Low Cost Grab Bar Installation
Old 09-29-2009, 05:33 PM   #1
Remodeler21's Avatar
Trade: LIcensed, Certified Building Contractor in Florida
Good afternoon guys,
I've designed and built several really nice ADA bathrooms this year. Very happy clients. No problem installig grab bars because we put 2x10's, 2x8's, 2x12s between the studs, behind the drywall and/or tile.
I've encountered a situation where I'd like to help someone who doesn't have much $ but really needs some grab bars installed. I've seen lots of sites which advertise anchors. I've put it a zillion toggle bolts, molly bolts, and other anchors over the years.
Can a few of you relate your experience with Moen anchors, or other brands of this newer type hardware, to secure grab bars where you know there isn't much of anything else in the wall between the studs?
This is a big guy and I'd rather tell him we'll just need to find him some financing so we can tear out his shower and do it over, rather than have him get hurt by grabing a grab bar and having it pull out or pull out with a chunk of drywall attached. Don't want him to get hurt, he's got enough medical problems already.
Remodeler21 is offline
Old 09-29-2009, 05:34 PM   #2
solar guy
naptown CR's Avatar
Trade: solar contracting
Rewards Points: 1,000
Re: Low Cost Grab Bar Installation
Theere are custom manufacturers that willl make a grab bar to attach to the studs in your particular situation More expensive but cheaper than tearing out tile.
naptown CR is offline
The Following User Says Thank You to naptown CR For This Useful Post:
Remodeler21 (09-30-2009)
Old 09-29-2009, 05:37 PM   #3
Project Manager
CookeCarpentry's Avatar
Trade: Project Manager
Rewards Points: 2,016
You could get a custom sized grab bar made.
Or if you can locate the studs you can use a standard size and mount on a slight angle to hit two studs.
CookeCarpentry is offline
The Following User Says Thank You to CookeCarpentry For This Useful Post:
Old 09-29-2009, 07:40 PM   #4
Home Builders/Contractors
Metrojoebarbs's Avatar
Trade: Residential Home Builder/Contractor
Rewards Points: 250
I agree here...
Metrojoebarbs is offline
The Following 2 Users Say Thank You to Metrojoebarbs For This Useful Post:
CookeCarpentry (09-29-2009), Remodeler21 (09-30-2009)
Old 09-29-2009, 07:44 PM   #5
paul100's Avatar
Rewards Points: 40
If you have access to the back side of the shower, can you cut an opening in the back side and add blocking, then patch the wall. It would be cheaper then redoing the shower.
paul100 is offline
The Following User Says Thank You to paul100 For This Useful Post:
Old 09-29-2009, 07:49 PM   #6
BLDG Inspector, G.C
spdtrx's Avatar
Trade: BLDG Inspector, G.C
Rewards Points: 150
Originally Posted by Metrojoebarbs View Post
I agree here...
Great Ideas Guys.
spdtrx is offline
The Following User Says Thank You to spdtrx For This Useful Post:
Old 09-29-2009, 10:53 PM   #7
Rewards Points: 2,000
You could look into these.
I only weigh 180, but I have stood
on them and bounced.
They are the only hollow wall
anchors I trust for this.
http://www.wingits.com/
neolitic is offline
The Following User Says Thank You to neolitic For This Useful Post:
Old 09-29-2009, 11:02 PM   #8
Professional Instigator
rbsremodeling's Avatar
The low cost grab bars are in the same aisle as the low cost Shower light..
Ask mike where they keep the shower lights at
rbsremodeling is offline
The Following 2 Users Say Thank You to rbsremodeling For This Useful Post:
Magnettica (10-01-2009), Remodeler21 (09-30-2009)
Old 09-29-2009, 11:03 PM   #9
paul100's Avatar
Rewards Points: 40
I used thier commercial ones (GBW40) on my house and they feltjust as strong as going into studs. only thing is that my house has wire lath and mortor for the tile so I am not sure how they would be on concrete board.
paul100 is offline
Old 09-29-2009, 11:21 PM   #10
willworkforbeer's Avatar
Trade: home remodeling
Why not cut the sheetrock/or whatever on the other side of the shower? Sheetrock repair isnt that big of a deal. No matter what anchor, sheetrock is sheetrock, put in wood. Do it right.
willworkforbeer is offline
The Following User Says Thank You to willworkforbeer For This Useful Post:
Old 09-30-2009, 07:38 AM   #11
Thanks guys for taking your time. We'll check out a few of the ideas. You guys are great.
Old 09-30-2009, 08:07 AM   #12
jtpro's Avatar
Trade: Construction Assistant Superintendant/Remodeler
Those look pretty badass!
jtpro is offline
Old 09-30-2009, 10:01 AM   #13
What if it's brick veneer?
Sometimes it just seems best
not to let the perfect be the enemy
of the good.
I have mostly used them where
folks were currently using the "handle"
on the ceramic soap dish as a grab bar.
neolitic is offline
Remodeler21 (10-01-2009)
Old 09-30-2009, 10:15 AM   #14
genecarp's Avatar
If its a tight budget job, get a nice piece of 5/4x4x24''. secure it to the wall into framing, then mount the bar to that. G
genecarp is offline
Old 09-30-2009, 05:15 PM   #15
Fentoozler
Celtic's Avatar
Probably of no help, but I have this:
14. Grab Bars
Recommended:
Plan grab bars to facilitate access to and maneuvering within the tub and shower areas.
Tub and shower walls should be prepared (reinforced) at time of construction to allow for installation of grab bars to support a static load of 300 lbs.
Grab bars should be placed at least 33"-36" above the floor.
Grab bars must be 1 & 1/4" to 1 & 1/2" in diameter and extend 1 & 1/2" from the wall.
Now you have it.
Here is some other stuff:
http://starcraftcustombuilders.com/b...sign.rules.htm
Celtic is offline
Old 09-30-2009, 05:42 PM   #16
14. Grab Bars
Recommended:
Now you have it.
Next time I get an 85 year old
guy, living in his 1963 tract house
who's just had his leg amputated,
I'll show him that!
neolitic is offline
Old 09-30-2009, 05:54 PM   #17
Fentoozler
Celtic's Avatar
I'll show him that!
I'm guessing you had no idea I am a fountain of useless information
Celtic is offline
Old 09-30-2009, 06:17 PM   #18
I have been accused of drinking
from the same fountain.
neolitic is offline
Old 09-30-2009, 06:29 PM   #19
Fentoozler
Celtic's Avatar
Celtic is offline
Old 10-01-2009, 07:17 AM   #20
I'll show him that!
Neolitic, You hit almost directly on it: the guy is retired, he IS living in his tract house and if he doen't get off his feet, his diabetes may require amputation in the future.
I'm going to try the wingits.
I LOVE YOUR QUOTE about not letting perfect win the war over good. God, I wish I'd said that one. That's a struggle I've been engaged in for most of my career and even before. (Probably need counseling )
If, however, I ever have a pastry question I'm asking Celtic.
Cost of Geothermal Units orson HVAC 40 07-27-2016 01:47 AM
Practical GREEN ideas that don't cost much, part 1. wackman General Discussion 24 03-15-2010 07:52 PM
"actual cost of materials" ChainsawCharlie General Discussion 10 06-30-2009 05:03 PM
Cost Based Bidding Vs Spreadsheet sitegrader Excavation & Site Work 1 02-04-2009 10:44 PM
Alright businessmen ... I'm gonna give it one more try ... breakin even dirt diggler Business 30 02-27-2007 12:34 PM
