Trade: owner/operator
Installing 6 X 6 Posts 8ft Above Grade
going to install some 6 x 6 posts in the ground and going to cement in the ground 4ft below the grade to hold up a scoreboard for a golf course 4ft in height by 16ft in length anyone know what the proper length of how much of the post should be below grade?
Service & Repairs
Trade: Electrician
Re: Installing 6 X 6 Posts 8ft Above Grade
What the frost level out there in Port Jeff?
3ft
Why are you going to use concrete?...use ground contact PT lumber, not the stuff you buy at the box store. Put the posts in 36" and tamp it as you fill the hole.
We have done some pole buildings and we were told not to cement the pole either because the wood shrinks and then water can get trapped between the cement and wood and accelerates the rot even though it is treated. We used gravel and packed it worked great.
The Deck Guy
I think you are pissing into the wind. Why?
Because I installed a scoreboard (smaller) yesterday as a matter of fact. It needs to be engineered unless you don't care about someone getting killed when the wind blows it over. Look: http://picasaweb.google.com/FineHome...eat=directlink Note the BIG STEEL BEAMS. Note the REALLY DEEP HOLE. Note the BIGGEST SONOTUBES YOU EVER SAW. Note the WELDED REBAR CAGES. Take it for what it's worth, but don't plead ignorance.
| The Following User Says Thank You to Greg Di For This Useful Post: | Five Star (04-30-2009) |
I like Green things
Holy Crap Greg, what a pain.
By the way, was that jimmy hoffa in that hole? |
Service & Repairs
Trade: Electrician
Damn, that's some set up.
Hoffa was buried at Giants Stadium everyone knows that. |
#9 | |
Handle It!
Re: Installing 6 X 6 Posts 8ft Above GradeQuote:
Doin' it and doin' so one can sleep without EVER thinkin' about it!!!
woodchuck2
Nice job Greg
Trade: Construction
Yea, a scoreboard is a giant parachute, get a good wind and an improperly designed sign, your gonna have a show.
Make sure its designed right |
Trade: renovator
Depends on what you mean by "6 x 6 posts 8ft above grade ...going to install some 6 x 6 posts in the ground and going to cement in the ground 4ft below the grade to hold up a scoreboard for a golf course 4ft in height by 16ft in length " - that's kind of convoluted.
If you mean the top of the posts, and therfore the top of the scoreboard, are 8ft above grade, then I'd point out that everyday guys on this board erect 8-foot tall and 30, 40, 50-foot wide scoreboards on 4x4 posts sunk 4-feet into the ground every 8-feet apart - they're called fences, and they stand just fine. But if the bottom of the scoreboard is 8-feet off the ground, and the board is 4-ft by 16-ft, that's a whole other ball game. Now you've got a 12-foot moment arm. |
| The Following User Says Thank You to bob_cntrctr For This Useful Post: | TimelessQuality (05-01-2009) |
Trade: GC/Remodeling
The moment would be 10'... Good Point!
-Steve "The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein |
posts are gonna be 6 x 6 acq post cements into the ground in 12 inch forms with 1/2 inch rebar installed into the cement, a total of 4 posts with the top of the posts being 8ft off the grade, it will be 3 sections 2 - 4ft, and 8ft in the middle with the 2 ends being at a 22 degree angle off the center panel
| Block up to grade, or pour concrete to grade?? | ruskent | Masonry | 8 | 11-30-2008 11:31 PM |
| Utility Grade Junk? | J-Peffer | Flooring | 0 | 10-07-2008 04:49 PM |
| How To - Finding New Posts | Nathan | Contractor Talk Tutorials - How To Use This Site | 12 | 05-09-2008 12:59 AM |
| Installing chain link line posts | Tim C. | Decks & Fencing | 10 | 01-06-2008 04:24 PM |
