Hardie Siding
Old 07-01-2009, 07:26 PM   #1
RCPainting's Avatar
Trade: Painting in Utah
Hardie Siding
Need some help guys!
Doing a bid for a GC (one I do a lot of work for) and he is speccing out a home. Customer wants to use Hardie Board and Batten and trim on a house.
Looking at two options
1. Prefinished from manuf, 30 year warranty
2. Painted on site with Duration, lifetime warranty on materials only.
This is not used much in this area, the home will be in a heavy snow area.
It will be labor intensive to caulk and paint all nail holes and cut edges.
I can see where a factory applied finish is preferable.
It is not as much as the price, but the quality of finish.
Which do you prefer? Have you seen problems with either?
How about the nails?
Colored?
Sunk?
TIA
RCPainting is offline
Old 07-01-2009, 08:54 PM   #2
Side Effects May Vary
ModernStyle's Avatar
Trade: Professional Painting
Re: Hardie Siding
The factory finish will still have to be caulked and filled wont it ? Which means touch up's.
I have never done pre-finished Hardie, but we used to do a builder who used pre-finished wood on his houses. Nothing ever touched up, and there was always the raw ends, and usually a board or 2 that hadnt been painted. We would have to repaint the boards that we touched up, I remember one house where we kept going back to because no matter what we tried we could not get paint to match. It would match on one board and then not match the next. After a year of endless touch ups the builder finally paind us to repaint the whole exterior. The whole experience kinda turned me off on pre-finished exterior products.
ModernStyle is offline
Old 07-01-2009, 08:59 PM   #3
Tom Struble's Avatar
Trade: siding
Re: Hardie Siding
you can go either way,the pre finish is nice but nothing looks like a freshly painted house,thats the premium finish imo
Tom Struble is offline
Old 07-01-2009, 09:17 PM   #4
RCPainting's Avatar
Re: Hardie Siding
I think touch up can be an issue, seems easier to me to just paint it on site.
Think the HO is looking at warranty issue as well.
Do you usually see the nails flat or presunk?
It is speced for presunk, just curious.
Old 07-01-2009, 09:33 PM   #5
Trade: siding
Re: Hardie Siding
what are you face nailing? siding?trim?usually the siding is blind nailed,you dont countersink nails in fibercement nail it flush,you really should get a hardie install manual or check out the finishing specs online
Old 07-01-2009, 09:43 PM   #6
RCPainting's Avatar
Re: Hardie Siding
That is where my concern (or lack of knowledge) is.
I looked at this.
I am just trying to understand options so when we meet I have a clue!
Thanks
Old 07-01-2009, 09:56 PM   #7
Zimmermann
BrianFox's Avatar
Trade: Wood Cutter
Re: Hardie Siding
The siding itself is all blindnailed so the only nail filling will be the corner and window / door trim material.
The best experience I have had is to paint it on site with a custom duration color.Looks better and is easier to maintain.
Happiness is produced not so much by great pieces of good fortune that seldom happen, as by little advantages that occur every day.
- Benjamin Franklin
BrianFox is offline
Old 07-01-2009, 10:09 PM   #8
Trade: siding
Re: Hardie Siding
i think your reading the detail wrong you dont sink the nails,if you happed to sink a nail your supossed to caulk it and add a nail driven flush
Old 07-01-2009, 10:14 PM   #9
RCPainting's Avatar
Re: Hardie Siding
That is why I am asking, I was told to estimate for caulking nails. And that just did not make sense, that's why I come here!
Old 07-01-2009, 10:20 PM   #10
Trade: siding
Re: Hardie Siding
good luck with the bid
Old 07-01-2009, 11:07 PM   #11
I like Green things
WarnerConstInc.'s Avatar
Re: Hardie Siding
The color matched caulk for the pre-finished is expensive, the paint to touch up is expensive. I vote for a finish coat after it is all installed.
WarnerConstInc. is online now
Tom Struble (07-02-2009)
Hardie plank siding per square Snl Windows, Siding and Doors 16 02-10-2010 10:49 AM
ABC Supply Co. Inc. Acquires Chesapeake Siding and Roofing Grumpy Roofing 0 03-03-2009 09:40 AM
Hardie Plank Siding robertaxxe Construction 6 03-02-2009 08:37 AM
Concrete Dust on Prefinished Hardie Cecil General Discussion 3 01-06-2008 10:37 PM
Hardie Plank Siding ApgarNJ Contractor Swap 0 11-05-2007 10:15 PM
