Are Graco And Titan Compatible?
Old 04-19-2009, 05:27 PM   #1
blackstonepainting.com
blackstone's Avatar
Trade: Painter
I've got 3 sprayers, and lots of parts (extra guns and hoses, lots of tips, etc.)
I'm thinking of pickiup up a Titan 1140 second hand. Does anyone know if my Graco hose and guns will work with a Titan sprayer
THanks!
blackstone is offline
Old 04-19-2009, 05:54 PM   #2
Railman's Avatar
Trade: Railing
Re: Are Graco And Titan Compatible?
I don't use airless sprayers, but as long as the psi is the same for both pumps, & guns, I can't imagine how there could be a problem. All the gun cares about is the psi, & flow rate (material volume).
Joe
Railman is offline
Old 04-19-2009, 08:44 PM   #3
Halo's Avatar
Trade: General building & remodeling
Tips can vary between the two brands mentioned. It will mostly depend on the spraygun and guard as to what tip will work. As mentioned, hoses, sprayguns, etc. are not pump brand specific. Just be sure the proper ratings are met. Remember that all of those items are considered consumables and thus may not have much life left in them.
Halo is offline
Old 04-19-2009, 09:01 PM   #4
Drywall & Painting Pro
Sir Mixalot's Avatar
Trade: Hang, Finish, Texture, Paint, and Repair.
Yes, the hoses and guns should be compatible with each other.
Check this out. Click Here
Sir Mixalot is offline
Old 04-19-2009, 09:05 PM   #5
Side Effects May Vary
ModernStyle's Avatar
Trade: Professional Painting
Everything will work. The only thing that would be brand specific would be tips and housings. I have heard that the titan tips will work with a graco rac5 housing but have never tried it, I only use graco tips and housings.
I always shy away from used pumps, you never know how bad they were mistreated, scarred pistons and piston sleaves are expensive to replace.
ModernStyle is offline
Graco Magnum Project 5 or Titan 440i? painter40 Painting & Finish Work 12 12-02-2008 05:50 PM
titan or graco sprayer48 Painting & Finish Work 1 04-28-2008 06:05 PM
Graco Contractor or LX 80 Platinum? mntacoma Painting & Finish Work 1 11-30-2007 05:28 PM
Titan 440ix jself52 Painting & Finish Work 4 02-16-2007 12:52 PM
titan sprayers painterofeveryt Painting & Finish Work 10 07-28-2006 09:14 PM
