How To Prevent Exterior Door Jambs From Rotting?
Old 07-17-2017, 01:26 AM   #1
3bar's Avatar
Trade: carpenter
Rewards Points: 416
i had to replace an 8 year old (i installed new) exterior steel door with wood jamb today because the jamb was completely rotted on the bottom. some rot on top brick moulding even. and even the door panel itself looked swelled on the bottom. this door doesnt see sun, so perhaps it stays wetter longer....menards mastercraft door by the way. not buying these again
anyways i see a lot of wood exterior door jams rotting on less than 10 year old homes.
what can i do to prevent rot without having to go with more expensive composite jambs?
on the door install today, i removed the threshold and painted the bottom frame edges. not sure if this will help.
is it better to caulk the frame to the aluminum threshold, or will that trap moisture?
3bar is offline
Old 07-17-2017, 01:51 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Re: How To Prevent Exterior Door Jambs From Rotting?
you may have to make your own jambs out of a more weather resistant material.
Seal & paint properly and keep the water off of them.
griz is offline
Old 07-17-2017, 01:54 AM   #3
sefiroxx's Avatar
Trade: remodel/handy
Rewards Points: 100
Mtg typically requires 3' overhang as part of the warranty. Rain splash from a lack of gutters, overflowing gutters etc create moisture problems.
The door supplier I just makes a custom jamb with the bottom 8-12" a moisture composite.
Before installing jambs, brick moldings, be sure to paint all sides and edges with paint or water proof material. The caulk everything well. Most rot comes from water being wicked up the edge or through paint cracks caused when shoes, wheels etc hit the jamb/molding
Sent from my XT1053 using Tapatalk
sefiroxx is online now
Old 07-17-2017, 02:07 AM   #4
3bar's Avatar
Trade: carpenter
Rewards Points: 416
why cant jambs be made of treated lumber?
but i guess door manufacturers like the fact you'll be buying a new door down the road....disposable society..
3bar is offline
Old 07-17-2017, 02:32 AM   #5
sefiroxx's Avatar
Rewards Points: 100
Pressure treated used chemicals that gassed off - and thus were not allowed on interiors
Old 07-17-2017, 08:49 AM   #6
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 296
Probably dryer climate here , but I wrap mine then caulk the bottom seems to work well. Also for around a $100 or so more can install one with an extruded aluminum jambs.
Randy Bush is online now
Old 07-17-2017, 09:02 AM   #7
avenge's Avatar
Rewards Points: 2,562
If you want longevity spend more money. I always use PVC brick mould and composite jambs.
avenge is offline
The Following 4 Users Say Thank You to avenge For This Useful Post:
Canmannc (07-28-2017), dutchroots2 (07-17-2017), hdavis (07-17-2017), Workingmanvan (07-31-2017)
Old 07-17-2017, 10:20 AM   #8
hdavis's Avatar
Rewards Points: 3,443
Treated lumber has been used for these and windows for a LONG time. It just isn't CCA or ACQ. It just takes a fungicide, and there are plenty of fungicides for interior use.
Most jambs with this problem have a cut end that allows the water to wick up the wood. I've seen them start rot in 2 years, even with full sun South East exposure. Painting over does nothing except give you prettier rotted wood.
hdavis is offline
greg24k (07-17-2017)
Old 07-17-2017, 10:36 AM   #9
General Contractor
greg24k's Avatar
Rewards Points: 7,018
Therma thru and other companies make rot-resistant jambs with rot-resistant Alaskan Yellow Cyprus finger jointed to the bottom of each jamb leg to protect the jamb where itís most vulnerable to moisture. They also make composite brick-mold.
greg24k is online now
The Following 4 Users Say Thank You to greg24k For This Useful Post:
hdavis (07-17-2017), overanalyze (07-24-2017), SouthonBeach (07-18-2017), Workingmanvan (07-31-2017)
Old 07-17-2017, 10:48 AM   #10
hdavis's Avatar
That's a big clue - all the untreated pine ones I see rot up to the glued finger joint, and the rot stops there.
hdavis is offline
Old 07-17-2017, 10:50 AM   #11
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,096
Yellow cedar.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 07-17-2017, 11:06 AM   #12
hdavis's Avatar
I've never seen a really old jamb sealed on the backside, plus they had a lot of air leakage.
Prime4s, caulk the bottom to keep water out (really, it just traps water that runs down the door), make sure your gasketing keeps air flow to a minimum - it's pretty much a perfect recipe for rot.
Put a storm door over it all, and you can use almost any jamb.
hdavis is offline
Old 07-17-2017, 11:38 AM   #13
General Contractor
greg24k's Avatar
Originally Posted by WarnerConstInc. View Post
Yellow cedar.
Therma Tru show in their specs "primed Pine with rot-resistant Alaskan Yellow Cyprus finger jointed to the bottom of each jamb leg to protect the jamb"
Old 07-17-2017, 11:45 AM   #14
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 7,244
Yellow cedar.
Same difference is what he's saying...
http://nativeplantspnw.com/alaska-ye...-nootkatensis/
Net Zero Energy Is Here Now
ďThe worst day working for yourself, is still better than the best day working for someone else!Ē
..Jim Rohn
SmallTownGuy is online now
Old 07-17-2017, 01:02 PM   #15
I like Green things
Plus it's spelled cyress.
Warner Mill Works
Facebook
YouTube
Old 07-17-2017, 02:04 PM   #16
RichVT's Avatar
Rewards Points: 439
I've used frames with a composite bottom. http://www.enduraproducts.com/produc...ew/framesaver/
The problem with them is that the composite section is really short and the finger joint between the composite and the wood opens up over time.
I now only use solid PVC frames. They are more flexible so I shim in a few extra spots.
RichVT is offline
Old 07-17-2017, 02:45 PM   #17
Dirtywhiteboy's Avatar
Rewards Points: 7,584
Not here ,, we use PT trim all the time. Some comes PT and pre primed.
Dirtywhiteboy is offline
The Following 2 Users Say Thank You to Dirtywhiteboy For This Useful Post:
Old 07-17-2017, 03:02 PM   #18
General Contractor
greg24k's Avatar
I just copied and paste... If it makes that much difference to you, contact Therma Tru and ask them to run a spell checker on their website Here is the link to save you some trouble.
Old 07-17-2017, 03:07 PM   #19
I think it's 2 different trees,,,,
Old 07-17-2017, 03:11 PM   #20
I like Green things
They are made 20 minutes from me, in a white trash stronghold town, so that's to be expected.
Warner Mill Works
Facebook
YouTube
How do I prevent stripping screws in door jambs?` Obi Wan Cannoli Windows, Siding and Doors 38 09-11-2015 10:29 PM
Latest ways to prevent cigarette smoke passing through ducts? bob_cntrctr HVAC 13 04-04-2013 11:29 PM
Why is wood rotting ? SKC Construction 44 07-23-2012 03:06 AM
Top 10 framing errors - and how to prevent them (From a Professional Builder Email) wallmaxx Framing 9 02-20-2012 07:57 PM
Wood lap siding rotting behind electrical meter base AdRog Windows, Siding and Doors 17 09-27-2011 09:49 PM
