Trade: pro
Kingfisher
i realize that pella and anderson are more expensive windows but is the labor more expensive than a good vinyl replacement?
is 200 bucks a window for labor only a good price;what is the going rate and also 900 for the bay? thanks buddy. |
Re: Kingfisher
Yes the labour to install a better window should be the better installers. Also the higher end windows are expected to open and close better than the cheap stuff but that means you relly need to take your time and do it perfect. I have installed 2 bay windows with a helper each time, 1 went in in 2 hours and the other took 5 hours and was a giant cluster. The floor was off the walls were off and I hed to attach eveything then check change just a huge mess. Both of these were high end wood windows, 1 was a pella, $900 is a little high but that is everything right? and these are on the first floor or realy close not 5' off the grade?
Trade: pro
Re: Kingfisher
so a pella replacement is about 250 per window including capping? lets say a 33x54 window? whereas a regular vinyl replacement is about 200?
a bay window to remove and install should be closer to 800 then? thansk buddy. a appreciate it |
Trade: Roofing Contractor
Re: Kingfisher
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs. Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/ We apologize for any inconvenience that this may have caused. This thread has been closed. |
| Best Miter Saw | CertifiedFunds | Finish Carpentry | 14 | 10-12-2007 12:48 AM |
