Trade: Handyman/ Carpenter
Found 1/2 Sheetrock Under Ceramic Tile Floor
This is one on me.
Is this a new way of installing ceramic tile floors in a bathroom. I went to look a a floor in a 5 year old town house in Hew Hampshire that had a major mold problem. Shower leaking. The tiles were cracked and loose. under the tile was 1/2 sheetrock. Is this a actual practice that i'm not aware of. |
| The Following User Says Thank You to jradziew For This Useful Post: | BrianFox (11-22-2009) |
solar guy
Trade: solar contracting
Re: Found 1/2 Sheetrock Under Ceramic Tile Floor
not on this planet it's not
The Remodeler
Trade: Home Remodeler
Holy Hackjob, Batman!
Re: Found 1/2 Sheetrock Under Ceramic Tile Floor![]() |
Check the walls, maybe the cement board is there, the installer just mixed up the products
, GMOD
Tech Geek
Trade: Property Management/Facilities Manager
WTF? How did it last 5 years?
could it be a hardibacker type material that you have not seen before and assume it is rock?
Trade: Handyman/Pressure Washing/Painting
Re: Found 1/2 Sheetrock Under Ceramic Tile Floor !!!
Trade: Construction
Yeah it could be a densgaurd type of board which can be used for flooring. May look just like drywall.
#10 | |
Its all ball bearings
Trade: Tile
Re: Found 1/2 Sheetrock Under Ceramic Tile FloorQuote:
What if the shower leaked and the installer used DensShield for the floor? While it's not like regular gypsum board, it does have a gypsum core. or That installer was one helluva HACK!!!!
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" |
bathroom guru
Hey, Remember the guy trying to convince everyone that his new CBU shower base was gonna change the World??
Maybe this was his first attempt!!
At least they could have used "Green board".
Average Joe
Trade: D/B, Management, Consulting, Contracting.
http://www.cgcinc.com/home.asp?nav=1...30&bc=1.48.157
Never used it but apparently it works Probably looks just like reg. d-wall. |
Priced In
Trade: Exiled For Life
I have demo'd tile floors with the gypsum backer. The floor was in good shape they just wanted a updated look.
Nothing hackie about if it was actual backer and not sheetrock. |
Shiloe
Was wet sheetrock behind the tile the cause of the mold problem? Sounds hack to me.
Yay! A construction blog! http://www.tarpapercrane.com |
I builds'em
Trade: Renovations & Decks
I have had two 4x8 sheets of DensShield leaning against the back of my house since January. They look the same as the first day I got them, no mold, no damage, nothing.
So, I know there is gypsum stuff that doesn't have issues with moisture. I have also left normal drywall I demo'd in my backyard for a couple weeks before I had the time to take it away and it was mush and growing mushrooms.
Ryan |
#17 | |
I'm not sure it looks like sheet rock it falls a part with water like sheet rock. It clearly has paper on each side. I just can't phathom a contractor using it on all the floors unless it is a new material of some sort. He will not answer my calls |
#18 | ||
Hi It is everywhere there is a leak at the front door and the water has got under the tile and it's all mold there also. The same tile runs right through the house on the first floor. |
#19 |
What is gypsum backer and where would you find it or what would you
| ceramic tile on bouncy subfloor | JohnHomeMatters | Flooring | 16 | 07-14-2009 09:19 PM |
| Intense cleaning of ceramic tile | Mitch M | Ceramic & Stone Tile | 12 | 04-19-2009 10:31 AM |
| Tile over Tile | fireguy | Flooring | 3 | 02-26-2009 11:36 PM |
| How can I get wax off ceramic floor | roo | Ceramic & Stone Tile | 3 | 02-26-2009 06:20 PM |
| Floor dilemma (tile failure) | Knyte260 | Flooring | 4 | 03-16-2006 07:35 PM |
