Trade: Residential
Flitch Beam Installation
I have to install a flitch beam for a 16' span. The structural engineer is calling for the beam to sit on a 4x4 on each end. Is there some type of boot or sleeve that this beam has to sit in on top of the 4x4's? How do you tie the beam to the 4x4's?
Thanks, Kevin |
Re: Flitch Beam Installation
Are you taking about 1/2" flinch plates that are sandwiched and bolted together? Then just toe nail in the header connection. Make sure your point load is being transferred correctly down below. If its a steel beam you would usually have a steel post with a pre-drilled plate for bolt connection.
Trade: Outdoor contracting: fences and decks
Simpsons makes exactly what you need.
Cabinetmaker
Kweber: why not just make it real ez and use an LVL ? Whole lot easier and faster and cheaper.
JackM |
#5 | |
Remodeler Extraordinare
Re: Flitch Beam InstallationQuote:
I agree with you skymaster, I have installed my fair share of lvl's much lighter than a 16' flitch beam.....but Its hard to say completely without the specifics as to why the engineer is calling for a flitch beam rather than a LVL or glulam though. kweber- find a Simpson distributor in your area they usually will have a Simpson book that will help you figure out the specific bracket that you need for your application
A.W. Davis Construction Co. http://www.awdavisconstruction.com/ Your friendly remodeling contractor Last edited by A.W.Davis; 02-04-2007 at 12:59 PM. |
| Beam Specs | ophnurse | Framing | 19 | 10-02-2007 08:21 AM |
| Main beam sagging 1/2 inch? | AllGoNoShow | Construction | 10 | 10-12-2006 08:20 PM |
| Beam Support Issue | HandyAl | General Discussion | 5 | 06-15-2006 11:11 AM |
| Installation costs? | dennyc | Carpentry | 2 | 06-10-2006 11:09 AM |
| deck beam sizing and post spacing? | diyerforever | Decks & Fencing | 5 | 05-10-2006 10:58 PM |
