Flue Pipe Soot Problem
Old 12-13-2005, 10:30 PM   #1
magnum's Avatar
Not sure where to post this but a buddy needs some help and I have run out of ideas. Have a wood stove with 6" pipe flang out of the back with 6" 90, 4' vertical pipe to 90 into 8" thimbal to chimney. After 5 days of use 6" pipe leading to thimbal is full of soot. He tried burning hotter, running 6" pipe through thimbal directly to chimney flue.
magnum is offline
Old 12-13-2005, 11:53 PM   #2
reveivl's Avatar
Trade: Renovations
Re: Flue Pipe Soot Problem
What species of wood is he burning, and how well seasoned is it? Hotter will help, but you need good wood. Watch for chimney fires, the stuff in the pipe is likely creosote, not soot, and is highly flammable.
reveivl is offline
Old 12-14-2005, 07:40 PM   #3
magnum's Avatar
red oak and locust and well seasoned. the chimney it self is clean just the flue pipe has soot/creosote. He burns it hot and checks it with a wood stove thermometer.
magnum is offline
Old 12-15-2005, 06:18 PM   #4
TimNJ's Avatar
That's strange. How is the draft on the chimney? Sometimes a cold masonary chimney will have problems getting a draft going. What brand of wood stove? How much is "full of soot"?
TimNJ is online now
Old 12-15-2005, 10:17 PM   #5
Superintendent
ConcreteGuy's Avatar
Trade: Concrete Foundations and Flatwork
Don't burn pine.
______________________________________________
A reasonable expectation becomes an assumption when it goes wrong.
ConcreteGuy is offline
Drain Pipe denick Excavation & Site Work 18 07-12-2009 04:41 PM
Gas Pipe Question.... drbigfresh Plumbing 9 02-28-2007 03:51 PM
Using Flex Pipe dirt diggler Pool Construction & Enclosures 8 02-25-2007 04:30 PM
Strange Fly Problem johnnymac Plumbing 4 09-07-2006 02:30 PM
How to trace gas pipe? karma_carpentry Carpentry 15 11-30-2005 11:47 AM
