Ice Guards For Metal Roof
Old 11-09-2006, 12:34 PM   #1
Chimney Monkey's Avatar
Trade: Chimney & flue sweeping, maintenance and repair for over 30 years
Hi! I'm looking for recommendations for ice guards for metal roof.
4/12 pitch in Kentucky. Usually only a couple inches of snow or 1/2" of ice, but have had 20" of snow. Metal or polycarbinate? Spacing?
Method of fastening? Snow splitters for metal chimneys?
Thanx,
Jeff
Chimney Monkey is offline
Old 11-09-2006, 08:11 PM   #2
sheeter
sheeter's Avatar
Trade: architectural metal panel systems, curtainwall
Re: Ice Guards For Metal Roof
There are numerous products on the market now. Some have brackets which connect to the standing seams to hold a bar that runs the length of the eave. Some simply get glued to the panels using an adhesive based silicone, like "Everseal". The cost varies and the copeasthetics isn't so great. But what I can tell you is that you want to stagger the placement about 10" to 12" up from the bottom. Do a web search for "Metal Archtecture" magazine. I always see them advertised in it but I don't have a copy handy to give you more specifics.
Sheeter
"It's hard to be humble when your good"
sheeter is offline
Old 06-18-2010, 09:07 AM   #3
copper magnet
seeyou's Avatar
Trade: custom metal fabrication
Thanx,
Jeff
What type of metal roof? Hidden or exposed fastener?
If possible, I'd avoid the stick on type, but that option may disappear if it's an exposed fastener roof. You need a material that's compatible with the roof material. I'm assuming painted steel, but you could be dealing with aluminum or copper.
seeyou is offline
Old 06-18-2010, 09:09 AM   #4
copper magnet
seeyou's Avatar
Sheeter
That's "you're" .
seeyou is offline
Old 06-21-2010, 08:40 AM   #5
woodchuck2
woodchuck2's Avatar
http://www.amerimax.com/catalog/pdfs/pgs%2088-89.pdf , i would contact the supplier and see what they recommend.
woodchuck2 is offline
Old 06-22-2010, 04:55 AM   #6
Custom Coils's Avatar
Trade: Coil Contrator
I think you should ask to a professional people to solve your problem.. They can give you better advices than any other can..
Custom Coils
Custom Coils is offline
Old 06-22-2010, 06:43 AM   #7
Tom Struble's Avatar
Trade: siding
yea...we gotta get more professionals for better advices here
Tom Struble is offline
Old 06-22-2010, 07:55 AM   #8
copper magnet
seeyou's Avatar
Of you that's not very professional advices for having to help today
seeyou is offline
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 10:54 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
