Knee Wall Insulation ?
Old 10-07-2006, 01:54 PM   #1
baspinall's Avatar
Trade: Telecommunications Cabling
I posted this ? in the HVAC area but didn't get any suggestions. So I thought I would try here seeing as I am doing this today. Thanks
I have a cape cod with the infamous knee walls. This house ate me alive last winter in heat.
My ? is. If I insulate the roof side with R-38 w/ craft paper, can I sandwich it with 1" ridgid foam? Will the craft paper create moisture between the ridgid foam board? I do have a ridge vent and holes in the soffit. I also added the ventilation baffles in between the rafters, wich I will seal at the soffit end of the bays(does that make sense).
TIA - Brian
baspinall is offline
Old 10-07-2006, 07:21 PM   #2
unlicensed hack
maj's Avatar
Trade: wood butcher
Re: Knee Wall Insulation ?
Go for it, sounds good to me, as long as you make sure you have uninterupted ventilation from soffit to ridge.
The views expressed in this post are merely opinions of named poster and in no way shall be deemed meaningful by members of the herd. By no means does anything posted by named poster mean a damn thing for anyone else partaking in this thread.
maj is offline
Load bearing wall or not??? BMAN Remodeling 26 07-28-2008 07:16 PM
Backyard office, retaining, and privacy wall Team Scream Masonry 8 08-02-2007 11:27 PM
Roof sagging wall pushed out christy Roofing 5 10-14-2006 09:53 PM
Knee wall Insulation ? baspinall HVAC 0 10-07-2006 10:39 AM
