Garage Door Opener
Old 09-05-2009, 05:16 PM   #1
wannabe
WNYcarpenter's Avatar
Trade: carpentry
Garage Door Opener
Okay...three times today... My garage door has opened on its own while I've been home.
I opened it this morning to load my truck, and thought I closed it when I left....got home, the door was open, and cursed my self. A little while later I heard a noise, went ouside and it was open again. This has happened two more times.
What's going on?
I have one remote (6wk old battery) that is on the visor in my truck (just checked incase it was stolen) and one switch on the wall. The sensors seem to be working. LED is on and flickers when I wave my hand in front of it.
It's almost like a neighbor is having fun with me....
Any diagnostic suggestions, Im not sure where to start?
WNYcarpenter is offline
Old 09-05-2009, 05:20 PM   #2
Re: Garage Door Opener
Try changing the codes.
neolitic is offline
Old 09-05-2009, 05:21 PM   #3
Work too cheap
quality1stconst's Avatar
The button on the wall station is sticking
Will Not Settle for Mediocrity
quality1stconst is offline
Old 09-05-2009, 05:21 PM   #4
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Aluminum foil the whole house, double wrap the garage. Tape the seems. It's all in the details.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
Old 09-05-2009, 05:26 PM   #5
Grand Rapids Remodeling
Paulie's Avatar
Airplanes?
www.phbconstruction.com
Paulie is offline
Old 09-05-2009, 05:42 PM   #6
wannabe
Trade: carpentry
Thanks, neo...and all
My remote has a single rubber button...I went to fetch it from the truck to started figuring out how to change the code.......soon as I grabbed it the door went up and I noticed the rubber button hadn't fully realesed.
For now, I'll assume that was the problem. I only used my remote once today, the rest were with the wall mount.
I'm still curious, if the button was partially engaged wouldn't the door be herky-jerky instead of opening intermittently?
At any rate, I'll get a new remote, and wall switch.
Old 09-05-2009, 06:51 PM   #7
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Bad contacts maybe on the pushbutton?
Magnettica is offline
Old 09-05-2009, 07:40 PM   #8
wannabe
Trade: carpentry
Must be...
the rubber cover was hung up on the rigid plastic encasement. I feel like an ass....
Actually, it was a relief the solution was so simple. If in fact that's the problem....since I last posted nothing's happened.
Hopefully I'll be able to replace my remote.
Old 09-05-2009, 08:52 PM   #9
mics_54's Avatar
Trade: contractor
Others in the neighborhood may have openers with the same frequency. I've heard of it happening before...and there are other possibilities.
http://www.aaaremotes.com/gdoopensbyitself.html
mics_54 is offline
Old 09-05-2009, 09:57 PM   #10
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Originally Posted by WNYcarpenter View Post
Must be...
When it comes to troubleshooting electrical circuits it can only be so many things. Knowing what those "things" are and understanding how the electrical system is wired is highly beneficial to fixing any broken circuit. Don't worry, I've been called out to fix stuff like this more times than I care to remember.
The Following User Says Thank You to Magnettica For This Useful Post:
WNYcarpenter (09-05-2009)
Pole Barn Garage mrmike Carpentry 26 10-28-2009 08:29 PM
does the garage really need the GFI? handyman99 Electrical 21 08-31-2009 12:33 PM
Price for Fill / Garage Slab Prep -- Opinions? slr2974 Excavation & Site Work 9 06-17-2009 10:22 AM
garage guru's Nath Construction 17 04-18-2009 11:01 PM
Vapour barrier between garage and living area?? big builder Insulation 18 12-23-2008 02:25 PM
