Trade: drywall
Knockdown Ceilings?
can anyone tell me how to apply a knockdown ceiling?
Trade: Builder/Remodeler- Master Electrician
Re: Knockdown Ceilings?
You may want to try the paint section on this.
Are you referring to the stomp, where you apply with a brush and lightly trowel off the tips or Spray with a hopper and joint compound? Spraying with the hopper requires playing with the mixture to find the desired spray pattern. Do not use your own compressor. Rent a unit made for this if you do not have one.
www.copusconstruction.com www.etexasrentals.com www.thelakevoice.com AkA Richard Cranium |
Drywall finisher
Trade: Drywall
A sledgehammer!
Knockdown is easy once you get the hang of it. Mix some mud very thin, I like it a little thinner than bazooka mud, but not too thin it's better to have it a little thicker. Just spray it on to desired pattern. The trick is to start to wipe it down at just the right time, too early and it's a real mess, too late and you really don't get the knockdown effect. I like to use a 22" knockdown knife, it looks like a squeege. You can get them on allwall.com. If you use a real light touch you can start wiping it down early so that you can do larger areas. I use my own compressor all the time with the pressure turned down to about 60psi, and largest diameter hole on hopper. I hope this helps, and good luck.
"I hate to tell you this, but you're a man. You're going to spend your life gettin' up one more time than you get knocked down." John Wayne |
| machine brocade on ceilings | camas-mud-man | Drywall | 0 | 06-28-2007 01:00 PM |
| 9 foot ceilings or 8 foot ceilings with treys? | williefb | General Discussion | 1 | 02-11-2007 01:29 PM |
| Best way to smooth wall over knockdown texture | dforeid | Drywall | 10 | 02-01-2007 07:36 AM |
| knockdown ceilings? | contractor131 | Drywall | 5 | 10-11-2006 11:39 PM |
| Just ceilings | Flying Colours | Painting & Finish Work | 5 | 11-10-2005 09:02 PM |
