Garage Ceiling Options
Old 01-04-2011, 08:58 PM   #1
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,110
I have a 1500 sq/ft garage that needs to be insulated and the walls and ceilings finished. I will just sheetrock the walls, quick, cheap and easy.
The ceiling is a different story. I like having the open trusses because I can store some really bulky and long items up there but, heating and cooling are going to be my priority right now.
Ceilings are 8' 6" right now, dry wall and then blown-in insulation (probably use chopped fiberglass).
I kind of like steel on the ceiling but, that stuff is pricey the last time I checked.
Is there an option to insulate and be able to have the open trusses? Or should I just learn to deal with a ceiling.
Thanks Yo.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 01-04-2011, 09:04 PM   #2
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,209
Re: Garage Ceiling Options
Closed cell foam up under the sheathing and between the trusses.
Easy Gibson
Warren is offline
Old 01-04-2011, 09:05 PM   #3
tgeb's Avatar
Rewards Points: 254
Yep, Foam.
www.gebcon.com
tgeb is offline
Old 01-04-2011, 09:05 PM   #4
Raawwwrrrr
blackbear's Avatar
Trade: finish carpentry
Rewards Points: 1,394
how about thick foam board 1 1/2"? cut it to fit. not going to get any significant R value out of that though.
blackbear is offline
Old 01-04-2011, 09:09 PM   #5
I like Green things
Originally Posted by tgeb View Post
Yep, Foam.
Sprayed on the bottom side of the roof sheathing? That would make it a hot roof? Then I should put some fans in to blow the heat down.
I thought about it under the truss chords up high but, climbing around up there would suck.
Warner Mill Works
Facebook
YouTube
Old 01-04-2011, 09:11 PM   #6
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Yes it would. It will also hasten the deterioration of the shingles.
Angus
angus242 is offline
Old 01-04-2011, 09:32 PM   #7
I like Green things
I just re-shingled it last year too.
I need to check the price of pole barn steel this week.
Plywood would be nice, i could screw anything any where to it, like lights and such.
Warner Mill Works
Facebook
YouTube
Old 01-04-2011, 10:43 PM   #8
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Thanks Yo.
IMO, it would be easier to deal with the ceiling. You'll get you're insulation. Add a couple of attic ladders if you are that worried about putting sh!t where it doesn't belong.
griz is offline
Old 01-04-2011, 11:02 PM   #9
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
If you foam under the sheathing you must baffle every rafter space from the soffit to the ridge. Otherwise you can kiss your shingles goodbye. And there should be a ridge vent.
If there is no air flow between the foam and the plywood, you will 'cook' your shingles. I was working for a new home builder who learned this the hard way. Shingles were toast within the first year.
katoman is offline
Old 01-04-2011, 11:06 PM   #10
I like Green things
Damn flat ceilings.
Ok, I really like the pole barn tin on a ceiling in a shop but, it makes it a pain to put stuff through the ceiling or move things around.
OTHO, you could pop a couple sheets off in the middle to get some stuff up there.
Although it is up and done vs. drywall it is kind of expensive for a ceiling.
Warner Mill Works
Facebook
YouTube
Old 01-04-2011, 11:10 PM   #11
Fire up the BBQ
griz's Avatar
Rewards Points: 18
For all your whining, get an engineer, convert flat ceiling to scissors trusses, insulate & rock. Then you have an open bay to store your stuff.
griz is offline
Old 01-04-2011, 11:24 PM   #12
I like Green things
Whining?
Convert the regular trusses to scissors.
Warner Mill Works
Facebook
YouTube
Old 01-04-2011, 11:48 PM   #13
Trim40's Avatar
Trade: Guy who plays with wood
Rewards Points: 550
Rock or plywood the ceiling and put a shed out back for your socks, i mean bulky items.
Trim40 is offline
Old 01-05-2011, 12:28 AM   #14
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Whining?
More than you & the green tools can do?
Ain't all that tough.
griz is offline
Old 01-05-2011, 12:36 AM   #15
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Another option would be to convert a section of your flat trusses to attic trusses.
griz is offline
Old 01-05-2011, 02:10 AM   #16
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extraordinaire
Rewards Points: 858
Hot Damn, that is a great idea. I bet you could do it with plywood gussets instead of the nail plates too. You could lay batt insulation up there then rock it.
Like griz said, with the help of an engineer.
Andy.
ScipioAfricanus is offline
Old 01-05-2011, 06:52 PM   #17
master hacker of wood
FRAME2FINISH's Avatar
Trade: restoration carpentry
Rewards Points: 1,730
find someone that does alot of pole barns, they have cover sheets to protect them in shipping and paint them yourself?????
or figure out what ya need and order two at a time every other day, for every two you get a free one hahaha
FRAME2FINISH is offline
Ceiling mold in garage mjwin HVAC 1 08-13-2010 09:09 PM
Raising ceiling joists lou94stang Framing 10 05-27-2009 10:46 PM
Tray Ceiling Info Needed BreyerConstruct Carpentry 7 11-17-2008 10:28 AM
Ceiling Fan , Medallion and Extension Box joejack NEC Discussion 4 05-11-2008 11:14 AM
High ceiling in garage construction T bone Construction 10 02-24-2007 10:57 PM
