Looking For A Failsafe Rust Removal Product For Concrete
Old 02-18-2009, 10:46 PM   #1
NJ Kevin's Avatar
Trade: Paiting and PowerWashing
Any one out there have any suggestions for a rust removal product that will work without any fuss. Condo complex has badly stained walkways from sprinklers gone wild. Lots of area, don't want to scrub. Thanks in advance.
NJ Kevin is offline
Old 02-18-2009, 10:54 PM   #2
Resta's Avatar
Trade: Ornamental Plasterer/Restorer
Re: Looking For A Failsafe Rust Removal Product For Concrete
Muriatic acid HCl(H2O). Can use acid-proof brush and wash with a lot of water.
Resta is offline
Old 02-18-2009, 11:15 PM   #3
mickeyco's Avatar
Trade: Squirrel Handler
Maybe a robot with a scrub brush and a bottle of CLR.
mickeyco is offline
Old 02-19-2009, 01:32 AM   #4
simplejack's Avatar
Trade: General
CLR and some illegals elbow grease.
simplejack is offline
Old 02-19-2009, 08:09 AM   #5
Burritos
bamawildcat's Avatar
Trade: Lectrical
Behr makes a concrete rust stain remover. It is basically Muriatic acid as Resta recommended.
bamawildcat is offline
Old 02-19-2009, 11:33 PM   #6
Hardly Working's Avatar
I 2nd the Muriatic acid if that doesn't work go with sandblasting with a soft media. Go and sub it out and take your 20%.
Hardly Working is offline
Old 02-20-2009, 01:26 AM   #7
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
If there is landscaping close by, nix the muriatic acid idea.
Rent a Hotsie, won't be 100% but a good start, than sell them on acid staining or a concrete overlay.
Chris
Chris Johnson is online now
Old 02-20-2009, 06:14 PM   #8
Tscarborough's Avatar
The only failsafe way to remove rust stains from concrete is with a wrecking ball.
Tscarborough is online now
Old 02-20-2009, 10:55 PM   #9
fireguy's Avatar
Trade: Fire Suppression Equipment Sales & Service
Ask at TheGrimeScene.com
fireguy is offline
Old 02-20-2009, 11:28 PM   #10
MarkmillerConst's Avatar
Trade: General Contractor, AutoCad Design, Carpentry
Acid won't work. All it does is dissolve the concrete,and your sinuses!
If you scrub it with a wire brush, it will make the stain worse by eating the brush and adding to the mess. Also if you use it strong, the acid alone will stain the concrete brown.
MarkmillerConst is offline
paintstripping and rust removal furiousstyles Painting & Finish Work 1 05-19-2006 10:05 PM
