HELP!!! Leak Under Exterior Wall On Slab
Old 01-09-2009, 11:02 AM   #1
jrcuts's Avatar
Trade: electrician
I have a leak when it rains under the exterior wall of the sunroom which is set on a slab. It looks like the water is coming in through the corner of the wall on the bottom on top of the slab. I've tried to cork it but it didnt work does anyone have any suggestions.
jrcuts is offline
Old 01-09-2009, 01:43 PM   #2
mics_54's Avatar
Trade: contractor
Re: HELP!!! Leak Under Exterior Wall On Slab
The last time I saw water actually enter the building under a wall it was due to poor drainage and the water level next to the building was higher than the slab. It was caused by snow and ice buildup. Are you sure it's coming from under the wall.
Does your building have eaves?
How much water are you talking about?
Where are you located?
How would water enter a building under an exterior wall? Is the slab protruding past the wall line? What type of siding etc?
mics_54 is offline
Old 01-09-2009, 02:28 PM   #3
jrcuts's Avatar
Trade: electrician
The slab comes out about 4 inches past the wall. Its not a lot of water it just builds up a little in the corner when it rains and then it seems like the sheet rock is soaking some of the water up and some of it puddles up. I have cedar impression vinyl siding. There are no eaves.
jrcuts is offline
Old 01-09-2009, 02:50 PM   #4
Make it Happen!
Rick954's Avatar
Trade: Project Super
you dont happen to have any pictures of the outside do you?
Rick954 is offline
Old 01-09-2009, 07:21 PM   #5
Tom Struble's Avatar
Trade: siding
hmmm slabs past the wall huh? wonder what it could be
your probably going to have to remove the siding and wrb install flashing,reinstall wrb then reinstall the siding.I Would hold the j channel if your using it up a little ,a couple of drainage holes drilled into the j wouldnt be a bad idea
Tom Struble is offline
leak under sunroom exterior wall on slab jrcuts Framing 7 01-09-2009 06:17 PM
Pex tube leak under cement floor jonbjornstad Plumbing 22 12-23-2008 09:44 PM
Deep fill under garage slab lazerguy Masonry 9 09-06-2008 02:23 PM
Another wood subfloor over concrete slab GreenBuilder Carpentry 3 05-08-2008 01:20 PM
Demo a foundation under a radiant heat slab without disturbing the slab...? wackman Remodeling 18 04-02-2007 12:38 AM
