Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Contractors Talk Forums > General Discussion
Old 01-29-2009, 08:14 AM   #1
Trade: framer-inside/outside trim- asphault roofing/remoldeling
help with finish on pecky beam
hello all. I am planning on pecky cyprus beam for a mantel. i have already
aquired the beam and need more know how on the finishing. I've begun to
wire brush the voids. I'm thinking i might want to fill the voids with epoxy
or the bar top stuff. Do I use a wood sealer? I can only imagine that the
cyprus is going to suck up anything i put on it. thanks in advance
passingwindII
rbeck3@ec.rr.co is offline   Reply With Quote
Old 01-29-2009, 09:43 AM   #2
Wouldn't you think that this might
belong under painting and finishing?
Or better yet at DIY forum?
neolitic is offline   Reply With Quote
Old 01-29-2009, 12:32 PM   #3
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
Cycanoacrylate. Use it to harden the soft areas. Fill with your choice of filler.
Cdat is offline   Reply With Quote
Old 01-29-2009, 12:35 PM   #4
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
Also, why would you fill the voids? That is the whole idea behind using pecky wood. For the look.
EXT, finish choices genecarp Painting & Finish Work 19 12-08-2008 04:47 AM
Dirt in Finish banctecbobn Flooring 18 09-19-2008 05:19 PM
beam situation rakuz66 Framing 1 09-16-2008 03:48 PM
Updating main beam in century-home: end. bob_cntrctr Framing 8 02-07-2008 04:04 PM
Sticky finish...Boy could I use some advice Uuber_Framer Flooring 11 10-26-2007 03:41 PM
