Gas Fireplace - To Vent Or Not
Old 04-15-2007, 10:14 AM   #1
Hardibuilt's Avatar
I have a customer on a custom home wanting to have a recessed area above the fireplace for a plasma tv. I am wondering if a vented fireplace or non vented would be better for this situation? In most cases vented fireplaces put off much more heat and I would initially consider non vented because the fireplace is only used for decoration. I live in a warm climate and heat is not the desired result. If going with a vented fireplace is there anyway to vent thru the ridge cap vs. going thru the roof. I have already had the house shingled when the whole plasma fireplace thing came up.
Hardibuilt is offline
Old 04-15-2007, 12:11 PM   #2
Hardibuilt's Avatar
Re: Gas Fireplace - To Vent Or Not
I thought that someone would have some input on this one.
Old 04-15-2007, 12:17 PM   #3
It's all about the Avatar
woodmagman's Avatar
Trade: I have no face!
Have a look at Dimplex Electric......I have done this in kitchen cabinets, basements and baths. No vent, look good and can be a heating of non-heating source.
woodmagman is offline
Old 04-15-2007, 12:55 PM   #4
concretemasonry's Avatar
Trade: Masonry consultant
Check your codes - unvented gas may not be permitted (most states)
Resale with an unvented could also be a problem even if codes permit it.
Venting through a ridge cap is definitely not permitted.
Dick
concretemasonry is offline
Old 04-15-2007, 01:53 PM   #5
Tom M's Avatar
Why not direct vent out the back. If exhaust is not close to windows or doors.
Tom M is offline
Old 04-15-2007, 02:55 PM   #6
bill r's Avatar
Trade: residential (marine) piers
Personally, I enjoy breathing oxygen.
bill r is offline
Old 04-15-2007, 06:03 PM   #7
Thom
thom's Avatar
I direct vent almost every fireplace. Obviously the FP must be on an outside wall for that to work. You can vent with the recess above the FP by blocking the back corner off and venting up there. Look at installation methods of Heat-N-Glo products on line.
thom is online now
Old 05-07-2007, 04:08 PM   #8
logdoc's Avatar
Trade: Gas fireplace
What state do you live in? There are only 3 or 4 states that you cannot install a vent-free gas fireplace. The vent-free ones do tend to put a lot of heat out and can cause problems if installed without a properly sized hood over it.
I direct vent unit may be your best bet. It is more expensive, but you will not have as many problems with heat issues with the TV.
logdoc is offline
Old 05-08-2007, 10:58 AM   #9
benchmark2323's Avatar
Trade: general contractor
i put a ventless in a house i just built and its awesome as long as you dont keep it running for days. i have a carbon monoxide detector and it has yet to go off. the thing that is nice is that 100% of the heat is coming into your house, and not out a vent (like your furnace). i put it in a 1750 sq ft home and this winter i turned the furnace down and turned the fan on the furnace to circulate the heat. worked great. should not be used as your main heat source. its also not that hard to crack a window if you had to either. it looks good and heats the room very well. i was sold on it
benchmark2323 is offline
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
Fireplace Insert Raised off the Slab Hambone Masonry 14 04-22-2007 09:54 PM
Fireplace Insert Raised off the Slab Hambone Construction 7 04-20-2007 11:57 PM
Direct vent fireplace into brick wood burning chimney? rach0990 Masonry 3 05-25-2006 07:20 AM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
