A&E's House
Old 07-19-2016, 12:45 AM   #81
back doors to hell put in
Irishslave's Avatar
Rewards Points: 352
Re: A&E's House
Originally Posted by A&E Exteriors View Post
How much are those corners?
You're gonna have a healthy price sheet by the time this is over
"An argument against democracy,” an astute observer once said, “is to spend five minutes with the average voter.”
Irishslave is offline
The Following User Says Thank You to Irishslave For This Useful Post:
SouthonBeach (07-19-2016)
Old 07-19-2016, 12:55 AM   #82
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 11,192
Re: A&E's House
Lol.
A&E Exteriors is offline
Old 07-19-2016, 01:07 AM   #83
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Re: A&E's House
I'm not sure, I did some few years ago, but they were supplied to me.
My local molding outfit can get them, but I haven't seen them in their warehouse. I get the poplar base corners from them sometimes, and they're $3-8 ea for common ones.
If you're good at plaster work, you can cut the profile in mud knives and make plastered round crown corners...
Check it out...
http://www.myoldhouseonline.com/m/di...ATopic%3A23415
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
The Following User Says Thank You to m1911 For This Useful Post:
A&E Exteriors (07-19-2016)
Old 07-19-2016, 06:05 AM   #84
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 3,332
Re: A&E's House
Deckhead lives in Florida...he don't know what a furnace is
Sure I do, its like an oven but for people
He knows nothing about everything and isn't afraid to prove it, so he defends ignorance with stupidity.
Deckhead is offline
Old 07-19-2016, 07:26 AM   #85
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 12,458
Re: A&E's House
Originally Posted by Californiadecks View Post
Not if it's done right. The office.
I actually get them even better for customers. I'm a hack on my own home.
That's interesting, here the bullnose transitions to a square about 6" above the baseboard and below the crown. Looks kinda slick.
Inner10 is offline
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
A&E Exteriors (07-10-2017), Californiadecks (07-19-2016)
Old 07-19-2016, 08:15 AM   #86
Been around
Mr Latone's Avatar
Trade: Roofing
Rewards Points: 1,562
Re: A&E's House
Good for you for trying to plan ahead. But don't fool yourself as to the cost of your time. I know we have time in the evenings and on weekends that we just won't be working for someone else, so yes, you can effectively save money this way. But don't forget life can get in the way.
Much productivity is lost in setup and tear down and clean up. In the start/stop/cleanup VS work progress ratio it's best to keep the former to a minimum.
It's easier to factor the PITA of working around someone else when pricing a contract. We all know that it takes more time when working around other people's stuff, but somehow overlook that or at least discount it in our own environs.
So it boils down to this IMO...Get it done as efficiently as you can. Finish it completely before you move into it. Living in a working space and working in a living space aren't typically very efficient ways to proceed.
Above all, a good roof
Mr Latone is offline
The Following User Says Thank You to Mr Latone For This Useful Post:
Old 07-19-2016, 10:36 AM   #87
VinylHanger's Avatar
Rewards Points: 7,576
Re: A&E's House
To me the hardest part, taking out exhaustion and burn out, is tool setup. Make sure you have an entire set of tools just for the house if you are going to have areas blocked off and being worked on. It is both frustrating and time consuming to pull out all your gear from the trailer, then set up the saws, then work a few hours after work or the weekend and then tear down and reload it all. Or even worse is getting to the job site and realizing you left your bag with all your screw guns at the house, or the finish guns, etc.
Small expensive things like nail guns aren't so bad to grab, but larger things like chop saws, table saws or constantly needed screw guns, bits and Sawzalls, etc., are nice to just have out and ready when you get home.
VinylHanger is online now
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
A&E Exteriors (07-19-2016), MonsieurBon (10-26-2016)
Old 07-19-2016, 11:18 AM   #88
hdavis's Avatar
Rewards Points: 8,959
Re: A&E's House
Where I will need to carry load down in the crawlspace, would footings on grade be ok or should I dig holes for the footings?
Should I screw the ceilings to the new floor trusses or will attaching the remaining chords of the roof trusses to the new trusses be sufficent?
Footings need to go down to undisturbed soil - maybe that's at grade, maybe it's a few feet down.
Some AHJs would require 2X6 first floor walls to put the second floor on. Make sure you know what your local BI is going to require on existing walls and footings.
Nail the bottom cord of the old to the bottom cord of the new, and plan on having some screw heads show up due to initial movement.
hdavis is online now
Old 07-19-2016, 11:39 AM   #89
hdavis's Avatar
Re: A&E's House
Get a dedicated compressor and hose that's big enough to run a framing gun. Lugging and setting that up / rolling it back up stinks when you're already tired. Consider getting a dedicated framing gun as well.
Get dedicated extension cords as well.
When it comes to paint, spray it out in a day or two. Brush and roll is going to be all set up and clean up.
For my own framing, I've used a chainsaw before, but you don't want to do that it you're tired or haven't done a bunch. It's fast...
Old 07-19-2016, 11:57 AM   #90
Re: A&E's House
I am completely on board with the dedicated house tools. I am actually going to take my electric compressor in to get fixed tomorrow so I can have it ready to go when the time comes
For the shell I am taking a week - week and a half off and going full time on the place. Then I will work in a couple other weeks as I can.
The Following User Says Thank You to A&E Exteriors For This Useful Post:
hdavis (07-19-2016)
Old 07-19-2016, 03:01 PM   #91
Irishslave's Avatar
Rewards Points: 352
Re: A&E's House
Too bad you have to do it on borrowed money....that's the part that would take the excitement out of it for me
me would rather pay for it now if at all possible instead of the rest of my life
Old 07-19-2016, 03:12 PM   #92
Re: A&E's House
I'm paying for the addition with my money
Old 07-19-2016, 05:30 PM   #93
hdavis's Avatar
Re: A&E's House
Pay for it with Eric's money, it's a better deal for you.
A&E Exteriors (07-19-2016), slowsol (07-19-2016)
Old 07-19-2016, 05:39 PM   #94
GC/carpenter
Californiadecks's Avatar
Rewards Points: 8,362
Re: A&E's House
It sucks being a HO at times. Especially if you're a contractor.
I've always said HO insurance companies should give contractors discounts. I can't tell you how many boo boo's I've fixed that I could've made a claim for.
Californiadecks is offline
Old 07-19-2016, 05:46 PM   #95
Re: A&E's House
LMAO!!!! not sure he would go for that hahahahahahahahahahahaha
hdavis (07-19-2016)
Old 07-19-2016, 06:52 PM   #96
#MAGA
EricBrancard's Avatar
Trade: Builder/Renovator
Re: A&E's House
I don't need anyone's help spending that.
EricBrancard is offline
The Following 2 Users Say Thank You to EricBrancard For This Useful Post:
A&E Exteriors (07-19-2016), hdavis (07-19-2016)
Old 07-19-2016, 09:59 PM   #97
Irishslave's Avatar
Rewards Points: 352
Re: A&E's House
it'll get done faster
Old 07-19-2016, 10:05 PM   #98
Irishslave's Avatar
Rewards Points: 352
Re: A&E's House
I think they screw you because you are...cause they probably think you screwed them somewhere along the way
Insurance is such a dirty business
The Following 2 Users Say Thank You to Irishslave For This Useful Post:
A&E Exteriors (07-19-2016), Californiadecks (07-20-2016)
Old 07-20-2016, 07:18 AM   #99
Re: A&E's House
Holy chit! Floor truss price estimate came back at 3,500
Old 07-20-2016, 07:21 AM   #100
Inner10's Avatar
Re: A&E's House
Yeah renos are expensive.
Inner10 is offline
The Following 4 Users Say Thank You to Inner10 For This Useful Post:
A&E Exteriors (07-20-2016), Agility (07-22-2016), asevereid (07-20-2016), BamBamm5144 (07-22-2016)
Whole House Trap Venting NJDan Plumbing 2 01-12-2012 08:51 PM
no wires to house...how can this be done... Pennyroyal's Technology 25 11-28-2011 09:28 AM
Pipes to Attic? Old House Mystery. JRSeifert General Discussion 20 10-15-2011 05:15 PM
Extreme Makeover House Bergstrom Finish Carpentry 6 10-10-2009 10:49 AM
The coolest house ever? HusqyPro General Discussion 24 08-14-2009 08:45 PM
