Laminate Flooring In A Travel Trailer??
Old 08-11-2009, 03:07 PM   #1
rservices's Avatar
Rewards Points: 364
This guy called me wanting to know if I could install Laminate flooring in a travel trailer. It sounds like I could has any one else done this.
He's think wood, or that faux tile
rservices is offline
Old 08-11-2009, 04:24 PM   #2
Mitch M's Avatar
Rewards Points: 250
Re: Laminate Flooring In A Travel Trailer??
I don't see why you cannot. I heard the story of a local restaurant owner had that or hardwoods installed in his RV. The good thing with laminate is that it floats. However, you have to be careful about the trailer flexing. You might want to put in a disclaimer since it is supposed to be on stable firm floors.
Mitch M is offline
Old 08-11-2009, 04:56 PM   #3
HSConstruction's Avatar
Rewards Points: 250
you could nail it down to keep it from moving while driving
I would say this seems like a reasonable request, but add a brake light gar-un-tee.
It sounds much easier than my customer who wanted a bath reno in a motor home, I turned that one down.
HSConstruction is offline
Old 08-11-2009, 05:29 PM   #4
Money Changer
bert0168's Avatar
Trade: Residential Remodeling
I actually saw pictures from another forum where a guy did just that.
Looked pretty good when he was done.
I'd say do it!
bert0168 is offline
Old 08-11-2009, 07:53 PM   #5
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
Rewards Points: 2,000
Surprise, surprise. My brother-in-law asked me the same thing today. Gonna' do it this weekend.
Cdat is offline
Old 08-11-2009, 08:06 PM   #6
#1 Handyman's Avatar
Trade: handyman do all
Rewards Points: 157
I think It would do well.
Freedom to float around would be a good thing.
Nailing would probably cause it to buckle. Just like on like vinyl siding that had the nails driven home.
If you do want to anchor it some, I would choose the center board That way all can expand and contract out toward the sides and there would be no stress to cause buckling.
#1 Handyman is offline
Old 08-11-2009, 08:49 PM   #7
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,002
Can, and has been done. Follow the manufacturers instructions to the letter concerning expansion space and there should be no issues. I have installed quite a bit in motor homes through the years, can't recall a single issue.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 08-11-2009, 08:50 PM   #8
Paul
Umm No.
Precision Floors
(772) 237-9900
Old 08-11-2009, 09:11 PM   #9
Rewards Points: 157
Originally Posted by PrecisionFloors View Post
Umm No.
I have done it once on a floor that was installed incorrectly in that three buts were in three rows very close to each other and it caused the whole floor to lift up in the center. I just finished nailed them down pneumatically. They stayed down and the floor was free to expand all around. Never caused another problem.
Old 08-11-2009, 10:04 PM   #10
jtpro's Avatar
Trade: Construction Assistant Superintendant/Remodeler
Would a motor home have less frame flex than a travel trailer?
or in your opinion is that not so much a prob?
I was going to do my van(same application as a motor home I would guess) at one time but hesitated.
jtpro is offline
Old 08-11-2009, 10:18 PM   #11
finaltouchfloor's Avatar
Trade: Flooring & Remodeling
Rewards Points: 75
I installed a laminite is a boat. Add a little titebond on the small planks at the ends. Leave at least 1/4 " at edges for swelling . If theres any dips in sub-floor over 1/4 fill will Mapai Tri-patch leveler or plani-patch.
finaltouchfloor is offline
Old 08-11-2009, 10:37 PM   #12
Paul
In my opinion, in order for there to be enough deflection in the sub floor to be an issue for laminate, you've got bigger problems to worry about, like cabinets and wall partitions coming loose. A well built, in sound shape travel trailer shouldn't be an issue imo. A rickety, 40 year old, frame rusted, p.o.s.....meh not so much
Precision Floors
(772) 237-9900
Old 08-11-2009, 10:41 PM   #13
Paul
Three end joints close together wouldn't cause tenting in a floating floor. Lack of proper expansion does. All you did was force the problem to move somewhere else. Remember, just because you don't get a call back, it doesn't mean you did it right and there were no other problems... Not pickin on ya...just sayin.
Precision Floors
(772) 237-9900
Old 08-11-2009, 10:42 PM   #14
jtpro's Avatar
Gotcha! THANX!
jtpro is offline
Old 08-11-2009, 11:11 PM   #15
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
I dont know a whole lot about flooring but i dont see why you couldnt. Alot of the higher end travel trailers and motor homes have these types of floors, hell some of them even have tiled floors and baths.
woodchuck2 is offline
Old 08-12-2009, 12:47 AM   #16
Yard Boi
HusqyPro's Avatar
Trade: Landscaping
Rewards Points: 250
Would excessive heat damage the flooring? The inside of a parked vehicle can reach 130+ degrees in the sun. Would that cause the adhesive to fail? Would that cause the floor to buckle? Most houses are climate controlled and don't reach those temperatures. What about freezing in the winter? Can laminate flooring suffer distress from temperature extremes?
Bob's Lawn & Landscape
When You Want The Best
Serving the LC Valley & Moscow-Pullman
HusqyPro is offline
Old 08-12-2009, 05:38 AM   #17
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
When my in-law asked me, I drove to the dealership, went in the lot and looked at the newest highend models, found one that matched what he wanted done and started peeling back trim and carpet to see how it was done. It can be done because the newer models have it.
Now, as long as that dealer dosen't read this post, I should be safe. It's easy to pull stuff up and back to peer underneath but that stuff just don't go back to it's original shape when you're done.
Cdat is offline
Old 08-12-2009, 05:40 AM   #18
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
People around these parts take really good care of their 5th wheels and motor homes. They park 'em inside pole barns or keep 'em in climate controlled conditions. You kind of have to, if you only use 'em once or twice a year.
Cdat is offline
laminate flooring placement nwksremodeler Flooring 7 06-19-2009 09:24 AM
Air Bubbles under laminate flooring Ugo Flooring 13 04-07-2009 09:12 PM
Laminate flooring lifting up. combuilder Flooring 5 02-18-2009 07:14 AM
What to charge to pull up 325sqf of Laminate flooring?? TileMan77 Flooring 3 07-17-2008 07:57 PM
