Glulam Weight
Old 08-10-2010, 10:08 PM   #1
serrano7503's Avatar
Rewards Points: 75
Glulam Weight
Any idea what roughly a 5" x18' x28' Glulam beam would weigh?
Thanks.
serrano7503 is offline
Old 08-10-2010, 10:12 PM   #2
Don
rotarex's Avatar
Trade: Renovator/ Builder
Rewards Points: 508
Re: Glulam Weight
Thanks.
882 lbs if you meant 5"x18"x28' thats Pine
i suggest if you want to move this by your self you get sauced up
Custom Decks
Custom aquarium all salt water
Renovation
next on my list............planting trees for all those material i used
rotarex is offline
Old 08-10-2010, 10:18 PM   #3
Tom M's Avatar
Rewards Points: 5,600
Re: Glulam Weight
Without looking in the spec book my guess is 20-22 lb per foot
Tom M is offline
Old 08-10-2010, 10:20 PM   #4
Rewards Points: 75
Re: Glulam Weight
Whoops, I DID mean 18" Thanks guys...
Whats the formula to determine the weight?
Old 08-10-2010, 10:24 PM   #5
Don
rotarex's Avatar
Rewards Points: 508
Re: Glulam Weight
cut a piece of the material you are using, put it on a digi , and then do the math
i figured its 31.5/ ft as its, pine, glue and nails
Custom Decks
Renovation
rotarex is offline
Old 08-10-2010, 10:36 PM   #6
Rewards Points: 75
Re: Glulam Weight
Good enough.
Thanks again.
Old 08-11-2010, 01:42 AM   #7
Kgmz's Avatar
Re: Glulam Weight
Tom, good guess.
For a western glulam its 22.4 lbs per foot. So 627 lbs.
Serrano, to get the weights just look at your beam manufacturers specifiers guide.
Here is link for Boise Cascades guide.
http://www.bc.com/dms/wood/ewp/3_Gui...c_complete.pdf
Kgmz is offline
Old 08-14-2010, 10:02 AM   #8
fast fred's Avatar
Trade: carpentry
Rewards Points: 764
Re: Glulam Weight
we used to have a contest at a place I worked. how much does it weigh?
it was always fun, but mr math would always win, the guy could caclulate roof systems with a little or no info
bf calculations were the best, but not always reliable on recycled timbers (old metal bolts in the beams would throw the weight off alittle)
if the semi was loaded with like beams or logs we could calculate it by truck load weight
and cutting a board foot and weighing it and doing the math was not always exact because you need to figure in loss and gain of moisture
the winner just got bragging rights until we found another beam or log to weigh
glu lams are too easy because all that info is available by the manufactuer
fast fred is offline
Old 08-14-2010, 10:11 AM   #9
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
Re: Glulam Weight
i like the idea of guess that weight, we play guess the length when finishing off smaller lenghts of the double top plate or gable end studs and what not
woodworkbykirk is offline
Old 08-14-2010, 10:37 AM   #10
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,494
Re: Glulam Weight
I would have guessed 1000 lb.
After 150 or so it becomes a zoom boom issue anyway
Airdrie AB Renovation Contractor | Kitchen Renovations | Basement Developments | Facebook
JT Wood Construction Serves Airdrie, Cochrane, Olds, Mountainview, Rockyview and Crossfield, Alberta.
JT Wood is offline
Material Weight. jcalvin Excavation & Site Work 5 02-11-2010 04:12 PM
Cellulose and weight = problem? tgeb Insulation 8 01-27-2009 06:55 PM
what is the weight of a solid CMU AustinDB Masonry 11 01-21-2009 07:58 PM
Carpet Weight Dan_Watson Flooring 4 09-25-2008 06:18 PM
Favorite Standard Weight FrankT Roofing 2 08-19-2008 07:25 PM
