I Beam ....or Another Alternative
Old 03-14-2008, 11:26 AM   #1
bkcm111's Avatar
Trade: professional
Hi,
I am remodeling a kitchen and a great design is being held back by a single vertical beam supporting the attic above (it is a ranch house) I want to get rid of the vertical beam and extend the ibeam another 10 -12 ft. What kind of Ibeam should I use? Is there an alternative to a steal IBeam? The full lenth of the new ibeam will be appox 22 ft.
I never replaced a ibeam before, but understend that I need to make a supporting wall on both sides of the beam, before removing the ibeam. The I beam that is up there now is a wooden one, consisting of two 2X12" beams. I want to make the beam smaller in size, but longer in length.
How hard is it to do this job? And what type of I beam would you sugest?
Please help.....this delaying the kitchen project.
bkcm111 is offline
Old 03-14-2008, 11:36 AM   #2
Thom
thom's Avatar
Re: I Beam ....or Another Alternative
Professional is not a trade
beams are not vertical
I think you have the wrong forum
thom is offline
Old 03-14-2008, 11:39 AM   #3
PacNWStructures's Avatar
Trade: Framing, remodeling, new construction
I second that. Vertical beam?
PacNWStructures is offline
Old 03-14-2008, 11:44 AM   #4
bkcm111's Avatar
Trade: professional
I meant to say vertical post that is holding up the I beam. I want to take the post away, but would need a stronger I Beam.
bkcm111 is offline
Old 03-14-2008, 11:51 AM   #5
Thom
thom's Avatar
You need an engineer.
Answering your question is really impossible without a lot more information. The real issue is, you don't understand the physics of what's going on. Even if we asked all the questions to get the answers to engineer this thing, there is no reason to believe we would not have missed something really important by not actually looking at the job.
The fact that you didn't consider the horizontal loads makes it clear you don't understand what's going on. The fact that you believe the answer can be derived from knowing the length makes it clear you don't understand what's going on. Screwing up on a beam can bring down a building and can kill people.
Beyond that, this requires real engineering and a real engineers seal. You could do it with software but that would require the training to use the software.
So, in short, you need an engineer.
thom is offline
Old 03-14-2008, 12:30 PM   #6
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & welding
Send a message via AIM to Michaeljp86
Not only would you need a stronger beam you would need stronger supports on each end of the beam. Then you need to look at whats under the verticle beams supporting you new I beam. You cant just have 2 4x4s sitting ontop of your floor holding up a 22' I beam with 5000lbs on top of it. You can easliy need to look all the way to the foundation. There would be alot of engineering in something like this. This isnt a ricks handman service job.
I am just a vessel from which genius flows -Homer Simpson
Global warming is a myth, like evolution and the metric system.
U.S. Coast Guard
Michaeljp86 is offline
Old 03-14-2008, 03:32 PM   #7
Restoration Crazy
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Send a message via Skype™ to Jason Whipple
This sounds like a perfect example of what I caution prospective customers about. You hire someone with less experience because they are less in price, it will come back to haunt you. In the end, poor planing and lack of experience will drive the cost up and will delay progress.
Sounds like you're in it up to you're waist now! How could you start this project without dealing with this issue first? If you're really the contractor and not the H/O, you're about to make a name for yourself on this one. Buy the way expect to spend at least a grand on an engineer to solve this for you, not to mention the fact that you have no idea what the proper fix is so how did you price it
I'm sure the H/O's wont be offended when you ask for another 2-3k
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 03-14-2008, 04:18 PM   #8
gregj's Avatar
Originally Posted by Jason W View Post
How could you start this project without dealing with this issue first? :
Hey, he's learning. In his previous post back in 10/2006 he pulled out his ceiling joists before asking the proper way to put in a cathedral ceiling. This time he asked before removing anything.
gregj is offline
Old 03-14-2008, 05:02 PM   #9
BuiltByMAC's Avatar
Trade: Construction
Quoted from one of his earlier posts -
Thank you for your imput.....
Yes the run is 9' 6", with appox 12'5" rafters. The guys that I have hired seem to be tearing out everything. I am concerned about proper support! I am sure that you way is the correct way, but would a few collar beams connecting the rafters also give proper support? At this momemt in time, I am concern to let these guys cut into my roof rafters.
Kill the thread and let the HO post in DIYChatroom.com
BuiltByMAC is offline
Old 03-14-2008, 05:33 PM   #10
Ed the Roofer's Avatar
Trade: Roofing Contractor
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Ed the Roofer is offline
Steel beam replacement BHI Carpentry 17 02-28-2008 12:03 AM
need some advice framing to a beam Vabuilder Framing 23 02-22-2008 04:41 PM
Updating main beam in century-home: end. bob_cntrctr Framing 8 02-07-2008 04:04 PM
Beam Specs ophnurse Framing 19 10-02-2007 08:21 AM
deck beam sizing and post spacing? diyerforever Decks & Fencing 5 05-10-2006 10:58 PM
