HELP! What Brand Is This Window???
Old 01-09-2009, 07:32 PM   #1
jkfdavmat1's Avatar
Question
I'm working on a project in which I need to replace a few window sashes. I've never seen this logo before and I can't find the usual sticker located on most windows. Any help would be appreciated.
The window is aluminum... I've looked up all window manufacturers that start with "P", but can't seem to find a similar logo on any websites.
Thanks,
Jason
708208
Last edited by jkfdavmat1; 01-09-2009 at 07:34 PM. Reason: Adding more information
jkfdavmat1 is offline
Old 01-09-2009, 07:44 PM   #2
Patrick's Avatar
Re: HELP! What Brand Is This Window???
where are you located? any idea when the windows were installed
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 01-09-2009, 07:45 PM   #3
I like Green things
WarnerConstInc.'s Avatar
And when they were cleaned the last time. I bet they have something to do with Pace Setter. I cant remember if that is all one word or not.
WarnerConstInc. is online now
Old 01-09-2009, 08:50 PM   #4
jkfdavmat1's Avatar
I'm located in Nashville, Tennessee. My wife and I just purchased the house as a rental. I usually just do framing and finish carpentry so I don't have a lot of experience with windows. I have no idea when the windows were installed. I'm guessing within the last 10 years. That probably doesn't help.
As for when they were last cleaned...I have no idea.
I'll google Pace Setter and see what I can find.
Thanks.
Old 01-09-2009, 08:56 PM   #5
jkfdavmat1's Avatar
Looks like you were right! They are Pacesetter windows... Looks like they got in trouble for conning people out of money and now no longer exist. Looks like I won't be getting replacement sashes. I guess I'll just have to get the glass replaced. Thanks for the info guys.
Old 01-09-2009, 09:10 PM   #6
I like Green things
Do I get a prize now?
Old 01-09-2009, 09:51 PM   #7
The Deck Guy
Greg Di's Avatar
Personally, I think it should be a law that all window MFGs must stamp or ID the windows in a uniform place. I have spent way too much time chasing down obscure/no-name brand windows.
Know what I mean?
Greg Di is offline
Old 01-09-2009, 11:09 PM   #8
I like Green things
Know what I mean?
I dont even wan't to get into how I knew what kind of window that is.
Long story, kind of embarassing, it was a long time ago as well.
I hate trying to identify or match something. I should start a service just for that.
I tried to match a busted out window on a repo for the bank/real estate company.
You cant match junk builders windows!!
I told them they need all new windows.
At least I got 175 bucks for screwing some osb over it.
I used #20 Torx heads, theft deterrant.
Old 01-10-2009, 12:54 PM   #9
Al Smith
A W Smith's Avatar
since almost all replacement double Hung's are designed to fit into a 3 1/4 inch cavity and share a common sash thickness of 1 3/8", why not see if a sash from a different manufacturer works and interlocks with the existing remaining sash rail? Even if the sash balances are different you can easily replace a pair as they are usually just held in with a single screw at the top of the frame. Most all manufactures will make a sash to exact size. (W x H) You can even re-use the same filthy hardware.
Al Smith
http://www.awsmith.com
A W Smith is offline
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Replacement Window Question? Max10 Windows, Siding and Doors 34 02-27-2010 06:15 PM
Reno Window Screw Up Bummie Windows, Siding and Doors 15 12-22-2008 10:33 PM
Window Sub Files Bankruptcy-Warranty Issues remodel chick Windows, Siding and Doors 12 11-23-2008 10:11 PM
Basement Window Leaking DanTheMan9727 Construction 3 10-24-2008 02:29 PM
