GIVEAWAY: Pacific Laser Systems PLS 180 Cross Line Laser - Page 2 - General Discussion - Contractor Talk
Old 10-23-2017, 06:23 PM   #21
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,780
Re: GIVEAWAY: Pacific Laser Systems PLS 180 Cross Line Laser
I don't use one on a regular basis. Like all tools, I use what is needed. I use lasers to keep long runs of conduits and lighting straight, lay out can lights on the floor and transfer the locations to the ceiling, and keep receptacles in kitchen and baths level with each other so backsplash tiles don't make it obvious the floor isn't level.
Why is there not a Flat Mars Society?.
480sparky is online now
Old 10-23-2017, 06:24 PM   #22
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,080
We use a laser at least a few times a month. When setting the boxes in a backsplash I will use the laser to make sure they all end up the same in the tile. I will set cabinets with it or at least use it to find out how flat the floor is. Shooting locations for fixtures from the floor to the desired ceiling location is much easier with a laser. We also install custom graphic murals and use a laser for setting the leading edges plumb as we go.
overanalyze is offline
Old 10-23-2017, 06:26 PM   #23
Mike-B's Avatar
Rewards Points: 662
How are you using a laser to identify low spots on the floor?
Mike-B is offline
Old 10-23-2017, 06:28 PM   #24
Fugetaboutit
Lunicy's Avatar
Trade: Professional fixer upper
Rewards Points: 422
I'd use it all the time. Tile walls for certain. Cabinets too. Chair rail all day.
Lunicy is offline
Old 10-23-2017, 06:46 PM   #25
Southbluff's Avatar
Rewards Points: 68
I loaned my laser level to a friend, and it came back broken. That was about a month ago, and I have only missed not it having twice.
I mostly used it while installing cabinets. Ive got a drop ceiling to do in a month, so I think I should replace it soon.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Southbluff is offline
Old 10-23-2017, 06:50 PM   #26
Always Learning
Set it up as a reference point and take several measurements along the walls the cabs will be installed.
Tom M (10-23-2017)
Old 10-23-2017, 07:14 PM   #27
back doors to hell put in
Irishslave's Avatar
Rewards Points: 2,632
all the time and for everything....the stabila only pulls to 12'-6" I think and man is it heavy. I have 2 older lasers but they aren't self leveling.
Television is fake...The internet is real
Irishslave is offline
Old 10-23-2017, 07:25 PM   #28
Mike-B's Avatar
Rewards Points: 662
Probably seemed like a stupid question... just thought maybe you guys had figured out something I overlooked.
I have a red PLS 180 and find it to be a great tool. Its comes in handy for all sorts of tasks.
Setting tile courses on the wall, aligning schluter trim on outside corners, setting doors, setting windows, shimming multiple window sills to all match, setting head trim in an addition, plumbing walls, leveling first row of a garage door, laying out garage door track, setting control marks for pouring a basement slab, running water line straight, hanging a 3-panel painting on the wall, laying out receptacles/ switches. Great replacement for a string line in many situations
It comes in handy nearly every day
Mike-B is offline
Old 10-23-2017, 07:38 PM   #29
millhouse's Avatar
Rewards Points: 40
Would use at least once a week for setting cabinets. Would probably find many more uses for it since it is small and easy to set up.
millhouse is offline
Old 10-23-2017, 10:10 PM   #30
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 472
I don't really know the answer to either question, because I don't currently own a laser.
I've used large grade-shooting lasers when I was doing underground utilities, and I've used lasers for siding as well, which was very handy.
But I'm sure I'd figure out real quick all the places I'd use this one.
Delta
Get Off My Lawn.
Old 10-23-2017, 10:11 PM   #31
Jeosua's Avatar
Trade: Tile
I would use it everyday doing my bathroom tile remodels.
Jeosua is offline
Old 10-23-2017, 10:20 PM   #32
Juan80's Avatar
Trade: General contractor
Rewards Points: 444
Twice a week .
Setting cabinets and instal windows
Sent from my iPad using Tapatalk Pro
Juan80 is offline
Old 10-23-2017, 10:35 PM   #33
Dirtywhiteboy's Avatar
Rewards Points: 8,214
This is a tool I use every day! I use it to plumb walls and set siding. I set cabinets and doors with it. It is one of my most useful tools. I have been eyeing that green one for a while now!!!
GIVEAWAY: Pacific Laser Systems PLS 180 Cross Line Laser-img_20171001_152125327.jpg   GIVEAWAY: Pacific Laser Systems PLS 180 Cross Line Laser-work-001.jpg
Dirtywhiteboy is offline
Old 10-23-2017, 10:45 PM   #34
tjbnwi's Avatar
Rewards Points: 4,146
Set electrical outlets.
tjbnwi is online now
Old 10-24-2017, 05:47 AM   #35
B.Johnson's Avatar
Trade: Builder
Rewards Points: 1,632
A couple of times a week. Setting cabinets, tile, flooring, drop ceilings.
Much quicker and more accurate than a level and a chalk line.
Home Designer Series Software
B.Johnson is offline
Old 10-24-2017, 06:22 AM   #36
RichVT's Avatar
Rewards Points: 653
I would use it at least a couple times a week.
Tile work, windows & doors, checking floors, cabinets, lining up electrical outlets etc.
RichVT is offline
Old 10-24-2017, 06:29 AM   #37
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 3,610
If there is a way to attach to the fascia to get a pitch I'd use it every time we do half round gutters instead of 4' level or a chalk line
NYgutterguy is offline
Old 10-24-2017, 08:03 AM   #38
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,420
I have one and use it daily. Small enough for the toolbag, use it mostly for doing ceiling layout.
Sent from my Nexus 6P using Tapatalk
Inner10 is offline
Old 10-24-2017, 08:52 AM   #39
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,521
I would use to find the straightest path from couch to fridge.
Also tile layout, door jambs, ceiling lighting, picture hanging on long walls, cabinet installs, etc. It's even a fun way to find center point over a mantel while the client is observing.
MarkJames is offline
Old 10-24-2017, 08:55 AM   #40
Donut �� enjoyer
TBM's Avatar
Trade: B General Contractor
Rewards Points: 506
id use it everyday, I do alot of work with finished stamped and stained concrete floors. It be nice to layout interior walls so not to use chalk lines. Also with tile flooring. Squaring foundations, making sure shingles stay straight, siding, masonry, man how do I not have one in my toolbox already.
TBM is offline
Laser receiver/detectors, which one to get or just buy a whole new rotary laser kit? platinumLLC Tools & Equipment 13 08-14-2017 12:27 AM
What size and kind of service line? help !!! mebedave Plumbing 10 10-31-2010 02:41 PM
Just you step 'cross that line. I dare ya. Kyras Tiling 5 03-13-2010 08:05 PM
Why Did the Chicken Cross the Road? eagleandbaby Off Topic (Non Trade) 3 10-04-2008 08:31 AM
What laser can put a line on the floor? PLS-5? offpiste Tools & Equipment 4 02-06-2007 02:12 PM
