How Much Does A Lift Of Plywood Weigh?
Old 03-18-2012, 10:14 PM   #1
Box Builder
Morning Wood's Avatar
Rewards Points: 8,790
Let's say 1/2" cdx. Or a better question- how many sheets of 1/2", 5/8", 3/4" are in a lift of ply?
Morning Wood is offline
Old 03-18-2012, 10:34 PM   #2
Commercial Contractor
Mud Master's Avatar
Trade: Commercial General Contractor
Rewards Points: 1,000
Re: How Much Does A Lift Of Plywood Weigh?
I believe there are roughly 48 sheets in a lift of 1/2", depending on manufacture can be as much as 52, and one supplier does units of 75.
A sheet of 4x8 1/2" is about 50 pounds, so a lift/unit would weigh roughly 2400lbs. If you get a lift of 75 it would be closer to 3750lbs. All A-C.
I've never seen a lift/unit of 3/4 be anymore than 50.
Again, it depends on the manufacturer. A lift/unit of 4x8 HDO for forming I get 66 sheets a lift.
Originally Posted by katoman View Post
And when the day is done, I can look myself in the mirror, with pride, and say " you're a craftsman, well done. "
Mud Master is offline
The war of plywood VS particle board Jimmy Cabinet Kitchens & Baths 47 09-18-2012 07:52 AM
Why can't I put plywood over bare concrete in my basement? shanekw1 Flooring 19 01-26-2012 12:40 AM
Painting exterior plywood wall sheathing hiphi45 Painting & Finish Work 4 12-23-2011 01:11 PM
Biljax 5533a (60') towable aerial lift arbor pro Contractor Swap 9 03-25-2011 08:03 AM
Plywood vs particle board CarrPainting Roofing 27 07-14-2010 11:14 AM
