How To On Striker Plates
Old 05-29-2007, 08:54 PM   #21
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: How To On Striker Plates
Looks good! When it comes to production, jigs and routers make the world go round, I've even seen them cut windows out of those walls they frame and sheath in factory built homes!
Mike Finley is offline
Old 05-29-2007, 09:46 PM   #22
go do it's Avatar
Trade: general contracting
i surrender
the router wins
i just like using a cheisel
probably goes back to my first carpenter job as a trim carpenter's helper
i still remember that house
go do it is offline
Old 05-29-2007, 10:11 PM   #23
Tom R's Avatar
You done us proud, framerman!!
P.S. if they needed more perfection on that little rounded corner, - - you could have drilled the corner with the proper size bit (1/4" maybe??), - - and then still used your corner chisel, - - but backwards . . .
Tom R is offline
Old 05-31-2007, 02:42 PM   #24
troubleseeker's Avatar
I use the little PC plastic jig mentioned . It is easy to use, accommodates most configurations of strikes, and inexpensive. When working on jambs where I did not want to leave the two small nail holes that result from securing it with the brads, I have used it it size the cutout on a longer piece of material that I could hold in place with a couple of clamps(Exact configuration varies according to the style of trim)
troubleseeker is offline
Hey Jersey guys! K2 Framing 15 04-19-2007 11:26 PM
Laser level for top plates on partition walls? personalt Framing 3 11-12-2006 09:58 AM
Square up sill plates jaymay75 Framing 24 09-13-2006 01:51 PM
Framing Partition walls in existing home... sootybuttercup Framing 2 11-11-2004 01:22 PM
