Garage Door Opener Losing Code
Old 01-31-2018, 09:25 AM   #1
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 482
On Sunday, I programmed two different garage door openers at a clientís house with two different openers (the ones in the headboards of the cars). They worked all day Sunday. On Monday, they donít work anymore (neither car Ė neither opener). Any ideas on what could be happening?
I contacted my garage door sub and got these steps to follow:
1. Unplug the units for one hour.
2. Remove all LED and CFL lightbulbs for the area.
3. Reprogram after the hour.
Does this make any sense?
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is online now
Old 01-31-2018, 09:35 AM   #2
cwatbay's Avatar
Trade: Electrical Contractor
Rewards Points: 1,862
Re: Garage Door Opener Losing Code
A client of mine had the same problem. Found out it was the CFL lights in his garage. Openers worked for a short time then quit. He replaced the CFL's and everything worked again.
They seems to work ok with LED lighting. Same thing in our living room. Remote controls would only work sporadically with CFLs, changed to LEDs and now everything works.
cwatbay is online now
The Following 3 Users Say Thank You to cwatbay For This Useful Post:
DaVinciRemodel (01-31-2018), hdavis (01-31-2018), Railman (01-31-2018)
Old 01-31-2018, 10:38 AM   #3
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,090
Long shot, but: Are you sure you're not entering a temporary code?
Chuck Norris can cut through a knife with hot butter.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
DaVinciRemodel (02-01-2018)
Old 01-31-2018, 11:21 AM   #4
Railman's Avatar
Trade: Railing
Rewards Points: 263
I recently went through the same ordeal, but thought I messed with something on the unit when I was resetting the limits. I was almost convinced the unit went bad, because it didn't make any sense how I could have reprogrammed it.
Once I found a u-tube video on reprogramming, it's been good to go. The whippy dip lights, in combination with constant Duke Energy brown outs, and power surges was probably the cause.
Railman is offline
Old 01-31-2018, 10:35 PM   #5
RickP's Avatar
Trade: Door Installer
Rewards Points: 76
What brand of opener? Yes, install incandescent bulbs if there are LED's or CFL's.
RickP is online now
Old 01-31-2018, 11:47 PM   #6
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 8,120
I learned something today!
Damned remotes & CFLs !!!
"Your talent is God's gift to you. What you do with it is your gift back to God." - Leo Buscaglia
SmallTownGuy is online now
Old 02-01-2018, 09:35 AM   #7
Rewards Points: 482
I think I was entering the permanent code. Now you got me thinking.
Old 02-01-2018, 10:01 AM   #8
RickP's Avatar
Rewards Points: 76
Some of the new openers can be frustrating ​to program. Used to be able to push the learn button and then push the remote and you were done. Now you have to hop on one foot with your hand on your head and spin around.
RickP is online now
Old 02-05-2018, 10:06 AM   #9
FlowTheWood's Avatar
Trade: Renovation + Restoration
If you take a cheap voltage tester and press the button and walk by a cfl, itís puts enough voltage into the air to set off the voltage tester, fluorescent tube lights do it too.
FlowTheWood is offline
Homeowner Fights Town Rules On Roofing greg24k General Discussion 79 03-08-2013 07:03 PM
First time ZackyBundles Drywall Picture Post 155 02-07-2013 08:11 PM
2 spare breakers 15 & 20a, want to wire outlets in garage pitterpat Electrical 8 05-13-2012 03:58 PM
Is Glass code in garage door between house and garage? abacab Windows, Siding and Doors 23 09-14-2011 08:17 PM
Vapour barrier between garage and living area?? big builder Insulation 18 12-23-2008 02:25 PM
