How To Repair Stucco Dent?
Old 06-08-2010, 09:43 PM   #1
Chris G's Avatar
Trade: Porch and Deck Builder
Rewards Points: 1,210
Happens.....
One of my guys dented the stucco in the pic. Any thoughts on how to fix? I have the colour of the stucco to match.
I can not emphasize how stupid I really am
http://www.vicporch.ca
Chris G is offline
Old 06-09-2010, 05:16 PM   #2
Chris G's Avatar
Re: How To Repair Stucco Dent?
Just a gentle bump.
Chris G is offline
Old 06-09-2010, 05:27 PM   #3
DREAM1's Avatar
Trade: G/C
Rewards Points: 25
clean it out filler up and hope you can match the old.
DREAM1 is offline
Old 06-09-2010, 06:07 PM   #4
Flag ship's Avatar
Trade: general contractor
Rewards Points: 150
Originally Posted by Chris G View Post
Happens.....
I assume this is a remodeling project. See if the owner has the color blend if not my 2nd choice would be to fill it with motor or even thin set works well use a spunge float for texture and paint the wall. The color match is easy if you pull the chip that is still hanging in the pic
Flag ship is offline
Old 06-09-2010, 06:52 PM   #5
Resta's Avatar
Trade: Ornamental Plasterer/Restorer
Rewards Points: 1,028
Mechanically clean all loose stucco, wipe dust out, moisten, mix white mortar, fill dent with knife/spatula, match surface texture with brush, check after few hours, math and blend new texture with old. Let it dry. Paint with round brush. No strokes, paint with straight touch. Thus dot dot dot dotted...Let it dry and dot dot dot again....
Resta is offline
Old 06-09-2010, 06:56 PM   #6
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
That looks more like an EIFS product to me. If it is, I'd be careful about using a Portland based product to patch.
loneframer is offline
Old 06-09-2010, 08:48 PM   #7
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Hire a stucco guy, that's what they do.
No offense but if you have to ask refer to the above.
griz is offline
Old 06-09-2010, 09:01 PM   #8
SamM's Avatar
Trade: Carpenter/Handyman
Rewards Points: 1,484
My usual method: Tape it off tight to the hole, Use a knife or corckscrew to pull the stucco out closer to the surface, jam some LE foam in behind to keep it out, fill, float, remove tape and feather it out with a dry paintbrush.
Keep in mind, you want the stuff pulled out so that you're not trying to fill a deep hole. Otherwise it'll slump. And you don't want it too far out, otherwise you'll have a bump.
If you have any crack lines left when you're done you can color them with the finish. put a little finish in a tshirt (clean) or cheesecloth kinda material, and gently tap he cloth against the crack to get a little of the finish color out, but not the sand.
It can be kinda tricky, and if you're not careful you can mess the wall up pretty good.
Good luck.
Edit: That looks like it's right on the corner. If thats the case I'd reccomend hiring a pro.
Your Dreams won't work unless you do.
SamM is offline
Old 06-09-2010, 09:03 PM   #9
Flag ship's Avatar
Rewards Points: 150
What is your concern with portland base patch? Back in the day when these product started they were often appliyed over portland base coats. and for that matter foundation walls. Granted the products are in 2 different spectrums.
Just a question not challenge of your ability?
Old 06-09-2010, 09:14 PM   #10
SamM's Avatar
As I understand it, sticking portland in the hole may cause cracking. The portland will expand and contract at a different rate than the foam/finish or the rest of the wall.
SamM is offline
Old 06-09-2010, 09:25 PM   #11
Red Adobe's Avatar
Trade: Metal Roofs, Sparky , Remodels and beer specialist
Rewards Points: 92
I love the ZOOM ON firefox.
Thats definently EIFS and alot of expirence applying and repairing the stuff over the years and I'll tell you even if you had the original finish in a bucket you will always see a repair. I did alot of eifs back in the day and can tell you finish in a bucket will not always match applied walls even 6 months later.
With that being said I'd look at a decorative medalions (coining) or lighting aproach. In other words add something unique and astetic right there since a repair will stick out like a sore thumb and be noticible.
Red Adobe is offline
Old 06-09-2010, 09:56 PM   #12
Dan
ApgarNJ's Avatar
Rewards Points: 2,000
Send a message via AIM to ApgarNJ
he can take the color as it is today and have it matched. I have that EIFS thread going where we did some rot repair behind the foam on a larger section, about 32"x9' high and we are matching the existing EIFS as it is today, not as it was put on in the early 90s.
he should be able to do the same here, just costly as I doubt you can just get a small batch mixed up.
you may have to blend it out a bit. might still looked patched as it looks like you aren't in a small area where it would blend in easier.
ApgarNJ is offline
Old 06-09-2010, 10:36 PM   #13
KemoSabe
loneframer's Avatar
As someone above stated, there may be an issue of differences in expansion, but I'd be just as concerned with trying to make the texture match.
I've seen buildings done with a Dri-Vit top coat over a Portland based brown coat and it looks great. One thing I did notice though, it has a tendancy to spider crack on the topcoat over time. Still in all, I think it's a better application than EIFS, in my opinion.
Old 06-10-2010, 06:45 AM   #14
Flag ship's Avatar
Rewards Points: 150
Thank You
I veiw the system the same way. 2 brown and top is i.mo. a true finish. And this dent wouldn't be.
Old 06-10-2010, 10:35 AM   #15
Chris G's Avatar
I'll just hire someone. I was kind of looking froward to giving it a go actually.
Chris G is offline
Old 06-10-2010, 07:26 PM   #16
Chris G's Avatar
FYI, yes it's EIFS. The dent is about 1" dia. Here's a closer look.
BTW, why don't they install this stuff with corner bead like drywall? Not that it would have helped in this case, but it's pretty fragile at the corners don't you think?
Chris G is offline
Stucco repair around replacement window bcbuilder32 Masonry 3 02-10-2010 09:20 AM
Stucco Repair? andrew07 Masonry 12 09-15-2009 09:57 PM
I lost a stucco repair repaint to a roofing Company Frankawitz Drywall 23 09-02-2009 04:24 PM
Stucco Repair & Paint - ellevation problem NAV Painting & Finish Work 10 06-16-2009 05:34 PM
Stucco Brick repair jas179 Masonry 6 10-19-2008 07:34 AM
