The Great Tip And Trick Thread
Old 11-26-2006, 01:58 AM   #1
Custom Builder
Glasshousebltr's Avatar
Because we've migrated to tips and tricks, I thought a thread on tricks would be cool.
Stack roof sheathing neatly, use black magic marker to scribe all edges 24OC at once. Hell of a time saver.
When cutting shingles. Set full shingle on top key down, flip right to left so as the bottoms up, slide to desired position, cut at last shingle flip back and nail.....perfect fit. A roofer measuring cut shingles or hooking a rake makes me sad to pay him.
Before hanging a board of drywall, run lipstick around electric openings, press drywall to wall gently, remove and cut from the back with rotozip. This is also a good way to utilize your less competent help.
If sex becomes boring, wait until mid way, then tell her ya slept with her sister.......giddeeeup!
Bob
Bob
Glasshousebltr is offline
Old 11-26-2006, 08:42 AM   #2
theworx's Avatar
Re: The Great Tip And Trick Thread
All good tips!!! But instead of the lipstick thing why not just put the sheet of drywall up with a couple of screws and use a guide bit on your rotozip to cut around the electrical box??? And half way through if I told her I slept with her sister it would be Gideeup alright (she would gideeup right out of bed and be gone) !!!
theworx is offline
Old 11-26-2006, 09:00 AM   #3
boman47k's Avatar
And would NEVER forget!
boman47k is offline
Old 11-26-2006, 09:05 AM   #4
tkle's Avatar
...neither would her sls
tkle is offline
Old 11-26-2006, 12:59 PM   #5
mdshunk's Avatar
Originally Posted by Glasshousebltr View Post
Because Before hanging a board of drywall, run lipstick around electric openings, press drywall to wall gently, remove and cut from the back with rotozip. This is also a good way to utilize your less competent help.
I've done that same thing for marking a deadbolt latch plate. Put lipstick on the end of the deadbolt and turn the knob so that it presses tightly against the jamb.
mdshunk is offline
Old 11-26-2006, 02:04 PM   #6
painterman's Avatar
Trade: Historic Restorations
I always colour my drywall mud and spackel. Much easier to see. Use carpenters glue (brown) to seal knots.
painterman is offline
Old 11-26-2006, 04:13 PM   #7
Teetorbilt's Avatar
Great tip painterman! Wonder why I never thought of that. I would think that any waterproof glue would work, like TiteBond II or III.
Albert Einstein
Teetorbilt is offline
Old 11-26-2006, 04:45 PM   #8
painterman's Avatar
Tite Bond 11 and 111 seem to work the best. Since I starting using this method I have never had a knot burn through. I use glue on rust stains and tannin bleed. Works everytime.A paint chemist turned me on to the glue thing
Old 11-26-2006, 04:47 PM   #9
painterman's Avatar
Baby power on weather strip stops a freshly painted door from sticking.
Old 11-26-2006, 04:53 PM   #10
wackman's Avatar
Trade: Builder, Additions, large remodels...Lately also small remodels.......
For the guys who aren't so fast at doing math in your head, if you need to cut a measurement in half (to get a center mark) pull your tape out to the full distance, fold your tape over and touch the dumb end to the number of your measurment, then look at the center of the fold in your tape, it'll be exactly half and is easy to tell down to a 16th.
Cut a disk of formica (you can also buy these) exactly 2 3/8" in diameter, put some construction adhesive on it then stick it to the side of your tape measure. Perfect for writing measurments so you don't forget your numbers or having to carry a block of wood or pad with you.
A nice little tool I picked up recently is something called a Big Lug. It's got bungee bands with a plastic ball on one end of one piece and the other piece is a belt style clip with a receptacle for the ball. Put the bungee around the handle of any hand tool (drills and nail guns especially) and then it will easily hang from your belt or bags. Comes in and out really slick. Makes any job where you need to put that hand tool down often much faster and it's great for ladder work.
Wack
wackman is offline
Old 11-26-2006, 05:15 PM   #11
carpenter and builder
Nick H's Avatar
Trade: carpenter and builder
If youve got to divide a piece of material in two ( or 3 or 4 etc) and the measurement is "awkward" , eg you measure a board and its 11 5/8 " and you gotta cut it in half, just skew the tape until its on 12" and then mark at 6". If you had to cut into three you could mark at 4 and 8 etc.
Dont give me problems, give me solutions.
Nick H is offline
Old 11-26-2006, 05:17 PM   #12
RobertCDF's Avatar
Trade: Custom deck builder
Always tell your pregnant wife that she looks great.
RobertCDF is offline
Old 11-26-2006, 05:47 PM   #13
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
[QUOTE]Before hanging a board of drywall, run lipstick around electric openings, press drywall to wall gently, remove and cut from the back with rotozip. This is also a good way to utilize your less competent help.
What color should I use?
Don't worry, the baseboard will hide it!
ron schenker is offline
Old 11-26-2006, 06:02 PM   #14
Flooring? What's that?
J DoubleD FLoor's Avatar
Trade: Flooring
Red is your color ron
After installing any hardwood flooring ... take the sawdust from the bags of your saws and sprinkle it over the entire floor ..... then rub it into the floor ... this fills any small gaps and imperfections of mill cuts ... then sweep it up and viola ... perfect floor
Quality is not expensive ... It's PRICELESS !!!
www.neoflooringco.com
J DoubleD FLoor is offline
Old 11-27-2006, 08:37 PM   #15
theworx's Avatar
For you painters, I always carry a couple of bottles of white out (you know, the correction fluid for when you make a spelling error) with me. If you encounter pen or crayon marks on a wall just cover with white out and seals it perfectly!!! No need to prime with special primer... Ink usually bleeds through everything but the white out seals in one little stroke !!!
theworx is offline
Old 11-27-2006, 08:53 PM   #16
Teetorbilt's Avatar
Old timer tricks with a plumb bob.
Chandalier placement; measure across table with string, fold in half and place a dime on the table. Drop the bob from the ceiling and mark.
Plumbing a door; hang the bob a few inches from the frame and measure out to it as you shim.
Albert Einstein
Old 11-27-2006, 09:23 PM   #17
joasis's Avatar
Anytime you work with sheet steel, like R panels in roofing, or walls, and want perfet screw lines, mark the sheets on the ground before they go in the air....speeds the installation plus no string line or chalkline used.
We screw our concrete forms together now with GRK Torx screws....vaseline in the head prevents concrete from sticking, and the forms can be disassembled easily...no more duplex nails.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 11-27-2006, 09:29 PM   #18
reveivl's Avatar
Trade: Renovations
When I'm putting steel roofs on I drill the holes while the steel is in a stack on the ground all lined up nice and even.
reveivl is offline
Old 11-29-2006, 02:59 PM   #19
jack of all, master of 1
snapper21's Avatar
Trade: carpenter/roofer
Mix sawdust with elmer's. Heavy on the sawdust, just enough glue to hold it together. Use the dust from the wood your filling if possible. This is a great fill that does stain without standing out if mixed right. Sands too.
Easy on the glue killer! Just a lil dab'l do ya.
Just the thought of not trying is a stroke of ignorance.
snapper21 is offline
Old 11-29-2006, 03:32 PM   #20
john elliott's Avatar
Trade: kitchen cabinet maker and installer
I use a Festool plunge saw and guide rail system extensively, especially on site where I find it invaluable. I find it works much better if I don't stand on the cord
John
Ed the Roofer said "John too, in his crass and blunt demeanor.............."
john elliott is offline
