Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Contractors Talk Forums > General Discussion
Old 11-05-2009, 07:31 PM   #1
rselectric1's Avatar
Interesting Chimney
I don't know if these photos will show up because I am having trouble attaching them, but if they do, great.
I discovered this in an attic today.
If the photos post alright, I'll provide more detail.
interesting-chimney-img00022-20091105-1332.jpg   interesting-chimney-img00023-20091105-1332.jpg   interesting-chimney-img00024-20091105-1333.jpg
rselectric1 is online now   Reply With Quote
Old 11-05-2009, 07:32 PM   #2
Illusion of Perfection
CookeCarpentry's Avatar
Trade: Residential Remodeler/Custom Carpenter
Mark
Wayne, PA
"It is what it is."
CookeCarpentry is offline   Reply With Quote
Old 11-05-2009, 07:33 PM   #3
God Bless America
Magnettica's Avatar
Trade: Electrician
I wouldn't try snaking up wires that way... that's for sure.
Classic Electric LLC
Repairs, Renovations, Rehabilitation
Magnettica is offline   Reply With Quote
Old 11-05-2009, 07:33 PM   #4
Hey it worked. Angus had to give me tech support.
When I saw this I didn't know whether to be awed or apalled. An HVAC guy on site said they did it to cut down on draft ??????????????
It looks to me like the masons had to offset the chimney when it was discovered the it was headed directly for the ridge.
Any comments?
The Following User Says Thank You to rselectric1 For This Useful Post:
angus242 (11-05-2009)
Old 11-05-2009, 07:47 PM   #5
Jeff
Trade: home builder/remolder
We see this all the time in the turn of the century homes around here. I always figured the same thing they came up in the middle of the house and gave it an oh when they got into the attic. But then again i see alot of chimneys come up dead nuts in the middle of the ridge.
jkfox624 is online now   Reply With Quote
The Following User Says Thank You to jkfox624 For This Useful Post:
genecarp (11-05-2009)
Old 11-05-2009, 07:57 PM   #6
Trade: interior trim
You'll want to save that picture!
Start a collection of 'nobody will believe it unless they see it' pix.
mikeswoods is offline   Reply With Quote
The Following User Says Thank You to mikeswoods For This Useful Post:
rselectric1 (11-05-2009)
Old 11-05-2009, 08:00 PM   #7
It's a pretty old house-probably newer than turn of the century by a little bit.
The chimney comes out through the roof exactly adjacent to the ridge. No ridge board, obviously no cricket, but it seems to have held up well for now.
Old 11-05-2009, 08:01 PM   #8
Trade: Framing
It is not unusual AROUND HERE EITHER
Framer53 is offline   Reply With Quote
Old 11-05-2009, 08:01 PM   #9
Trade: General Remodeling Contractor
I beleive that's called "FlexBrick".
eisert is offline   Reply With Quote
Old 11-05-2009, 08:12 PM   #10
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Thats where the Jack Daniels consumption exceeded the brick layed amount because the tender couldn't keep up.
Once they went above the second floor the poor guy just couldn't keep material on the boards.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline   Reply With Quote
Old 11-05-2009, 08:15 PM   #11
I'll look for ancient JD bottles in the insulation tomorrow
Old 11-05-2009, 08:19 PM   #12
What are you doing up there anyway, Ron?
Mark
Wayne, PA
"It is what it is."
Old 11-05-2009, 08:27 PM   #13
I'm sleeping one off
Actually it's a very small bath remodel and I was tracing wiring.
Is that OK with you?
CookeCarpentry (11-05-2009)
Old 11-05-2009, 08:39 PM   #14
Trade: Siding, Metal Roofs, and whatever to pay the bills
Yes turn of the century THIS ONE. BAHAHAAA
Looks like modern day mesican "brother in law" work to me. A good mesican woulda thew up chicken wire and a scratch coat of stucco to hold it together, but never came back to 2nd coat or finish it
Red Adobe is offline   Reply With Quote
Old 11-05-2009, 08:48 PM   #15
Jeff
A little off topic but dont you love goin in those old attics seeing 2 x 4's on 2' centers and like a 20' rafter length. Then you drill through the roof to cut a boot in and find 1" boards, shakes, then 4 layers of asphalt. Its like wtf keeps this thing from turning into a pile of kindling in the basement.
Old 11-05-2009, 08:49 PM   #16
Trade: Carpenter/GC
That one is a bit extreme but they off set it so there would be solid framing for the hip roof.
With a gable roof you can split the ridge no problem. With hips you have lateral pressure coming from all four sides.
Aframe is online now   Reply With Quote
Old 11-05-2009, 09:14 PM   #17
Tscarborough's Avatar
Trade: masonry
As long it is less than 30 degrees it is all good (from a draft standpoint, structurally, good luck with that).
Tscarborough is offline   Reply With Quote
Old 11-05-2009, 09:30 PM   #18
Our work has nothing to do with the chimney. I just happened to notice it. I think it does actually fall within 30 degrees.
I was just baffled by the draft comment by the HVAC guy. I thought he was full of s***. Was he? It was hard to tell by your post.
Old 11-05-2009, 09:45 PM   #19
DavidC
DavidC's Avatar
In our parts that is a very common chimney for an older house. As to why, I have no idea. I don't see how it would effect the draft so I would lean to accommodating the framing.
Good Luck
OK, rant if you must. For the love of Pete, use paragraphs and spell check.
DavidC is offline   Reply With Quote
The Following User Says Thank You to DavidC For This Useful Post:
Old 11-06-2009, 12:07 AM   #20
jarvis design's Avatar
Ha Ha, you did the same thing I did when I saw my first loopy chimney!!
I had a bricklayer buddy come and look at it - he explained it was supposed to be like that!!
Seen quite a few since
Do it Right the First Time....or someone else will!!
www.JarvisDesignBuild.ca
jarvis design is offline   Reply With Quote
Chimney pipe help bsp General Discussion 8 10-23-2009 12:20 PM
crazy chimney idea? Michaeljp86 General Discussion 5 10-01-2009 09:19 AM
Clearance problem for chimney GregWCIL Masonry 3 07-07-2009 09:54 PM
Dangerous Chimney Dilemna The Boss Masonry 27 04-25-2009 08:35 PM
Metal chimney replacement trade Construction 5 04-06-2009 12:35 PM
