Interesting Chimney
Old 11-06-2009, 12:19 AM   #21
CharlesD's Avatar
Trade: Remodeling/building
Re: Interesting Chimney
I've seen chiminys like this on a lot of houses. I thought it was an accepted procedure.
CharlesD is offline
Old 11-06-2009, 12:20 AM   #22
DarrenB's Avatar
Trade: VA Contractor (bathrooms)
That is called a sloped offset chimney.
Very common years ago.
One thing you have to worry about is cracking where the slope starts, cracks commonly form presenting a fire and gas hazard.
DarrenB is offline
Old 11-06-2009, 01:22 PM   #23
Tscarborough's Avatar
It will reduce the draft, but I don't think that is why they did it.
Tscarborough is offline
Old 11-06-2009, 01:26 PM   #24
JonM's Avatar
I've seen quite a few like that here in New England..quite common in the turn of the century three story houses...
JonM is offline
Old 11-06-2009, 02:39 PM   #25
DavidC
DavidC's Avatar
How is it that it affects the draft? Inquiring minds want to know.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 11-06-2009, 03:54 PM   #26
Old House Mechanic
RenaissanceR's Avatar
Trade: Antique & Victorian Home Restoration Services
[deleted]
Renaissance Restorations LLC
www.renaissancerestorations.com
Last edited by RenaissanceR; 04-22-2011 at 11:38 PM. Reason: per advise of attorney
RenaissanceR is offline
The Following User Says Thank You to RenaissanceR For This Useful Post:
bonz (11-08-2009)
Old 11-06-2009, 04:00 PM   #27
s.kelly's Avatar
Trade: electrician
wow, twisted!
s.kelly is offline
Old 11-06-2009, 04:09 PM   #28
stuart45's Avatar
Trade: Brickwork
Originally Posted by RenaissanceR View Post
Found this chimney while bidding on a proposal on a house built in 1830. The chimney was "twisted" to clear the roof line and a staircase I was told.
That is an interesting one.
It used to be thought that a flue needed to travel at least its own width to reduce any downdraught and increase the draw. We were taught this at college as can be seen from these old drawings.
Nowadays a straight flue is said to be more efficient.
How much would you charge to rebuild these 4?
stuart45 is offline
The Following 5 Users Say Thank You to stuart45 For This Useful Post:
DavidC (11-06-2009), DJ9222 (11-07-2009), neolitic (11-06-2009), rselectric1 (11-06-2009), Tinstaafl (11-06-2009)
Old 11-06-2009, 05:31 PM   #29
rselectric1's Avatar
Yours wins!
rselectric1 is offline
Old 11-06-2009, 06:42 PM   #30
Don't Eat Yellow Snow!
English Roofer's Avatar
Trade: Pro Slater and Roofer
Ive only ever seen an offset chimney built in to a gable wall end, seen lots of twisted chimneys, great to look at but a bugger to re-point!
Cheers
' I can resist anything but temptation' Oscar Wilde
www.drroofing.co.uk
English Roofer is offline
Old 11-06-2009, 07:01 PM   #31
On a recent job, the chimney in the first photo was going to get repointed till we took the slates off the lower roof to discover they had taken the chimney breast (flue) out below it and it was being held up by a timber batten!!(photo 2)
Cheers
P.S. we took it down....carefully!
www.drroofing.co.uk
Old 11-06-2009, 07:28 PM   #32
How in the heck did you fix that one?
Old 11-07-2009, 06:46 PM   #33
stuart45's Avatar
Trade: Brickwork
Taking the chimney breast out and leaving the stack suspended is quite common in the UK. It was done a lot in the 70's when everyone wanted central heating and open fires went out of fashion. It's OK if the stack if supported with gallows brackets in the roof space, but many aren't sometimes with deadly consequences. Here is another typical example.
stuart45 is offline
Old 11-07-2009, 06:54 PM   #34
My fascination and respect for what good masons can do is growing with every post!
Old 11-07-2009, 09:12 PM   #35
Al Smith
A W Smith's Avatar
Ive seen plenty of offset chimneys like in the opening post. Usually they are laid up against a pair of 2X4's to prevent them from falling over while the mortar is still wet. The 2X4's are usually left in place.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 11-07-2009, 09:35 PM   #36
KentWhitten's Avatar
The chimney in our house starting in the basement is on top of a massive arch system. It has two flues from there that are on either side of the staircase, then merge above the stairs to come out the top in only one spot.
Salmon Falls Cabinetry
KentWhitten is offline
Old 11-08-2009, 12:40 AM   #37
General Contractor
bonz's Avatar
Interesting Thread...
Is the verdict in as to why this was done?
I have seen this in several historic homes we have renovated. Always figured it was to have the chimney offset from the ridge (specially because the offset occurred only in the attic)...
But, after seeing a couple homes where the chimney runs straight thru the ridge, I am wondering if there may be some other reason...
Thanks,
Bonz
bonz is offline
Old 11-08-2009, 01:07 AM   #38
solar guy
naptown CR's Avatar
Trade: solar contracting
I think the poster who saw the hip roof was on track
naptown CR is offline
Old 11-08-2009, 09:11 AM   #39
We took the chimney down as it was to dangerous to leave like it was!
Cheers
www.drroofing.co.uk
Old 11-08-2009, 09:15 AM   #40
I came across these chimneys on a job in Liverpool, thought they looked rather nice!
I think a chimney can come through a roof where ever but the pots need to be about a metre above the ridge line to stop down draft!
Cheers
www.drroofing.co.uk
Chimney pipe help bsp General Discussion 8 10-23-2009 01:20 PM
crazy chimney idea? Michaeljp86 General Discussion 5 10-01-2009 10:19 AM
Clearance problem for chimney GregWCIL Masonry 3 07-07-2009 10:54 PM
Dangerous Chimney Dilemna The Boss Masonry 27 04-25-2009 09:35 PM
Metal chimney replacement trade Construction 5 04-06-2009 01:35 PM
