GIVEAWAY: Pacific Laser Systems PLS 180 Cross Line Laser - Page 3 - General Discussion - Contractor Talk
Old 10-24-2017, 07:13 PM   #41
PacificCanvas's Avatar
Trade: Awnings
Rewards Points: 148
Re: GIVEAWAY: Pacific Laser Systems PLS 180 Cross Line Laser
How often would you use a tool like this? What ways would you use it the most often?
Once or twice a week. Leveling up Posts, marking elevations.
PacificCanvas is offline
Old 10-24-2017, 07:37 PM   #42
GitSum's Avatar
Rewards Points: 178
Depends on what we are doing but a couple of times a week/month doing layout work
GitSum is offline
Old 10-24-2017, 09:52 PM   #43
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 2,124
I use a laser fairly often, with no defined calendar events. Definitely helps me improve on bush trimming. Otherwise they look like a really bad hair cut. Mostly I use a laser to level everything that needs to be level like pictures, tile, cabinets, etc.
Peter_C is online now
Old 10-24-2017, 09:56 PM   #44
Dirtywhiteboy's Avatar
Rewards Points: 8,214
I find if I get it out every morning there is always something I will need it for.. Today was bright and I wished I had the greenie..
Here is plumbing up a layout.
GIVEAWAY: Pacific Laser Systems PLS 180 Cross Line Laser-img_20171024_141849508.jpg
Dirtywhiteboy is offline
Tom Struble (10-26-2017)
Old 10-24-2017, 10:06 PM   #45
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & wel
Rewards Points: 4,934
I would use something like this often and Ive even been thinking about buying a new one since mine is a cheap piece of junk and a pain to use.
The job Im doing now I would use it in a horse stable to give me a level line while running electrical conduit.
Other then that I would use it on anything from drop ceilings to using it as a reference line when doing foundation repair.
I am just a vessel from which genius flows -Homer Simpson
Global warming is a myth, like evolution and the metric system.
U.S. Coast Guard
Michaeljp86 is offline
Old 10-25-2017, 05:00 AM   #46
saynever's Avatar
Trade: electrical
Rewards Points: 229
Have one already with the red beam. Would love one with the easier to spot green.
Use it for most interior tasks. Determining floor and ceiling flatness. Cabinets install. Can light layout. Plumbing up pre hung doors, even something stupid like running all outlet or switch boxes in the same plane when the floor is real wonky.
saynever is offline
Old 10-25-2017, 07:25 AM   #47
Been around
Mr Latone's Avatar
Trade: Roofing
Rewards Points: 1,574
I would use as often as it made sense..multiple times per job
It would be used as a replacement for a chalk line or pencil mark for any point of reference needed.
Above all, a good roof
Mr Latone is offline
Old 10-25-2017, 10:44 AM   #48
Bubble stick operator
Defenestrate's Avatar
Rewards Points: 262
I'd use this once or twice a week. Mainly setting elevations for cabinets, but also the occasional furring out of a ceiling, setting shelves, setting window/door head heights, and figuring out how/where structures have settled.
Defenestrate is offline
Old 10-25-2017, 11:58 AM   #49
Head Grunt
Tashler's Avatar
Trade: carpentry
Rewards Points: 197
How often is hard to say. But most definitely with cabinets, aligning door heights, transferring lines to adjoining walls.
Limits my chances of error with a level.
Tashler is offline
Old 10-26-2017, 06:57 AM   #50
Joasis's Avatar
Rewards Points: 1,900
I use a Northwest vertical plane laser to check plumb on ICF walls...looks like this would do it as well.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
Old 10-26-2017, 07:05 AM   #51
BlueRidgeGreen's Avatar
Trade: Craftsman
Rewards Points: 776
We use our lasers all the time.
For all kinds of things.
Today......we will use one for laying out tile.
BlueRidgeGreen is online now
The Following User Says Thank You to BlueRidgeGreen For This Useful Post:
Old 10-27-2017, 11:46 AM   #52
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,000
Tile and cabinets. A couple x's a month.
Steve
We Fix Houses is offline
Old 10-27-2017, 12:03 PM   #53
rsaunders's Avatar
Trade: building/remodling contractor
Rewards Points: 26
I could use this every week, setting tile, hanging cabinets, etc.
rsaunders is offline
Old 10-27-2017, 01:00 PM   #54
House surgeon
illbuildit.dd's Avatar
Trade: building/remodeling
Rewards Points: 2,062
I would use this tool no less than 3 times a week. I constantly install items with the need for leveling and level continuity.
illbuildit.dd is offline
Old 10-27-2017, 01:07 PM   #55
GreenLion's Avatar
Trade: Construction
Rewards Points: 4
This would make an excellent replacement for my cheap old Ryobi I bought awhile back. Comes in handy for so many projects!
GreenLion is offline
Old 10-27-2017, 01:12 PM   #56
AZsparky54's Avatar
Trade: Eleectrical
Rewards Points: 2
Thumbs up
Would use it for everything I want to be exactly plumb and level while doing electrical layout...#PRECISION
AZsparky54 is offline
Old 10-27-2017, 09:12 PM   #57
jakejorgenson's Avatar
Trade: GC/Carpentry
Rewards Points: 107
I would give it to my crew. I have one of the PLS lasers already and use it every few days for squaring up foundations, squaring up framing, measuring creating benchmark elevations for structural steel, and a whole lot of other simple uses for level and square lines. I like it a lot, but don't want to give my personal one to my crew to use when I'm not there because it is too valuable of a tool to me and I haven't purchased the crew their own yet.
jakejorgenson is offline
Old 10-28-2017, 09:07 AM   #58
DevittDesigns's Avatar
Rewards Points: 4
I would use it daily for tile, cabinets, framing or a thousand other things
DevittDesigns is offline
Old 10-28-2017, 10:21 AM   #59
tang's Avatar
Trade: Remodel contractor
Rewards Points: 269
I would use it instead of my cheap Stanley laser, for cabinets. I think at times it could replace my huge money TopCon! Pick me!
tang is online now
Old 10-28-2017, 11:55 AM   #60
VinylHanger's Avatar
Rewards Points: 8,038
I use mine nearly every day. Shower doors, posts, siding , etc. My favorite tool.
Impossible to do custom shower doors without one.
VinylHanger is online now
Laser receiver/detectors, which one to get or just buy a whole new rotary laser kit? platinumLLC Tools & Equipment 13 08-14-2017 12:27 AM
What size and kind of service line? help !!! mebedave Plumbing 10 10-31-2010 02:41 PM
Just you step 'cross that line. I dare ya. Kyras Tiling 5 03-13-2010 08:05 PM
Why Did the Chicken Cross the Road? eagleandbaby Off Topic (Non Trade) 3 10-04-2008 08:31 AM
What laser can put a line on the floor? PLS-5? offpiste Tools & Equipment 4 02-06-2007 02:12 PM
