Epoxy That Turns Rotten Wood Into Solid Wood
I bought an epoxy product that turned rotted window sill into a solid piece of wood again. The stuff works great. I was wondering if anyone else has try it?
#2 | |
Its all ball bearings
Trade: Tile
Re: Epoxy That Turns Rotten Wood Into Solid WoodQuote:
![]() Sounds weird but I can't judge. I haven't seen it before.
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" |
Trade: Residential Remodeling
I used one a number of years ago on a wood frame around a etched glass window. Explained to HO that the proper way was to remove the window and have the frame rebuild but he did not want to go that expense since they were moving.
After digging around I found a wood stabilizer and epoxy kit from Elmer's. I swear the stuff looked like my kid's Elmer's glue . So with much skepticism I gave it a try and was quite surprised that it worked fairly well.Not sure I would use it often but in that particular case... |
Branch Manager
Trade: Painting Contractor
Ive found that this works really well: Minwax Wood Hardener (liquid form) to stabilize spongy or rotted wood followed by a lightweight 2 part body filler to rebuild & shape, usually found at paint stores, or Bondo (its just alot harder to sand) prime with oil primer or marine primer better yet, & paint 2 topcoats.
Of course, a complete tear-out & redo is best, all it takes is money.
JasonW turned me on to this stuff
http://www.abatron.com/cms/buildinga...rationkit.html Waaaay better than Bondo or MinWax.
| The Following User Says Thank You to neolitic For This Useful Post: | Tom Struble (01-31-2010) |
#1 stunner
Re: Epoxy That Turns Rotten Wood Into Solid Wood![]()
| The Following User Says Thank You to Static Design For This Useful Post: | skyhook (01-31-2010) |
Trade: Remodeling / Carpentry
Like Neo said......
I use this also http://www.rotdoctor.com/products/product.html Since finding these products a few years ago I have used at least the epoxy sealer / stabilizer for all rotted wood. Depending upon the budget I'll then use Abatron, Rot Doctor Restoration Putty or Bondo. |
| The Following User Says Thank You to We Fix Houses For This Useful Post: | brushmonkey (01-31-2010) |
Trade: carpenter/remodeler
I would never use a bondo type filler in an exterior application. I have used this product for many years:
http://www.advancedrepair.com/archit...artssystem.htm It is easy to use and works well. |
| The Following User Says Thank You to Shawn Prentice For This Useful Post: | afkama (01-31-2010) |
#9 | |
Super B
Exopy is plastic. rotted window sill is wood.
Only the naive believe you have transformed epoxy plastic into a solid piece of wood, again, like Jesus turned water into wine, once. Window sills get dryrot from wet/dry cycles. Dryrot is a wood destroying fungus. It can not be killed, it must be cut out and removed. Plastic band aids only disguise the problem, not cure it. These are products designed for ignorant home owners, do it yourselfers and handymen. Your statements are totally false and an insult to the intelligence of the Building and Safety Professionals on this web site. Last edited by skyhook; 02-15-2010 at 02:44 AM. |
#10 | |
Chief Toilet Mover
Trade: Bathroom Remodeling
#11 | |
some Neosporin and a band-aid, at another point your arm must be amputated. There is some discretionary space between the two.
| The Following User Says Thank You to neolitic For This Useful Post: | skyhook (02-15-2010) |
Trade: MFG Commercial Screen Enclosures
We don't perform any restoration work but a regular customer of ours named Paul Marlowe of Marlowe Restorations has quote a good business (and following) in this trade. He specializes in the repair of historic woodwork using epoxies. I cannot attest to the product(s) but you can find information on his business and the epoxy product on his web site. Hell, give him a call if you have questions - he's a nice enough guy and would probably help you out.
Marlo Restorations, LLC |
#13 | |
I builds'em
Trade: Renovations & Decks
If the wood is a structural member of any sort, then what you are saying is correct. The world is not black and white.
Ryan |
| The Following User Says Thank You to Winchester For This Useful Post: | skyhook (02-15-2010) |
#14 | |
Branch Manager
Your totally right about this product
I like Green things
West systems is also good. Abatron is hard to get around here, west is easier.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana Warner Remodeling Facebook |
#16 | |
Trade: Control Systems
#17 | |
http://www.rwps.com/ That's pretty close, no?
#18 |
Trade: Porch and Deck Builder
I use West System. I figure if it's good enough for a boat then it's good enough for a house. Buuuuuuut it can be finicky when it come to mixing and curing.
"Neek...Neek...yoo-a-moronna Neek. Getta-da-fookin-a-jacka-ham!" http://www.vicporch.ca Deck Fence Porch Builder Toronto |
#19 | |
I like Green things
![]() I can order it, just like talking to a person about it when I buy it. Some of the marina's around here carry the West.
#20 | |
The liquid kills the fungus or spores that is destroying the wood. You can also use anti freeze to kill the spores. I didn't say the stuff actually turned rotten wood into real solid wood. It turned the wood into a solid piece again. I used it and it worked great. Read up on the latest products before you accuse anyone of false statements. |
| The Following User Says Thank You to rstarre For This Useful Post: | skyhook (02-15-2010) |
| Tags |
handyman repairs ![]() |
| Moisture Problems with Carrera Marble and Epoxy Grout | Tallguy1 | Ceramic & Stone Tile | 4 | 10-13-2009 10:50 PM |
| Looking for help on epoxy floor bid. | BLASTPRO | Painting & Finish Work | 3 | 09-23-2009 07:53 AM |
| LEED Certified Wood | CF Construction | Business | 6 | 02-27-2009 04:45 PM |
| Covered Patio 10 x 10 - Should I wood block? | gussy1971 | Roofing | 1 | 01-27-2009 06:19 PM |
| Wood people I need your help | Floorwizard | Flooring | 11 | 05-18-2006 09:07 AM |
