How To Measure Soffit And Fascia Off Of Plans?
Old 02-01-2010, 02:57 PM   #1
Mitch.Parker's Avatar
Trade: Millwork/ Siding
Can anyone help me on different ways to do this?
Mitch.Parker is offline
Old 02-01-2010, 03:00 PM   #2
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,704
Re: How To Measure Soffit And Fascia Off Of Plans?
Just add it all up
knucklehead is offline
Old 02-01-2010, 03:01 PM   #3
Framer53's Avatar
Trade: Handyman
Rewards Points: 320
Scale it
Framer53 is offline
Old 02-01-2010, 03:03 PM   #4
just add the lineal up? or do you think buying one of those measuring pens would be easier?
Old 02-01-2010, 04:20 PM   #5
rselectric1's Avatar
Rewards Points: 586
The plans (through sections, details and notes) should provide most everthing you need. Check elevation drawings too, sometimes they note more tid-bits there. This should be kind of easy actually.
rselectric1 is online now
The Following User Says Thank You to rselectric1 For This Useful Post:
roughrider (02-01-2010)
Old 02-01-2010, 04:28 PM   #6
Framer53's Avatar
Trade: Handyman
Rewards Points: 320
On the plans it qwill tell you the scale. 1/8 and 1/4 are most common.
Ure a scale or measuring device, measure it and add it up.
By the way, go up to the into section and introduce yourself.
Framer53 is offline
Old 02-01-2010, 04:32 PM   #7
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,496
Calculator helps when I run out of pencils.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 02-01-2010, 04:59 PM   #8
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Rewards Points: 12
The fascia is straight forward. You simply measure it
The soffit (if you are using 12" wide aluminium), works out to these numbers for the two most common sizes, 16" and 24"
If working with 10' pieces, 16" = 7 cut pieces (or 7 running feet) 24" = 5 pieces (or 5 running feet)
If working with 12 pieces, 16" = 9 cut pieces (or 9 running feet) 24" = 6 pieces (or 6 running feet)
If, however, you are working with plywood for your soffit, you will divide the fascia measurement by 8, and rip your sheets according to what is required for the width, minus the screen piece in the middle.
If only putting in the screen-in-a-hole inserts, forget the ripping part.
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is offline
Old 02-01-2010, 05:03 PM   #9
rustyjames's Avatar
Rewards Points: 1,524
unless it's a really simple design I'd be careful with scaling it.
rustyjames is offline
Old 02-01-2010, 05:08 PM   #10
General Contractor
Willie T's Avatar
Rewards Points: 12
It's honestly a lot easier to simply pick up the phone and tell your installer you want the house at 1234 Anyplace Street done.
Willie T is offline
Old 02-01-2010, 05:18 PM   #11
Rewards Points: 586
OK, call me harsh if needed, but the OP (with 2 total posts) has demonstrated that he might "be in over his head". Take-offs and print reading abilities should be a prerequisite to bidding on ANY type of job.
Pretty basic stuff. OP can you give us more info on just where you are stuck?
Old 02-01-2010, 05:24 PM   #12
General Contractor
Willie T's Avatar
Rewards Points: 12
Ron, you are just SO, so "harsh".
Willie T is offline
The Following User Says Thank You to Willie T For This Useful Post:
rselectric1 (02-01-2010)
Old 02-01-2010, 05:27 PM   #13
General Contractor
Willie T's Avatar
Rewards Points: 12
Sometimes I wonder why we even have the 'contractor' part attached to the forum name...... Still waiting for someone to ask why the tape measures have those little red and black marks on them.
EDIT: Sorry..................... that was a little harsh too.
Willie T is offline
Old 02-01-2010, 05:39 PM   #14
Rewards Points: 586
I'm sure you've had the pleasure of trying to explain why the first stud is only 15-1/4" in too.
Trying to make this a "warmer, fuzzier" place for newbies certainly has it's frustrations too.
Old 02-01-2010, 05:44 PM   #15
d-rock's Avatar
Trade: carpentry/drywall/plaster
Rewards Points: 250
I'm assuming you haven't done much soffit and fascia. Without seeing the plans, here is a brief step by step, but you have to use your judgement. 1.Scale it for total length. 2.Seek out details in the drawings to figure out the assembly, (plywood,vinyl, aluminum etc) Do the math to figure for materials and labor.
d-rock is offline
Old 02-01-2010, 07:03 PM   #16
NormW's Avatar
Trade: Builder
Rewards Points: 250
I had to leave the job today. After putting in all the specials, I turned to the other carpenter and reminded him about the "15-1/4" (and even explained why too). He says "You know I've built houses before.... right?" "Yup, and you don't know how many times I've heard that from others and found someone pulled the first off at 16".
When I got back, he saw me eyeballing the walls. He says "Bet your going to whip out a tape measure now"... "Nope!" I whipped out my folding rule and checked em'... He had em' right.
Had to laugh, when I read this post
NormW is offline
The Following 2 Users Say Thank You to NormW For This Useful Post:
rselectric1 (02-01-2010), Willie T (02-01-2010)
Old 02-01-2010, 08:41 PM   #17
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
figurin soffit is a pain
Tom Struble is offline
Old 02-01-2010, 09:21 PM   #18
General Contractor
Willie T's Avatar
Rewards Points: 12
I still love the guys who do layout to the actual 'centers'.
Willie T is offline
Old 02-01-2010, 09:27 PM   #19
General Contractor
Willie T's Avatar
Rewards Points: 12
I certainly DO understand the guy who may well be a contractor in a specific discipline not understanding the finer details of another's trade. But, for the life of me, I can't figure out how anyone, in any trade, lacks some of the basics that we all learned as laborers and/or helpers long ago.
Well, perhaps I can. Years ago, we all came up doing most of the jobs on a site. Today, it seems to be mostly specialization. Yet so many never get all that good in their own isolated and esoteric trade. Strange.
Willie T is offline
The Following 4 Users Say Thank You to Willie T For This Useful Post:
afkama (02-02-2010), griz (02-01-2010), SC sawdaddy (02-01-2010), tgeb (02-01-2010)
Old 02-01-2010, 09:35 PM   #20
tgeb's Avatar
Rewards Points: 632
It's been covered at least once or twice, not recently as I can recall....but I have seen the questions.
Now that you bring it up......I'm sure they'll come out of the woodwork.
www.gebcon.com
tgeb is online now
aluminum soffit and fascia Something new General Discussion 13 02-22-2013 05:01 AM
Azek fascia, vinyl soffit question RightConnection Windows, Siding and Doors 11 10-09-2009 08:18 PM
fascia, soffit, gutter cleaner Home Serve Windows, Siding and Doors 1 09-26-2009 07:40 PM
Soffit without fascia avenge Windows, Siding and Doors 7 08-20-2009 09:14 PM
Average price per ft for soffit fascia labor ericvandee Windows, Siding and Doors 9 08-18-2009 02:27 PM
