Trade: General Contractor, class B license
Funky Smell
This may be a little bit outa left field, but there is a strange odor in our house and I'm stumped.
Everyday my wife comes home and must open all the windows to air out the place to get rid of the smell. Its best described as musty, moldy. The obvious thing would be some mold issue. I highly doubt it. We've had little precipitation, our underfloor is well insulated, and we have broad overhangs. What else could it be. Its not the dead critter smell either. We do have exposed t and g ceilings, but our roof is less than four years old. Any crazy experiences with funny smells that my give me some insight? |
Service & Repairs
Trade: Electrician
Re: Funky Smell
Maybe something in the HVAC system? Do you have a forced air system?
Custom Stuff
Trade: General Contractor - Custom Renovations
Re: Funky Smell
Just because it hasn't rained and the house is well built doesn't mean you can't have a mold or mildew problem. A pipe could be leaking slowly inside a wall, basement sump crock could be nasty, drain trap dry somewhere, condensation pan under the coils inside an AC unit could be moldy, shower pan could be compromised, and dozens of other things. Could be condensation in the walls due to faulty installation of a vapor barrier, or none at all, could be a lawn mower in which the grass wasn't cleaned from underneath.
I would try closing all the doors in the house when you all leave for work. If the weather is suitable, also turn off the heat/ac fan so nothing is circulated. When you come home, try and isolate which area has the highest concentration of odor and go from there. Keep us posted; I'm waiting for the dead possum under the leaves beneath the deck.
__________________________________________________ ___________ I EXPECT THAT SOMEDAY I WILL SEE THE FRUITS OF MY LABOR. IS IT SOMEDAY YET? ![]() Clifton, Great Falls, McLean, Fairfax Station, Manassas, Virginia Renovation Contractor |
Code Nerd
Trade: Historic Preservationist / Furniture Maker
Re: Funky Smell
drip pan under fridge? I agree with Mike, close it up, shut it down and then follow your nose.
(aka 'The Wolf')
Re: Funky Smell
Funky smells in a house usually connects to something moldy or something dead and/or rotting.
Any and everything you ever wanted to know about mold but didn't want to touch: http://www.epa.gov/mold/
Majestic-Tile, a division of Majestic Home Improvement, LLC. http://www.majestic-tile.com/ My Publishing Company and Graphic Design Portfolio: http://www.bgpublishing.com/ |
Trade: Electrical Contractor
Re: Funky Smell
A little-used drain like a floor drain has had all the water evaporate out of it letting in some sewer gas?
#7 | |
Trade: Professional Berserker
Re: Funky SmellQuote:
Outside walls and plumbing walls should be checked. One way to check them is to turn on all the house exhaust fans. This will de-pressurize the house. Shut the air or furnace down. Keep all windows and outside doors closed. Then sniff all the outlets and wall switches. If there is mold in those walls you will smell it by those openings. Base boards are also a good place to sniff while doing this. Air ducts are a common place for mold. Low spots in the duct work, where moisture can collect are the most common areas. Good luck.
I think I say OOPS!! out loud way to often. Last edited by MBS; 01-22-2009 at 10:55 PM. |
| rotten egg/sulfur smell from oil fired boiler | ApgarNJ | HVAC | 2 | 01-20-2009 06:15 PM |
| can't get rid of bad primer smell....help please | Zeebo | Painting & Finish Work | 17 | 12-10-2008 06:39 AM |
| Sewer drain smell | flashheatingand | Plumbing | 4 | 08-15-2008 10:55 PM |
| pet smell out of carpet any help???? | TurnkeyConst | General Discussion | 20 | 05-25-2008 10:35 PM |
| The smell of ?? | K2 | Off Topic (Non Trade) | 9 | 12-19-2006 07:17 PM |
