PM   #12
Tiling & Bath Contractor
TileLady's Avatar
Trade: Tiling & Bathroom Remodeling
Rewards Points: 250
Maybe this would work for you at least to keep it warm before applying?
http://www.caulkwarmer.com/
TileLady is offline
Old 11-10-2010, 07:55 PM   #13
Originally Posted by TileLady View Post
Maybe this would work for you ...http://www.caulkwarmer.com/
"Tile Lady" proposes a caulk-warmer.
You can't make this stuff up.
Old 11-19-2010, 04:51 PM   #14
TileLady's Avatar
Rewards Points: 250
And what is that supposed to mean?
TileLady is offline
Old 11-19-2010, 06:46 PM   #15
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
tile ladys goin to kick your a$$ bob,you just need a nice warm place to keep your caulk in...huh tile lady?
....i'd just like to know how to keep my sealant warm
Tom Struble is offline
Old 11-20-2010, 07:48 PM   #16
TileLady's Avatar
Rewards Points: 250
TileLady is offline
Old 11-20-2010, 07:54 PM   #17
Raawwwrrrr
blackbear's Avatar
Trade: finish carpentry
Rewards Points: 1,394
always keep the caulk warm, cold caulk doesn't come up (the tube that is)
blackbear is offline
The Following User Says Thank You to blackbear For This Useful Post:
Cole82 (11-20-2010)
Old 11-20-2010, 08:53 PM   #18
Jeff
jkfox624's Avatar
Trade: master turd burglar
Rewards Points: 502
jkfox624 is offline
Old 11-20-2010, 09:00 PM   #19
Jeff
jkfox624's Avatar
Rewards Points: 502
+ YouTube Video
jkfox624 is offline
Old 12-02-2010, 07:26 PM   #20
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 6,716
Actually registered for this forum to reply in this thread.
I've been doing a lot of window jobs this past year, winter included, and have been on a quest to find the perfect caulk.
So far, I have to agree with Premier and give my vote to the Dap 3.0 Unfortunately though, the Dap is crazy expensive. Something in the neighborhood of 5 to 6 dollars a tube, if you can find a good deal. Titebond also makes an all weather caulk which is also "green" if that's how you get your kicks. It's almost 2 dollars cheaper per tube than the Dap, but it's murder on the hands to apply. You actually have to heat it(room temperature does not cut it) to get it to flow with any kind of ease. If you're installing any more than 5 windows your hands will be killing you from squeezing this stuff out of the tubes.
I hate to be contrary in my very first post on here, but everyone who is suggesting simply heating caulk before applying it is not taking into account that regular caulk applied in freezing conditions will most definitely harden and crack. If you think you can seal your window exteriors with regular painter's caulk in 15 degree weather then mister, you have a rude awakening ahead of you when your customer calls you to tell you that all that caulk you applied froze, cracked, then fell out the very next day.
If anybody else has any other suggestions for sub zero caulks that are cheaper than 5 bucks a tube, please please please speak up! I'm always on the hunt!
Easy Gibson is online now
Whats a good caulk gun for concrete epoxy? Project_Pat Tools & Equipment 18 01-02-2012 06:42 PM
Primer Cracking over Caulk go_hercules Painting & Finish Work 11 01-19-2011 07:39 PM
To Caulk or not Caulk. HandyHails Tiling 11 03-10-2009 06:45 PM
Window U-Value Home Serve Windows, Siding and Doors 73 11-16-2008 09:45 AM
Condensation Help Patrick Windows, Siding and Doors 10 03-16-2007 08:40 AM
