GIVEAWAY: Pacific Laser Systems PLS 180 Cross Line Laser
Old 10-28-2017, 12:57 PM   #61
avenge's Avatar
Rewards Points: 2,712
Re: GIVEAWAY: Pacific Laser Systems PLS 180 Cross Line Laser
I just used the 3 lasers I have on a bath remodel. Used a combo of cross line and dot to center a freestanding tub with chandelier centered above. Used them to line up vanity lights, cabinets, tile floor, tile walls and chair rail.
I sometimes find myself needing 2 cross line lasers. I use them often but at times a level and pencil is a better choice.
avenge is offline
Old 10-28-2017, 02:03 PM   #62
bbxride's Avatar
Trade: remodel
Rewards Points: 8
would probably use it most everyday that I take measures
bbxride is offline
Old 10-28-2017, 03:21 PM   #63
fjn's Avatar
Trade: mason
Rewards Points: 8,966
Would use it every day laying out foundations and wall lines.
fjn is offline
Old 10-28-2017, 08:24 PM   #64
Hackattack's Avatar
Trade: Remodeling GC
Rewards Points: 44
I would use it multiple times each week. Installing cabinets, interior trim like wainscot paneling and chair rail, tile layout, framing basement walls, helping my electricians line up lighting fixtures, etc. The applications are endless.
Hackattack is offline
Old 10-29-2017, 08:55 PM   #65
rblakes1's Avatar
Rewards Points: 1,290
I would use it 1-2 times a week, depending on the job. I love using as laser for setting cabinets and doing tile layouts. I've also used it for walls and running trim
Sent from my SM-N910V using Tapatalk
rblakes1 is offline
Old 10-29-2017, 10:29 PM   #66
Sawdust Sweeper
carpentershane's Avatar
Rewards Points: 28
As a general carpenter and remodeler I would use it nearly daily... It is a fantastic tool to use from doing trim and doors to tile to decking and siding... A former employer of mine had one a PLS and we used the hell out of it. If I were to use it tomorrow, it would be used for tile layout...Next week? On a window job!
"Perfection is an unachievable goal, the illusion of perfection is the work of a true craftsman. " LoneFramer
carpentershane is offline
Old 10-30-2017, 05:39 AM   #67
improving homes
platinumLLC's Avatar
Trade: Roofing/Remodeling
Rewards Points: 298
I use my lasers all the time. Once you learn how to use them to their full capabilities it's amazing how handy they are. Would love to try out a green laser to see how much better they are then my red ones.
platinumLLC is offline
Old 10-30-2017, 08:49 AM   #68
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 1,762
I use lasers every week, would love to have another one.
"When the people fear their government, there is tyranny; when the government fears the people, there is liberty"
- Thomas Jefferson-
http://www.savingtherepublic.com/Main.html
Snobnd is offline
Old 10-31-2017, 09:06 AM   #69
fred54's Avatar
Trade: contractor
Rewards Points: 138
the outside sensor will be handy, I need to extend some outdoor drainage pipe before the winter. Great for drop ceilings. Once a week or so.
fred54 is offline
Old 10-31-2017, 10:14 AM   #70
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extraordinaire
Rewards Points: 1,082
Even as a designer, I use a laser to see if a potential as-built model has a drop in the floor or ceiling that needs to be remedied before commencing with the regular work.
Andy.
ScipioAfricanus is offline
Old 10-31-2017, 08:30 PM   #71
mstrat's Avatar
Trade: New Construction & Remodeling
Rewards Points: 1,422
I gotta say, I guess I need one to learn how to use lasers better! I have simply not figured out how to use them in framing very efficiently...I did love it on the last cabinet install, but a door jamb? I struggle to understand how you guys are using it for doors/windows (other than if you're keeping jambs at the same height?). I do also love the help in keeping tile lines straight too though!
mstrat is offline
Old 10-31-2017, 10:39 PM   #72
Dirtywhiteboy's Avatar
Rewards Points: 8,004
I like using mine on tall walls to check how out of plumb they are.
GIVEAWAY: Pacific Laser Systems PLS 180 Cross Line Laser-img_20171030_145058055.jpg
Dirtywhiteboy is offline
Old 11-01-2017, 01:59 PM   #73
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 9,360
How often would I use it you ask?
If I had one of those when I first started in this business, I'd be retired and hanging out at the beach by now!
GIVEAWAY: Pacific Laser Systems PLS 180 Cross Line Laser-1-1-.jpg
SmallTownGuy is online now
Old 11-01-2017, 09:10 PM   #74
antonioooooooo's Avatar
Trade: framing, finishing.
Rewards Points: 429
I use lasers every single day at work. Steel stud is where we use different lasers most often. I use them to shoot square lines, and to transfer wall lines up. I'll use a point laser for setting corners on furring out columns, and a horizontal line to check floor variances to cut studs to level for structural mezzanines. I actually barely ever touch a bubble level.
antonioooooooo is offline
Old 11-01-2017, 10:56 PM   #75
Pro or somethin'...
Anthill's Avatar
Trade: Tinwoodman
Rewards Points: 1,240
As a one man band, I would use it several times a week. They work good in place of a snap line. Its often difficult to chalk a line on a floor by myself. They're super handy for interior framing and t-bar grids.
Anthill is offline
Old 11-02-2017, 06:02 PM   #76
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,538
I use it on my sharks.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 11-02-2017, 09:39 PM   #77
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 872
I use my laser line for getting perfect slope on flat roofs. Never a puddle.
cedarboarder is offline
Old 11-03-2017, 03:14 PM   #78
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 864
Like any good tool once you have I think one tends to use it more. Residing houses sometimes with lot of different levels and in and outs it would make things easy in setup . Also would be great when installing windows.
Randy Bush is offline
Old 11-04-2017, 08:19 AM   #79
Tom M's Avatar
Rewards Points: 6,026
It helps keep us level headed.
Tom M is offline
SmallTownGuy (11-06-2017)
Old 11-04-2017, 08:47 AM   #80
Pearce Services's Avatar
Trade: Commercial Loading Dock and Door Contractor
Rewards Points: 40
Every time I install one of these.....
GIVEAWAY: Pacific Laser Systems PLS 180 Cross Line Laser-umass-outside.jpg
GIVEAWAY: Pacific Laser Systems PLS 180 Cross Line Laser-umass-inside.jpg
Layout is critical
Kevin
www.BadcoDoors.com
Pearce Services is offline
The Following User Says Thank You to Pearce Services For This Useful Post:
Californiadecks (11-04-2017)
Laser receiver/detectors, which one to get or just buy a whole new rotary laser kit? platinumLLC Tools & Equipment 13 08-14-2017 12:27 AM
What size and kind of service line? help !!! mebedave Plumbing 10 10-31-2010 02:41 PM
Just you step 'cross that line. I dare ya. Kyras Tiling 5 03-13-2010 08:05 PM
Why Did the Chicken Cross the Road? eagleandbaby Off Topic (Non Trade) 3 10-04-2008 08:31 AM
What laser can put a line on the floor? PLS-5? offpiste Tools & Equipment 4 02-06-2007 02:12 PM
