Garage Door Opening?
Old 12-07-2009, 05:14 PM   #1
Daniel Rochford
Old North's Avatar
Trade: cabinetmaker / home restoration
Rewards Points: 25
Anyone know offhand the rough opening for a typical 9' x 7' garage door opening?
Old North is offline
Old 12-07-2009, 05:26 PM   #2
mics_54's Avatar
Trade: contractor
Re: Garage Door Opening?
Finished opening is the same size as the door. So the rough opening depends on how you are going to finish the opening. If you are finishing the opening with 2x8 then the rough opening is 3 inches wider and 1 1/2 inches higher than the door or 9'-3" x 7'-1 1/2" etc etc. The weather trim then is positioned against the door on thefinished opening.
mics_54 is offline
Old 12-07-2009, 05:29 PM   #3
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,209
Rough opening is generally 3" wider than finish door (if using 2x material) or 1 1/2" wider (if using 3/4 material)
Height works the same way. Doesn't hurt if the opening ends up slightly less on the finish.
Easy Gibson
Warren is offline
Old 12-07-2009, 05:40 PM   #4
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,110
Yup, 9x7. Pad as you wish.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 12-07-2009, 05:41 PM   #5
samccard's Avatar
Trade: Property Preservation and Remodeling.
Rewards Points: 75
Normally 3" on width 1 1/2" on height. This might help:
http://www.clopaydoor.com/Garage-Door-Fundamentals.aspx
www.destinyhomesinc.com
samccard is offline
Old 12-07-2009, 05:54 PM   #6
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
WOW ! Everyone got it right and everyone agreed. Is this a first ?
katoman is offline
The Following 3 Users Say Thank You to katoman For This Useful Post:
Chasing Dreams (12-08-2009), genecarp (12-07-2009), robin303 (12-07-2009)
Old 12-07-2009, 06:25 PM   #7
Joasis's Avatar
Rewards Points: 806
I always frame them exact, and use 3/4 to trim with. Works everytime.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
Old 12-09-2009, 08:39 AM   #8
Daniel Rochford
Old North's Avatar
Rewards Points: 25
thanks guys that answers that!
Old 12-09-2009, 09:38 AM   #9
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
You need to cover the ends of the garage door a little.
If you have a 9' wide door that is 7' tall (just so happens to be the exact size I just installed) you want your finished opening to be something like 9' - 2" so you cover one inch of the door side to side. Do the same on the top.
When the boys show up to install the door they need to build off the finished opening and if the door is excatly the size of the rough opening the panels are going to be not supported.
If you are using a weather sill you might only overlap the door by 1/4" or 1/2".
I was told to frame the rough opening the same size as the door. The the finished stock 3/4" or 1 1/2" is the amount that over laps. It looked a little heavy so I framed it so my finished opening was 2" shorter than 9' and height was 1" shorter than 7'.
Good Luck
JohnFRWhipple is offline
Old 12-09-2009, 01:30 PM   #10
Al Smith
A W Smith's Avatar
Rewards Points: 1,000
yes your masonry should be three inches wider than your door to accept the 2x10 jamb. On the interior edge of the Jamb go 2X4 or 2X6 caps to accept the track and head hardware. I use 2X10 jamb material because it ends up flush on the interior of 8 inch block and projects 1 3/8" to 1 7/8" (depending on parge thickness if any) beyond the sheathing and foundation on the exterior.
Al Smith
http://www.awsmith.com
A W Smith is offline
The Following User Says Thank You to A W Smith For This Useful Post:
jeffatsquan (12-09-2009)
Old 12-09-2009, 01:36 PM   #11
Al Smith
A W Smith's Avatar
That's what the garage door stop is for.
Al Smith
Old 12-09-2009, 02:01 PM   #12
jeffatsquan's Avatar
Trade: builder/renovator,Squam Lake NH
Rewards Points: 250
That's right A W SMITH it all starts with getting the MO correct it reads like you produce a nice looking opening well thought out and planed.
We don't build on block much so the OHD openings need to be planed in the foundation work. When we have multiple openings I like to not have the bump ups in-between and instead we use granite curbing it looks really nice
jeffatsquan is offline
Old 12-09-2009, 04:36 PM   #13
ampman
ampman's Avatar
Trade: providing pathways for electrons and protons
Rewards Points: 516
on my shop i'am going to have 10x12 roll up doors installed would the r/o be 10x12
an army of sheep lead by a lion will defeat an army of lions lead by a sheep
ampman is offline
Pole Barn Garage mrmike Carpentry 26 10-28-2009 08:29 PM
Framing 20'x20' garage carterarce Framing 12 09-29-2009 11:24 AM
does the garage really need the GFI? handyman99 Electrical 21 08-31-2009 12:33 PM
Vapour barrier between garage and living area?? big builder Insulation 18 12-23-2008 02:25 PM
Epoxy Garage Floors RoSSco Painting & Finish Work 8 09-04-2008 11:00 AM
