wannabe
Trade: carpentry
Footing Depths
Last that I'm aware of our footing depth was changed to 42" from 36". I've been told the farther south you go footing depths are shallower.
What are your respective minimum footing depths on undisturbed soil?
"I knew I lost my wallet as soon as I threw my pants over the fence". -'lil jarhead bro when asking for a wire transfer... |
Re: Footing Depths
The United States Army Corps of Engineers, Publication Number EM 1110-1-1905, "Engineering and Design - Bearing Capacity of Soils".
http://www.usace.army.mil/publicatio...905/entire.pdf Page 20 of this document is most helpful, as it has the frost depth contour map of The United States. This is a document most often referred to by AHJ's when they set the footing depth for your town. |
Trade: Custom deck builder
Re: Footing Depths
Only 30" for me.
Re: Footing Depths
Were at 30" here but residential caissons can go 40 ft to bedrock if there is certain clays. Water line at 5' but no minimum on sewer. I think the sewer shoud be 3'.
The Grand Wazoo
Re: Footing Depths
Sewer depth is dependent on the system, septic systems will be about 6" deep, so that they enter the tank above the discharge, for regulaer sewer's it is dependent on the depth of the municipal main, I have seen mains as shallow as 2.5 feet.
Re: Footing Depths
Actually here with all foundations being poured concrete walls, Spread footings are rarely required for a couple of different reasons. Frost protection at 30" is required.
Trade: Porch and Deck Builder
Re: Footing Depths
48". I believe it's the same requirement in all of Ontario whether you live in Toronto or North Bay, which is odd to me. I wonder if Toronto has had frost below 2 feet for quite some time. But dig we must, (I'm speking of decks).
Re: Footing Depths
In my opinion, in my area, if you can't get 3 ft. dept to the city sewer the permit should not be issued. Shallow pipes get blocked and then freeze and then @#$%... I've always been able to have deep pipes to a septic tank too.
#9 | |
Re: Footing DepthsQuote:
Vagitarian
Re: Footing Depths
Around here, we have to do a minimum of 40" walls. So, with a footer, we are 48" deep.
The Grand Wazoo
Re: Footing Depths
That falls to local code, and in the area of septics, the EPA is involved also, there are parts of Wisc. that do not allow septics at all, and you must have a water tight storage tank that you have pumped once a month if there is no city sewer, by EPA mandate.
Trade: general contracting
Re: Footing Depths
24" here in albuquerque
Re: Footing Depths
48". Some years where it's cold with no snowpack is what they are trying to use as worst case scenario. We've dug in hot weather in June and come up with frost.
Re: Footing Depths
24" here as minimum.
Most of our architects require us to go to 30". When we do work in DC. it is 30". |
Trade: contractor
Re: Footing Depths
18" ... i go 24" to be safe
Re: Footing Depths
10" to 12" min depth roughly in FL, but the hurricain fasenings hasssel makes up for it
I'm a Mac
Trade: ICF Construction
Re: Footing Depths
Mostly Post Tentsion Slabs on Grade here, The coldest I've seen in three years is maybe 28F @ night for a week.
Chris |
#18 |
Young Gun
Trade: Smartass
Re: Footing Depths
I did a set of plans for this addition on my parents house in IL. They want/need me to go 50" on it(inspectors). Well It really doesn't matter to me tho, the tractor is going to be digging it anyways. I don't care!
#19 |
menber
Trade: bricklaying
Re: Footing Depths
48'' cleveland
| Mass deck footing codes | Mike Fish | Decks & Fencing | 1 | 07-25-2007 08:34 PM |
| Article On Footing Drains | denick | Excavation & Site Work | 21 | 08-28-2006 09:59 PM |
| Footing Drains | jjtt | Excavation & Site Work | 27 | 07-17-2006 10:28 PM |
| footing size | dproc | Decks & Fencing | 2 | 03-12-2006 12:38 PM |
| Footing size and depth | dproc | Construction | 11 | 03-08-2006 06:25 AM |
